Author Topic: Hardware store grip glue?  (Read 2631 times)
Offline Bpreynolds2
« on: April 12, 2022, 11:54:40 AM »
Hey all, any recommendations for a good glue I could use for grips available from my local hardware store?  Gorilla?  Shoe Goo?
2003 California Stone
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Hardware store grip glue?
« Reply #1 on: April 12, 2022, 12:28:41 PM »
I thought super glue was the standard?
Also—any tips on removing my Oxford heated grips that have been glued with said cyanoacrylate without destroying them would be great;y appreciated. Baby’s got a new handlebar to install. Acetone? Denatured alcohol and patience?
« Last Edit: April 12, 2022, 12:29:18 PM by Dirk_S »
Offline dirtiegirtie
« Reply #2 on: April 12, 2022, 01:08:23 PM »
I use hairspray.
Goes on as a liquid - lubricates to make install/positioning easier.
Dries quickly (alcohol) and has tacky/adhesive properties once dried.
Offline Motormike
« Reply #3 on: April 12, 2022, 01:13:21 PM »
I'd stay FAR away from Super Glue.  That stuff can get everywhere and will eat paint in a second.  No matter how careful I am with it, somehow it always ends up on my fingers! :angry:  Common hairspray (which is mostly an aerosol lacquer) works well.  I've also used Goop Adhesive.  Easy to find at almost any hardware or department store.  Be careful, it too can be messy, a little goes a long way.
« Last Edit: April 12, 2022, 01:14:28 PM by Motormike »
« Reply #4 on: April 12, 2022, 01:28:58 PM »
I use hairspray.
+1
I always used hair spray too. Get it wet to slide it on easy. It is easy to clean up when you replace the grip.
Online Tom H
« Reply #5 on: April 12, 2022, 02:23:53 PM »
WD40 will also work to slide the grips on.
Offline LaMojo
« Reply #6 on: April 12, 2022, 04:19:02 PM »
How about no glue. Blast the interior of the grip with rubbing alcohol or carb cleaner and quickly slide it over the handlebar. Dries in seconds and grip stays put.
Yep. Used this method to regrip golf clubs. Works.
Offline Jack Straw
  • Laugh More, Live Longer
« Reply #7 on: April 12, 2022, 04:37:17 PM »
I've never needed grip glue on any bike with any grips.
Offline wrbix
« Reply #8 on: April 12, 2022, 04:47:03 PM »
3+ on hairspray
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline Moparnut72
« Reply #9 on: April 12, 2022, 05:22:54 PM »
One caution, heated grips will soften and loosen some glues. On a longer trip I had to get some super glue to put my throttle grip back on. Oxford supplied it with their grips but I didn't want to use it due to reasons listed above. I used a Gorilla Glue that failed, the water activated version.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline PeteS
« Reply #10 on: April 12, 2022, 05:38:13 PM »
Another vote for hairspray. The cheap old school lacquer that golf balls bounce off of. Helmet hair.
« Last Edit: April 12, 2022, 05:39:05 PM by PeteS »
Offline lucky phil
« Reply #11 on: April 12, 2022, 05:45:14 PM »
Yep, I've never used any form of glue on hand grips even race bikes. I do use a few wraps of lockwire around the grips though but I've run without that as well. So to remove the grips just snip the lock wire, stick the air gun nozzle under the outer edge of the grip and pull the trigger and slide the grip off. Installation is the reverse. Grip glue just seems messy and unnecessary.
Offline Motormike
« Reply #12 on: April 12, 2022, 06:05:40 PM »
No adhesive...hmmmm?  I've had grips loosen on more than one occasion.  Usually in the heat of summer, July and August.  Almost always just the left one, since it's over a smooth metal tube.  The throttle tube is usually ribbed to help prevent the grip from slipping.
Offline kballowe
  • - Kevin the Great -
« Reply #13 on: April 12, 2022, 06:14:03 PM »
I like the super glue gel.
Note that it could crack some windshields if too close proximity while it is still outgassing.
Offline BRG-BIRD
« Reply #14 on: April 12, 2022, 06:44:33 PM »
Another vote for hairspray  :thumb:
Offline chuck peterson
« Reply #15 on: April 12, 2022, 09:03:52 PM »
Electric contact cleaner, but you have to be fast
If it drys in place before you get it where you want it, lift the inside lip and spray some more, push w both hands real fast
To remove use large screwdriver circling the bar
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline lucky phil
« Reply #16 on: April 13, 2022, 12:28:21 AM »
It's worked for me on road bikes for 40 years and on WSB's I've prepared and IOM bikes I've prepared and worked on. Race bikes always had lockwire though. I can't ever remember any new bikes I've worked on that were glued. I recently changed the RE grips for Yamaha R1 grips and they weren't glued. Sometimes handlebar diameters aren't what they claim to be by a small margin as well.
Ciao
« Last Edit: April 13, 2022, 12:30:58 AM by lucky phil »
Offline malik
« Reply #17 on: April 13, 2022, 01:44:17 AM »
Hairspray, too. I use the cheapest I could get hold of, from the $2 Shop, lasts for ages, effective.
You wouldn't want to use it on your head, but for handgrips it's good.
« Last Edit: April 13, 2022, 01:46:37 AM by malik »
Offline Dirk_S
« Reply #18 on: April 13, 2022, 06:00:10 AM »
kk
Bingo—that’s what happened to me. I found myself spinning my clutch side grip almost as much as my throttle.
Offline Alfetta
« Reply #19 on: April 13, 2022, 07:36:39 AM »
I do not use any glue or lock wires.  I boil my grips in a pot of water and push them onto clean dry bars while hot. I have never had any loose grip issues.
i guess it's whatever works for the end user !
« Reply #20 on: April 13, 2022, 09:08:20 AM »
I just use WD-40 to remove the old ones and install the new grips. Never needed any adhesive after the drying out of the WD-40.
« Reply #21 on: April 13, 2022, 09:22:03 AM »
mountain bikers tip that has served me well is classic hair spray!  Spritz it inside, the grip slides on smoothly, but it evaporates quickly to tacky but not glued-on! Just enough grip to keep it from spinning, but easy to remove
Offline kballowe
« Reply #22 on: April 13, 2022, 09:36:29 AM »
Aqua net is the very best.  It has 33% more hold
Offline bigbikerrick
« Reply #23 on: April 13, 2022, 12:46:56 PM »
I think I have tried everything, mentioned here. I guess it depends on the grip/ handlebar individual fit. On some I have gotten away using nothing, just cleaning up both the grip and bar with alcohol. On others I have used hair spray with good results. Some I have had to use contact cement, like a 3m spray contact glue used for upholstery. There have been some grips that were stubborn, and kept twisting that I had to use super glue on, but thats my last resort option. I seem to get that stuff all over, and its messy!
Rick.
Offline 80CX100
« Reply #24 on: April 13, 2022, 02:58:16 PM »
I cannot believe no one has mentioned hair spray :shocked:
      Yea, but they're all pretty careless with their cash,,, I got mine at a real dollar $tore
       :evil:  :laugh:  :evil:
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
