Author Topic: Need fork spacer material-Marzocchi  (Read 1226 times)
Offline kidsmoke
« on: March 19, 2022, 04:39:03 PM »
Jackals stock forks are marzocchi non adjustables. They use a spacer which is black PVC at 38mm OD or 1.5” I’ve got my hands on a pair of IKON progressive spring spec’d for these forks that are 3.5” shorter. I need the same material in a longer spacer to compensate. Cannot find it. Anyone addressed this issue successfully in the past?
MG makes you aware of this issue but does not sell appropriate material. Standard commercially available pvc is 1.660 diameter. Too big.
Suggestions?
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline wrbix
Re: Need fork spacer material-Marzocchi
« Reply #1 on: March 19, 2022, 04:48:01 PM »
Go to “the source for all things useful”, McMaster- Carr…. they appear to have “plastic” pipe (as well as many other materials) in ODs varying by as little as 1/16 inch.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline kidsmoke
« Reply #2 on: March 19, 2022, 05:28:35 PM »
Actually, I had started there. I thought I exhausted it pretty well, but clearly you found something I missed. I was a purchasing manager for a manufacturing job shop for years, and McMaster Carr was my end all be all. I was surprised when I couldn’t find what I needed. I’ll look again.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline kidsmoke
« Reply #3 on: March 19, 2022, 09:52:13 PM »
1" schedule 40 PVC and 1-1/2 OD SS fender washers.
1-1/2" Stainless steel sanitary .040 wall sanitary tubing
1-1/4" or 1-1/2" sink tail pieces in either chromed brass or PVC
1-1/2" OD PVC rod
I like the washer idea. Thanks
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline mechanicsavant
« Reply #4 on: March 20, 2022, 07:41:43 AM »
Uh , I’m pretty sure it’s an SS washer @ each end of PCV , not a mega stack .
Offline kidsmoke
« Reply #5 on: March 21, 2022, 11:37:07 AM »
Ha, yes, that was understood, but I do appreciate the clarification.
worked a treat. Thanks. Simple solution.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
