Author Topic: V700 Speedo Cable. What's this Ferrule do?  (Read 880 times)
Offline dgurovich
  • Right Foot Shift is best.
    • As the Dude Abides
« on: May 20, 2022, 07:50:22 AM »
I have a new Speedometer Cable for my V700 from MG Cycle.  The "gearbox" end needs some assembly.  There is the female adapter and a brass ferrule.  It looks like you have to strip the rubber back until the adapter fits,  but what is the ferrule for?
Danilo Gurovich
Marine City, MI
  • 1961 Matchless G12 CSR
  • 1966 Matchless G80s
  • 2019 Royal Enfield Interceptor
  • 2006 Vespa 200L
  • 2014 Vespa 300GTV
  • 1968 Moto Guzzi V700
  • 1964 Citroen ID19F Safari (yes, it's a car)
Offline Mike Tashjian
Re: V700 Speedo Cable. What's this Ferrule do?
« Reply #1 on: May 20, 2022, 08:07:37 AM »
Pictures would help.  Is this a do it yourself cable?  I have seen a few types where you have to cut them to length and then crimp on a fitting for the end you cut.  I thought most cables use a brass ring at the speedometer head to hold the cable in the meter.  Not sure what you are dealing with.
« Reply #2 on: May 20, 2022, 08:26:56 AM »
The brass ferrule clamps down on the cable when the "female adapter"/nut is tightened, keeping the cable secured in place.
The outer housing on some cables I've bought are a bit undersized and the brass ferrule won't do it's job no matter how tight the nut is. In those instances, I slip two o-rings on in place of the ferrule.
Offline dgurovich
« Reply #3 on: May 20, 2022, 09:02:29 AM »
Nailed it.  thanks.
Danilo Gurovich
Marine City, MI
  • 2006 Vespa 200L
  • 2014 Vespa 300GTV
