Author Topic: RPM limit of late Model MGs?  (Read 2396 times)
Offline bad Chad
« on: December 23, 2021, 05:23:45 PM »
The B1100 I have trips the light fantastic at 7600 as I recall, no matter how hard I try, it won't go for more, less something might go Boom!  My newer SB 17 v9 will not go beyond 6800, but to it's credit, it has a considerably stronger torque spread.  I'm just wondering what the difference might be among small blocks?  The v9 is done at 6800, are the other SB the same?
« Last Edit: December 24, 2021, 09:57:55 AM by bad Chad »
Re: RPM limit of late Model MGs
« Reply #1 on: December 23, 2021, 05:31:48 PM »
I'm sure the V9 came with an adjustable rev limiter just as the V7s did. They come from the factory set on the low side.
I have never set my V7 higher so it will cut out early, I often hit the rev limiter in 1st and 2nd taking off at the lights.
I found this thread on setting the limits
https://wildguzzi.com/forum/index.php?topic=96373.0
« Last Edit: December 23, 2021, 05:41:28 PM by Kiwi_Roy »
Offline Murray
« Reply #2 on: December 23, 2021, 06:13:49 PM »
Adjustable change light, red line was limited by the ECU for run in then is defaults to the factory's setting.
Offline bad Chad
« Reply #3 on: December 24, 2021, 09:53:28 AM »
I know all that fella’s,  I’m talking about the Max allowable rpm that the ECU will allow.
The Revlimiter will not allow it to spin over 6800, at least with stock map.
Offline Kev m
Re: RPM limit of late Model MGs?
« Reply #4 on: December 24, 2021, 10:44:17 AM »
I don't know about either of my smallblocks.
But I assume it varies by model just from what I see you've posted here and from hp ratings on some models like the V85.
The original V85 was listed as having peak hp at 7750 rpm and the current version at 7980 rpm, so I'll assume they probably rev higher than 6800.
« Last Edit: December 24, 2021, 10:44:46 AM by Kev m »
Offline yogidozer
« Reply #5 on: December 24, 2021, 11:28:52 AM »
High RPM might sound impressive, but how the engine pulls is what's important.
I'd rather have good power where you need it most.
That's why old ironhead Harleys had 4 speed gearboxes.
Pulled from the basement, no need for 14,000 RPM
GuzziOrDeath
« Reply #6 on: December 24, 2021, 03:04:07 PM »
Stock V9 rev limit is 7100 RPM.
V7/V7II is 7200 RPM
V7III is 7250
Offline Joliet Jim
  • Justus Esto, Et Non Metue
« Reply #7 on: December 24, 2021, 07:18:56 PM »
I once asked my Triumph dealer what the redline was on my 78 bonneville. He sad X, and it will do X x amount of times. Turned out if X was 8000rpm, x was 1.
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Offline bad Chad
« Reply #8 on: December 24, 2021, 07:26:07 PM »
V7/V7II is 7200 RPM
V7III is 7250
Where did you obtain this info?
Offline chuck peterson
« Reply #9 on: December 24, 2021, 07:39:10 PM »
Those numbers seem low to me
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
GuzziOrDeath
« Reply #10 on: December 24, 2021, 08:27:42 PM »
That's the rev limit in the maps.
Offline chrisfer
« Reply #11 on: December 25, 2021, 07:32:12 AM »
Exact :
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
Offline SmithSwede
  • I don't want a pickle
« Reply #12 on: December 25, 2021, 12:54:51 PM »
Not being critical, but I’m not sure why you would want to rev a small block to the absolute limit. Seems to me the horsepower increases as you go up, and things are lively between 5 and 6K.  But the show is pretty much over just past 6,000, so time to upshift.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline bad Chad
« Reply #13 on: December 25, 2021, 03:20:48 PM »
I don't doubt your correct, I'm just curious to know if they vary, and if so, what is gained or loss.
« Reply #14 on: December 26, 2021, 06:03:44 AM »
The rpm limit on smallblocks is different from your big breva. My tach-o-meter, 2007 Nevada v7, twin throttle bodies, says yellow at 7000, red at 8000. As hard as i try I can’t hit the rev limiter. I’m assuming the engineer at Guzzi has blessed it up to that range. I’ll consistently ride rpm to 6800-7000. It’s amazing how much engine braking there is to be had, or the honking great pull when i shift it and land at 5000-5500 with all ponies breathing hard…yeah baby. Itsa gutzee, it gets better the harder you beat on it. But that doesn’t mean I’m going too fast for the conditions..
I’ve got a photo of my tach around here somewhere
someone with v7, I, II, III?
« Last Edit: December 26, 2021, 06:13:54 AM by chuck peterson »
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Bulldog9
« Reply #15 on: December 26, 2021, 04:52:49 PM »
Doesn't apply to the Breva which is a 4V motor, but I had a problem with my 8V Norge that it would not rev past 6000. Just spun up there and hovered.  Ended up that the right side cam timing was off by 1 tooth on the chain. Ran fine otherwise.
I know the 1200 Sport makes max power at 7500, and rev limiter cuts in at 8K.
MGNOC#23231
Offline Moparnut72
« Reply #16 on: December 26, 2021, 05:49:11 PM »
My Audace would hit the rev limiter about 7,000. It didn't just hang but cut the fuel completely with corresponding feeling like something broke. I only hit it twice. Never have hit it with the V7lll.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
