Author Topic: How to store a gasket?  (Read 1288 times)
Offline cappisj1
« on: June 04, 2022, 10:48:15 PM »
I feel like there is a proper way to keep the extra gasket “fresh” until I need them? Specifically valve cover, oil pan and rear end sump gaskets. Freezer, ziplock with a couple humidity things dropped in or does it not matter? Even a list of things not to do would be helpful. I have had oil pan gaskets get brittle on me before I use them.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Offline Scout63
Re: How to store a gasket?
« Reply #1 on: June 04, 2022, 10:51:03 PM »
I consider it a victory just to find the right gasket in the garage when I need it.  I store gaskets in overnight envelopes stuffed upright between boxes to keep them flat.
Ben Zehnder - Orleans, MA USA
Online nc43bsa
« Reply #2 on: June 04, 2022, 11:15:06 PM »
Don't hang them from a nail, as I have seen in countless M/C shops.
1990 MilleGT
Offline mtiberio
    • TiberioRacing
« Reply #3 on: June 05, 2022, 12:17:12 AM »
the papery ones (trans cover, eldo RD sump, etc), just soak them in water when you are about to use them. The others I have never had an issue with since I oil gaskets before using which restores flex.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #4 on: June 05, 2022, 09:14:02 AM »
All my gaskets are in a wide flat box, some 40yrs old. Only ones that get brittle are the old black stock ones. Always been in non humid environment. I use cardboard between levels. I usually order 10 at a time of whatever I need, I use them up. Head gskts I use copper coat when assembled, they are all fine.
Like Mike says, water the paper ones otherwise they don't fit. Not even new ones.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #5 on: June 05, 2022, 09:16:55 AM »
Are there easily memorable rules to the different types of gaskets in terms of applying oil/grease to them? I know some go on dry, some should be lubricated, etc.
Offline dguzzi
« Reply #6 on: June 05, 2022, 09:48:23 AM »
  Nice subject, I often wondered what might be the best way.  Mine are in the original plastic package kept flat but no other special treatment. I usually do oil them but I haven't heard of soaking in water.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
