Author Topic: '16 and Up V7 Speedo/Tach Conversion For a Stone?  (Read 4015 times)
« on: June 05, 2022, 05:29:20 PM »
Hopefully this is a simple question.
Can a (IIRR) '19 V7 Stone with the single speedo get a DIRECT swap to let's say a '16ish Speedo/Tach?
The wires to the dash I think are the same. From what I learned, it may or may not be plug and play. Or, does the ECU or the like need some fiddling?
So what do you think?
Offline agdrache
Re: '16 and Up V7 Speedo/Tach Conversion For a Stone?
« Reply #1 on: June 06, 2022, 12:27:59 PM »
I feel like I read somewhere that it was like $2000 worth of parts (and a whole bunch of work) to replace a Stone dash with a Special dash because it needed a whole new wiring harness
2018 MG V7 III Stone
2011 Suzuki TU250X
« Reply #2 on: June 06, 2022, 01:04:04 PM »
That is what I was wondering about. I wold have thought Guzzi just used the same harness for all the models and just plugged in what was needed.
Thanks,
Offline agdrache
« Reply #3 on: June 21, 2022, 11:15:03 AM »
Thanks,
Same. It's disappointing to me that it's not easy to do. When I started looking at Moto Guzzis, the V7 Special was the one that initially caught my eye, in part because of the tach, but I ultimately decided the Stone made the most sense for me. I really liked having a tach on the Honda Nighthawk 750 that I had for a few months, and the off-center speedo on the Stone always messes with me...but I'm not sure I'd like the angle/position of it with the drop bracket that GTM sells (even though I initially thought I wanted one)
2011 Suzuki TU250X
« Reply #4 on: June 21, 2022, 11:54:01 AM »
Old ways of Guzzi are gone, now you must pay Piaggio. This is what they want. Just put on aftermarket or buy a different V7. No more swapping things from model to another.
Get used to it or call the 800# and bitch at them. I got what I enjoy and it's nothing new.
Offline Jack Straw
  • Laugh More, Live Longer
« Reply #5 on: June 21, 2022, 12:07:00 PM »
Speaking on behalf of a few harmless eccentrics who own V7 Stone models I wonder exactly why anyone needs a tach on these bikes seeing as they have a rev-limiter and, on newer models, an adjustable shift light?
« Reply #6 on: June 21, 2022, 01:16:54 PM »
If I was Tom I'd get a loom from one of Marks take off bikes. I changed a loom on a Griso a few years ago, 4hrs & running perfect, just like factory. You have to do it just like factory to have those results.
« Reply #7 on: June 21, 2022, 01:30:50 PM »
The fact that they didn't make the RPMs one of the display options is pretty dumb.  The shift light does meet my needs when cruising around.
Offline Alfetta
« Reply #8 on: June 21, 2022, 02:59:02 PM »
my special has the dual clocks, and for the life of me, I don't know what it brings to the table.  personally I shift by ear,  and knowing the 70MPH is 4K revs means little to me..
and with a USB cable you can get RPM to display on the smart phone.
just my 2c
« Reply #9 on: June 21, 2022, 04:00:43 PM »
just my 2c
For me it is not about upshifting, but about cruising RPMs, and knowing what they are so I don't accidentally bog the engine accelerating when I should have downshifted first.  Easy to just accelerate and decelerate, or to keep the revs up when riding spiritedly, but eking out the best fuel economy is easier with a tach.
« Reply #10 on: June 21, 2022, 08:17:26 PM »
I was not asking to do this on one of my bikes. Don't own a V7.
I had been asked if it could be a direst swap. I did not know. I just thought that Guzzi would have used the same wiring harness between the bikes and just hooked up the connections as needed for the various models.
It's sorta sounding like it can be done, provided you use the wiring harness from the bike with a speedo/tach. But then....Is the ECU (box itself or the programing) and all other connectors the same?
Mainly, I was just curious if it would be a direct swap. Apparently not.
Thank you for your insights!!!
« Reply #11 on: June 22, 2022, 08:18:13 AM »
I very much doubt the main wiring harness is different ..That would be an expense the factory would try to avoid. A sub harness to the dash is more likely.
On the big block bikes like EV vs Jackal the same main harness was used with different sub harness to the instruments.
Someone would have to show two different part numbers on the wiring harness for me to believe they are different.
« Reply #12 on: June 22, 2022, 12:10:33 PM »
Just so you know, I looked it up. Main loom on Special(2clocks) Part# 2D000209 & on Stone(1 clock) Loom Part# 2D000332 .  Sub harnesses seem to be same numbers. this is for 17-19 V7III on both models.
Don't believe, then look it up.
Edit:   Special $650  Stone $735
« Last Edit: June 22, 2022, 02:41:46 PM by guzzisteve »
« Reply #13 on: June 22, 2022, 12:16:02 PM »
Ok, I believe, thanks for straightening me out.
Offline Chatmanx
« Reply #14 on: June 22, 2022, 06:30:53 PM »
Is the wireless MIA an option to display RPM etc with your smartphone? Probably about $500 (I think) with mounting kit.
« Reply #15 on: June 22, 2022, 07:01:33 PM »
Yes it is, but clumsy and inelegant, like a blaster vs a light saber...
... Sorry watched Obi-Wan with the kids tonight.
