Author Topic: Changing Headlight on Norge  (Read 1013 times)
Offline craigclu
« on: April 03, 2022, 06:41:28 PM »
I didn't spot the info I needed on a search so to save some head scratching and have what I need before I start.....  The owners manual and service manual didn't seem to spell out well.  My low beam left is out and I see it calls for an H3 which I'm familiar with from car uses.  I see that just adjusting the lights call for removing the instrument panel.  A quick look makes it appear this wouldn't be absolutely required?  Can the rubber back cover be removed and gain access to the bulb?  I see the H3's listed with the bracket and wire assembly but I wouldn't have expected needing anything more than the bulb and wouldn't have even thought about that aspect but the service manual drawing features the bracket and extension wire.  I guess I was hoping to not be removing plastic body panels, etc if not needed and would like having the right stuff ready.  If it's requiring much disassembly to get at things, I would replace both at once.  10,000 miles on my 2014 and I learned to always buy the HD versions in car duty.
He who is without oil shall cast out the first rod...”-Detonations 5:72.
Offline old head
Re: Changing Headlight on Norge
« Reply #1 on: April 03, 2022, 08:07:08 PM »
I have changed the bulb on my breva twice, I remember it was a pain to get my hand inside the bucket but I don't remember what was involved.
Adjusting the headlight was a pain also, did that once.  Seems like you have to turn a bolt inside the bucket.
wasn't terrible, just PITA.
Old Head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
« Reply #2 on: April 04, 2022, 03:31:17 AM »
It’s worth the 10 minutes that it takes to get the panel off.
Everything is easy to reach then.
