Author Topic: Coil selection  (Read 944 times)
Offline dxhall
Coil selection
« on: December 14, 2021, 11:31:01 AM »
I’m working on the wiring to my project Aermacchi / Harley.  Mostly because I want to run an electronic tach, and also because I want to use a micro-sized battery, I need to  convert the old electrical system to 12 volts.
My idea is to wire the stock 6v generator to the stock regulator, and wire the regulator to a 6- to 12v converter, and the converter to the battery.  That seems simple enough.
The thing I haven’t yet figured out is what coil I need, or whether any 12v coil will work.  With breaker-point ignition and no fuel injection, does it matter what coil I use?
I have way too much money and time into this bike, although it is kind of cool in a strange way.  I hope it doesn’t turn out to be a total dog.
Re: Coil selection
« Reply #1 on: December 14, 2021, 12:02:51 PM »
If your feeding the coil 12V, then any 3ohm internal resistance automotive coil should work. Think Bosch Blue, but any decent one from you local auto parts store should be fine. I would stay away from oil filled cols if you can.
Offline moto-uno
Re: Coil selection
« Reply #2 on: December 14, 2021, 05:20:28 PM »
  I'd be curious what actual amperage may be available if your idea of using a transformer works out .
  I worked on the 350 Aermacchis' when they were new , and they were rather lame performing even then .
  With enough money they got fast , but how much more money do you want to spend ?  Peter
