Author Topic: Looking for used SB clutch plate.  (Read 800 times)
Offline Pescatore
« on: April 03, 2022, 05:22:08 PM »
Hello Folks,
I am looking for a worn out small block clutch plate, part number 27084460.
I need the hub to hold the main shaft.
I don't think the plates get resurfaced, so I am hoping they are collecting dust in a dark corner.
Willing to pay.
Example:  https://www.ebay.com/itm/173890654497
Thanks,
Pescatore
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Shorty
Offline Pescatore
Re: Looking for used SB clutch plate.
« Reply #2 on: April 05, 2022, 12:50:54 PM »
Thanks for the link, Shorty.
Unfortunately, I think the V50 has a slightly different plate.
I ended up buying that Newfren plate on Ebay.  I'll try to make a jig without compromising it.
Hopefully it's a good replacement, if I ever need to replace my clutch.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #3 on: April 05, 2022, 05:01:30 PM »
The later smallblocks ('03 Breva) have a different shaft size than the earlier stuff.
I made my own shaft tool from an old clutch plate (thanks Pete Roper) plus nut tool.  That nut is very thin.  I bought a brand new 6 point Koken socket and made the crank dimensions so that the handle on the nut spanner could be clamped the the bell housing, so that it couldn't move and round the nut off.  Undid the nut by turning the spline.  That nut is a Guzzi special, at least here in NZ.  Look after it!
Offline Pescatore
« Reply #4 on: April 11, 2022, 02:04:09 PM »
Hi Muzz, I was hoping you would notice my post.  I read most, if not all your gear box posts on here, as well as Nick Webb's writeup.
I finally received the Newfren clutch plate and it fits on the shaft.  Now I am thinking of a way to attach it to a spare 1/2" ratchet socket
so I can turn the shaft while holding the nut as you describe.  I should be able to hack a 36mm wrench for that.
The clutch plate is new, so I am trying not to spoil it.
The spline nut is thin indeed.  In fact the to lip that gets punched broke off.  So I am waiting for a new nut from Italy.
I also broke the punch lip on the internal 22mm nut for the output shaft, but I have a few of those.
While doing this work (https://wildguzzi.com/forum/index.php?topic=102352.msg1811202#msg1811202), I realized there has to be a way to service the gear box
without removing the spline shaft from the clutch housing.  It seems that it is removed only to use it to hold the internal output shaft.
My dilemma now is how to go about tightening both nuts.
I read a few posts debating whether to use a torque wrench or just put some thread lock and hit it with an impact wrench.
I was able to undo both nuts with my impact wrench, so if I can't figure out a way to use the torque wrench, I might switch to the impact.
I think I will attach the gear box to the swing arm and rear tire.  Have someone sit on the tire while I torque the nut.
Maybe I'll make something to lock the internal gear to the gear box housing.    :undecided:
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
