Author Topic: Shock for V85  (Read 2486 times)
Offline rudyr
Shock for V85
« on: January 28, 2022, 06:32:02 PM »
I called the dealer about a new rear shock for my V85, 1” shorter.  When I was at MoKan last year a Ace showed my  V85 with 1” shorter rear shock and the little gril that was riding it really like the handling.  Had slipped the front fork tubes on 1” also.  Is stair their were marks on the front tube, to adjust them.  I have put the lower seat and removed the rubber bumper on the under side of the seat.  I think with the 1” more.  I will really be happie with the coming riding year.Rudy
Re: Shock for V85
« Reply #1 on: January 29, 2022, 12:10:29 AM »
What is the eye to eye length of your shock, with the bike on it’s wheels and no one on board Rudy ?
Offline rudyr
Re: Shock for V85
« Reply #2 on: January 29, 2022, 05:40:35 PM »
How about 14” approx. center to center. Rudy
Re: Shock for V85
« Reply #3 on: January 29, 2022, 09:28:07 PM »
I don't know what Don told you about ordering a Guzzi shock but I think he can get a custom shock made here in OKC.
They rebuilt the shock on my V11 Sport but they were originally going to make a new one.  I'll admit that I don't know the company here.
« Last Edit: January 30, 2022, 09:42:38 AM by LowRyter »
Re: Shock for V85
« Reply #4 on: January 30, 2022, 03:22:51 AM »
I just thought I’d ask, because I have replaced the shock on my V85 to lower it about 25-30 mm.
It has the pre load wound right off and my centres  are 14” also.
I am surprised that yours is not longer.
Offline rudyr
Re: Shock for V85
« Reply #5 on: January 30, 2022, 06:05:29 AM »
I just walked out in the cold and put tape to the mounting holes.  That said the spring is loaded to the frist notch.  Don did say he would check with a friend, that builds shocks.  When I was at mo- kan. I checked on the cost of a shock made by the same co. That made the original shock., about $700.00.  Don think his will be cost less.Rudy
Offline Sye
  • Be nice, feel good
Re: Shock for V85
« Reply #6 on: January 30, 2022, 06:37:57 AM »
Hyperpro do a replacement spring to lower the shock by 25mm (1-inch). Not very expensive and should do the job. I'm sure they would ship to the US or there may be a distributor there.
https://www.ebay.co.uk/itm/184374917038
Re: Shock for V85
« Reply #7 on: January 30, 2022, 06:39:35 AM »
On the T7 you just install longer dog bone links, I wonder if you can do that on the Guzzi?
Offline Sye
Re: Shock for V85
« Reply #8 on: January 30, 2022, 06:57:20 AM »
There isn't a dog bone on the V85, it's eye to eye on one side.
Offline rudyr
Re: Shock for V85
« Reply #9 on: January 30, 2022, 09:29:32 AM »
At mo-kan some one suggested shorting the spring( after a few beers).  But that might be something to think about.Rudy
Re: Shock for V85
« Reply #10 on: January 30, 2022, 09:40:41 AM »
Great Italian design work!  :thumb:
Online Vagrant
Re: Shock for V85
« Reply #11 on: January 30, 2022, 09:59:17 AM »
Drop the tubes three lines. That's all you can do without shorting the kickstand. There is a company making a adaptor to lower the shock an inch but I don't recall the name. Forks and seat bumpers did enough for me at 28" legs.
Offline rudyr
Re: Shock for V85
« Reply #12 on: January 30, 2022, 11:34:54 AM »
You know I had already though of kick stand.  The center stand is the one that I will enjoy cutting down.  It’s the one that is a son of a @#$& to get the bike on.Rudy
Re: Shock for V85
« Reply #13 on: January 30, 2022, 01:31:15 PM »
You need to raise the tubes, not drop them.
Also be mindful that the seat base goes very close to the battery with the bumpers removed.
« Last Edit: January 30, 2022, 01:40:58 PM by Huzo »
Re: Shock for V85
« Reply #14 on: January 30, 2022, 01:37:30 PM »
You may encounter some complications shortening the centrestand due to the actuating arm, but depends on how much you chop off.
Remember when you put your bike on the centrestand on a hard flat surface, measure the distance that the rear wheel is clear of the surface and only take a THIRD of that amount off the stand.
I had to modify both my stands to buggery for my muffler job.
« Last Edit: January 30, 2022, 01:37:59 PM by Huzo »
Re: Shock for V85
« Reply #15 on: February 03, 2022, 05:41:15 AM »
Mindful of your comment above Rudy, I thought I’d show you this method for putting your bike on the stand.
https://youtu.be/I8ayA_fDON0
There’s no reason why yours shouldn’t be the same, even though both my stands are heavily altered.
