Could it be that I have a worn or loose distributor drive gear ... Or a worn camchain affecting timing ... Might be clutching at straws here but running out of things to try
Fuel supply issue? Remove the fuel taps and check the filters that are mounted on the taps and fit in the bottom of the tank for blockages. Also check taps themselves for blockages and the the filters at the carbs and any other in line filters if they have been fitted.
