Author Topic: Girbing Troubleshooting  (Read 1013 times)
« on: January 29, 2022, 10:58:47 PM »
Its going to be cold in the morning for my ride to coffee so I thought I should make sure my heated gear is working.
I have a Girbing vest about 5 years old, it gets a lot of use as I ride year around even if its just once a week to coffee with the the guys in the club.
The gloves were only working on an intermittent basis, one or both would cut out and the vest didn't seem to be putting out a lot of heat.
I pulled on the cable going to each cuff, you can work about 2 feet of cable out and sure enough all four wires were broken where they flex at the elbows, the break was typical of work hardened copper, pulling on the wires the insulation stretched like a rubber band. This is not the first time they have broken, last time I just shortened them a few inches and spliced back together, this time I replaced the wires with some single #18 back past the elbow. I have a different arrangement on my vest with the glove connectors mounted on a printed circuit but it would be easy to replace the cuff cables using one of the Girbing glove cables.
I also found that the cable connected to the bike was intermittent, the negative was broken off under the plastic so it would lose contact if pulled the wrong way.
I have attached a sketch of the Girbing vest wiring showing how the two circuits can be combined to operate as a single circuit.
I also show a little test box I made as a troubleshooting aid. It has a Male and Female connector so it can be hooked up at any point in the wiring.
A small 12 Volt lamp lets you know if the power is present.
An an old headlamp bulb in series indicates current is flowing, its a 60 Watt lamp so its running about 50% when its in series with the vest and barely glows for just the gloves.
The little test box is worth its weight in gold, its much easier to use than a multimeter as it has all the right connectors.
I'm sure most of you have dual channel controllers for your heated gear, I have a dual channel Bluetooth but its permanently installed o my V7III when I use the gear on the Convert or my Old Eldorado I just run flat out and turn it off once I get warm enough. If I plug the test box into a Girbing controller it will show the pulse length proportional to the setting.
« Last Edit: January 30, 2022, 04:14:28 AM by Kiwi_Roy »
Offline yogidozer
Re: Girbing Troubleshooting
« Reply #1 on: January 30, 2022, 06:51:26 AM »
Suggesting a solution to an electronic expert? OK I like playing with fire  :rolleyes:
 You didn't get any more heat by not using the dual channel controllers, right?
Is it possible the wire you replaced was a larger gauge?
Less resistance, less heat?
« Reply #2 on: January 30, 2022, 09:49:25 AM »
The wire I replaced is just the copper between elements
I'm guessing the heat loss (Voltage drop) is about the same between using a 2 channel controller and doing one channel full on.
The real heat loss was broken wire at the elbows and a disconnected wire in the adapter cable.
I will find out how good a job I did this morning, I'm riding the Convert, its alternator capacity is weak at the best of times, I keep an eye on the battery voltage and shed load if it drops below 12. Last time I rode it the Voltage stayed above 12 but I suspect because the load was shedding itself LOL.
While I dont have a controller on this bike it has a relay that I can drop out by switch or with the ignition, the trouble with Converts is they cannot be bump started.
Update:
I gave the gear a good test this morning, toasty warm.
I have to maintain at least 40 MPH in Low Ratio, 50 in High Ratio for the Convert to maintain 12.2 Volts, I'm happy with that
Thats 60 Watts for the vest, 30 Watts for a pair of gloves, headlight on 60 Watts
« Last Edit: February 01, 2022, 09:23:52 AM by Kiwi_Roy »
