Alloy wheels
Topic: Alloy wheels (Read 2422 times)
BMCMOTO
Alloy wheels
December 18, 2021, 09:04:35 AM »
I now have correct alloy wheels (thanks to BC) to replace my cracking spoked wheels on my Mille. I am considering a color change to black or gold. What is the general consensus on paint or powder coat? I have access to both and prices are somewhat comparable. The powder coater wants to sand blast before coating, paint shop will dip to remove previous coating, which I believe is powder. All ideas welcome!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
kfz
Gaggle Mentor
Re: Alloy wheels
Reply #1 on:
December 18, 2021, 03:04:24 PM »
powder coat everytime for me.
Kev
kfz
Gaggle Mentor
Re: Alloy wheels
Reply #2 on:
December 18, 2021, 03:06:02 PM »
BTW what happened to the Mille wheels. Really nice quality, Akront rims. Should I check mine?
Kev
BMCMOTO
Re: Alloy wheels
Reply #3 on:
December 18, 2021, 05:34:36 PM »
Cracking between spoke holes is what led me down this path. Apparently there was a recall or warranty replacement deal in the 90s. I clearly missed the deadline on that one. Would either of you powdercoat proponents care to expand one your reasoning? I wory about losing edge flange details and contamination with sandblasting. The paint guys dip them to strip and can remachine edge the surface and remove some edge dings. The powder coater can blast and powder coat only.. Any color opinions?
Thanks guys!
Brian
Last Edit: December 18, 2021, 07:43:07 PM by bmc5733946
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Cam3512
Re: Alloy wheels
Reply #4 on:
December 18, 2021, 06:06:43 PM »
Powdercoat is more durable. Being peppered with dirt, gravel and other road debris I would go that route
BMCMOTO
Re: Alloy wheels
Reply #5 on:
February 20, 2022, 08:08:49 AM »
The refinished, powdercoated wheels.
They aren't perfect but they look pretty good and i think they will add to the bike
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Scout63
Re: Alloy wheels
Reply #6 on:
February 20, 2022, 04:36:17 PM »
Very nice. Good call.
Ben Zehnder - Orleans, MA USA
SED
Re: Alloy wheels
Reply #7 on:
February 20, 2022, 10:28:39 PM »
Tire beads fit very tight on some rims. I made the mistake of powder coating between the flanges and it was almost impossible to seat the bead. There is masking tape for powder.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
BMCMOTO
Re: Alloy wheels
Reply #8 on:
February 22, 2022, 04:57:16 AM »
There is a very small amount in one of the wheel bearing bores that I think I can remove. The cush spigot is clean and free of powdercoat. I am afraid that they might not have been as clean as would be best before coating, there is some tire residue evident in the area between the beads etc. so I am not sure how he cleaned them. He has a bead blast cabinet and a vapor hone setup. I wish I had asked to see them after he cleaned them and before he coated them. He is doing some othe small pieces for me now. I am old enough now that perfection matters less and less, none of this can be taken with us our final journeys, so maybe the next guy gets to deal with the flaws and imperfections. It is going to look great!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
guzzista
Re: Alloy wheels
Reply #9 on:
February 22, 2022, 10:51:39 AM »
In honoring Guzzi content(aka inexpensive way to do stuff), allow me to mention an alternative to powder coating. Duplicolor or VHT wheel paint, combined with its respective clear coat, can provide a reasonable cost way to get cast wheel to look better. The color below on my bike (VHT) was intended for matching Chevy Rally Wheels. Other colors are available. As the various tints originally on cast wheels either faded , lost the clear coat, or otherwise are not longer as when new, this could work reasonably well. Blasting is ok, but not necessary ( esp. if it cost $ >Guzzi content again) if the wheels are scrubbed clean/ flaking paint sanded/etc and are pre-paint prepped. Links to VHT and Duplicolor.
Guzzi Content lives!
https://www.duplicolor.com/product/wheel-coating/
https://www.vhtpaint.com/high-heat/vht-wheel-paint
Last Edit: February 22, 2022, 10:56:55 AM by guzzista
BMCMOTO
Re: Alloy wheels
Reply #10 on:
March 17, 2022, 05:19:25 PM »
I am no Chuck S. so only a few pics. Progress is being made but slow.
I ran into problems between the caliper bracket and the inside surface of the rotor mounting plate. I ending up modifying both. The caliper bracket has cast in ridges for reinforcement and the rotor mount plate is just a little high, so some got removed from both and then repainted. The new rotor doesn't mount exactly as the old.
Please disregard the messy shop, I told you I wasn't Chuck. The top plug is missing from the drive housing because there is no lube in there. I'm out, so tomorrow for that. Housing powdercoated, bracketry painted and baked for a couple of hours, wheel balanced, wheel weights painted. Anal much???!!!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Jack Straw
Gosling
Laugh More, Live Longer
Re: Alloy wheels
Reply #11 on:
March 17, 2022, 08:49:16 PM »
Rattle cans with good prep are dandy and a fraction of the cost of powder coat or "pro" painting.
BMCMOTO
Re: Alloy wheels
Reply #12 on:
March 30, 2022, 12:17:22 PM »
The project is mostly done, still a few small things to finish.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Re: Alloy wheels
Reply #13 on:
March 30, 2022, 01:15:22 PM »
That looks really nice!
BMCMOTO
Re: Alloy wheels
Reply #14 on:
March 30, 2022, 02:31:44 PM »
Thank you fotoguzzi! This bike is 33 years old and I've owned it for 30 of those years. I haven't put many miles on it but it has been my favorite to ride for a long time. I am very happy with the way it turned out. I got the SPII fairing mounted last spring and got it painted to match in the late summer so I have now completed most of my wish list, a list built over the years of living with this bike. I do have a few other things I would like to accomplish with it yet but at 71 years old they are less and less important. Impatient now for riding weather, icy this morning.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
moto-uno
Re: Alloy wheels
Reply #15 on:
March 30, 2022, 06:25:31 PM »
Well I gotta tell you , that's one fantastic job
. Now of course I'd be terrified to ride it unless the
weather was perfect
. Really nice job ! Peter
Alloy wheels
