Author Topic: 12 amp vs 14amp for 2007 v7  (Read 1828 times)
Offline chuck peterson
« on: May 17, 2022, 08:21:53 PM »
Interesting to be replacing a yuasa ytx14ahl-bs 12 amp battery after only 2 years
What I noticed in the maintenance book is that the battery is specified as a 14 amp.
Could this be the problem w batteries dying on smallblocks pretty frequently? 12 amp where a 14 amp battery should be?
It seemed like the charger had to be plugged in all the time. In two weeks unplugged it would be clicliclicliclic in the driveway w a no start..
All the yuasa ytx14ahl-bs are 12 amp
After lots of searching i bought an off brand, but 14 amp thru Amazon
Moto Classic
12v 14 amp
230cca
Anyone w experience in this area?
Would those two extra amps hold a charge longer/start easier? Thanks
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Re: 12 amp vs 14amp for 2007 v7
« Reply #1 on: May 17, 2022, 11:00:50 PM »
12ah versus 14ah is pretty meaningless.
You have a parasitic load it sounds like. Do you have a phone charger or anything like that wired to the battery?
« Reply #2 on: May 18, 2022, 06:33:32 AM »
The Cold Cranking Amps CCA is what turns the starter.
Is the battery 14 amps or 14 Ah which is Amp Hours.
« Reply #3 on: May 18, 2022, 09:50:48 AM »
Just the pigtail for the charger…I’d like to try the pull one fuse at a time and see if i can find the draw
14 amp hours and 230cca for $62 bucks…
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #4 on: May 18, 2022, 11:51:52 AM »
One trick is to lift the battery ground side, and pass the power through a blub, like a brake light bulb. If the bulb lights with the key off, then start pulling fuses or connections until the light goes out.
It would also help a lot to measure the charge voltage and the voltage each day as it is sitting.
« Reply #5 on: May 18, 2022, 04:56:18 PM »
Nice, thanks! I might learn something tomorrow..neat trick.!
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
