Author Topic: What is the thread pitch size for oil pump shaft  (Read 1683 times)
Online NCAmother
« on: June 09, 2022, 09:26:52 PM »
Hi, I need to repair the threads on my oil pump shaft.  I know the shaft is an m8 size, but what is the thread pitch size?  Thanks
Howdy
Re: What is the thread pitch size for oil pump shaft
« Reply #1 on: June 09, 2022, 09:39:19 PM »
Standard M8 thread pitch is 1.25, the first fine will be 1.0 but it may be (though I would be surprised) is 0.75.
Take a standard M6 bolt and line it up against the M8 shaft, it the pitches lock together the M8 shaft is 1.0 pitch.
Online NCAmother
« Reply #2 on: June 09, 2022, 11:28:11 PM »
Yeah, I tried m8x1.00 and it didn’t work, I’m guessing I should go with m8x.75
Howdy
Offline lucky phil
« Reply #3 on: June 10, 2022, 12:17:32 AM »
It's an M8 x 1 on both the pumps on my bench.
Ciao
« Last Edit: June 10, 2022, 12:17:50 AM by lucky phil »
Online NCAmother
« Reply #4 on: June 10, 2022, 04:36:19 AM »
Ciao
Damn, the threads are most likely screwed.
Howdy
« Reply #5 on: June 10, 2022, 07:49:44 AM »
Pun intended?  :smiley: Probably not, though. That is a hardened shaft and unless there has been a shaved ape beating on it  :shocked: there may just be a small ding in the end that keeps the nut from starting. Take a look with a 10 power glass. Maybe a thread file? Grind a little chamfer on the end?
Offline lucky phil
« Reply #6 on: June 10, 2022, 05:26:30 PM »
And make sure it's actually a 8x1 nut because 8x1 is not the standard 8mm size nut and someone may have forced the common 8x1.25 onto the shaft.
Phil
« Last Edit: June 10, 2022, 05:27:58 PM by lucky phil »
