Author Topic: Somebody edumacate me on this  (Read 1855 times)
Offline marcmorrison
« on: December 30, 2021, 09:24:01 PM »
I think this must be where unburned exhaust in the rocker arm/valve cover is routed vis-a-vis a fuel type hose away from that area...however, I can't find anything that specifically identifies its function and just wondering what it is???  I've been replacing various fuel lines on a '99 Bassa, came across this hose (actually one to each cylinder), but it looks like they simply connect to the frame; went ahead and replaced both hoses while i was there, but now curious as to what they might be???
1999 MG Bassa (pearl white)
Online BMCMOTO
Re: Somebody edumacate me on this
« Reply #1 on: December 30, 2021, 09:30:58 PM »
Oil breather.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Scout63
« Reply #2 on: December 30, 2021, 09:33:31 PM »
Looks like a breather line port.  Routes excess rocker arm oil back to the sump via the air box if it’s anything like an old small block. Smarter folks will come along.
Ben Zehnder - Orleans, MA USA
Offline lucky phil
« Reply #3 on: December 30, 2021, 09:41:29 PM »
As others have pointed out it's the rocker area breather hose.
Ciao
« Reply #4 on: December 30, 2021, 09:54:36 PM »
Guess I was on the right track...sorta llike a PCV valve, but what struck me as somewhat odd was that that hose routes back (attached) to the frame.  What does this ultimately accomplish if those exhausts simply end at that point and are not routed back to the air box for recycling??  Am I missing something here??  My "inquiring mind" at work!!
« Last Edit: December 30, 2021, 10:17:26 PM by marcmorrison »
Offline lucky phil
« Reply #5 on: December 31, 2021, 12:37:26 AM »
Not really, more like a vent for the rocker area to evacuate moisture laden air from the high point of the engine and help prevent "mayo" forming there. On a spine frame bike it vents back to the main crankcase which in turn vents to the frame backbone which vents to the airbox and any separated oil drains back into the sump from the spine.
A PCV system draws crankcase cylinder blow-by and depending on the engine configuration crankcase volume fluctuations back into the inlet manifold on closed and partial throttle and not so much on full throttle and not at all "on boost" for turbo/supercharged engines and recycles it.
Ciao
« Last Edit: December 31, 2021, 01:04:18 AM by lucky phil »
Offline aklawok
« Reply #6 on: December 31, 2021, 01:06:37 AM »
 Is it possible that this is actually an air intake for crankcase ventilation and not an exhaust? makes more sense.
2007 california vintage
Offline lucky phil
« Reply #7 on: December 31, 2021, 05:42:24 AM »
Nope
Ciao
Offline Scout63
« Reply #8 on: December 31, 2021, 07:26:26 AM »
You don’t really want air going into your crankcase since the downward stroke of the piston is pressuring the case and if not released tends to blow seals (not those kind). A one way PCV valve or breather valve allows air out but not in. On the big blocks it can be in the breather box or a ball valve coming out of the case. The rocker arm breathers are sometimes blocked off by owners - I keep them as built by the factory.
« Reply #9 on: December 31, 2021, 08:22:01 AM »
Thanks for enlightening me....I feel much better now!!
« Reply #10 on: December 31, 2021, 10:42:07 AM »
They also let the oil drain back into the engine from the frame.
I have had mayo in those lines. PITA to clean them out.
Offline jacksonracingcomau
« Reply #11 on: January 03, 2022, 11:02:18 PM »
What he said
Other Guzzis have oil return to sump (behind clutch on roundies, external on spinies and small blocks)
90’s cali’s don’t, the only place for condensate to settle is at the lowest point, let’s call it a water trap
For OP in Texas, shouldn’t be a problem but pages and pages of mayo posts on this forum to read if interested
« Reply #12 on: January 04, 2022, 06:53:01 AM »
A water trap inside the frame doesn't sound like there will be a good outcome.....hopeful ly that will not occur during my ownership
Offline Chet Rugg
  • Administrator
  • Chet & Rusty ( 99 Bassa )
« Reply #13 on: January 05, 2022, 09:13:14 PM »
on Bassa it starts at the crankcase vents up  large  S shaped hose to frame up front goes down inside of frame goes to small lines that go to rockers.  crank case vent returns back into rockers simple.   Oh yea ball valve at bottom of  S hose where it hooks to crankcase letting it vent one way
s
Chet Rugg
99 Bassa
01 Cali Special
100,000 miles
