Author Topic: plugging a tire  (Read 2991 times)
Online jrt
plugging a tire
« on: June 18, 2022, 10:07:02 PM »
I picked up a nail in my almost-new tire- tubleess tire- right in the center.    I have a 'dynoplug' which consists of a rubber string with a brass needle end.  I guess you stick it through where the nail was and the bras tip stays inside the tire.
Anyone used these?  I'm thinking I'll just plug this one and not bother with anything else (dealership) if it keeps pressure.
If it makes any difference, I am not going to tour on this tire- I'll use it for a year then move on to a new one.
Any opinions?  Any suggestions on super-great-wonderful-foolproof tire plugs for tubeless rims?
Thanks!
JRT
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline n3303j
  • Ron Cichowski
Re: plugging a tire
« Reply #1 on: June 18, 2022, 11:08:39 PM »
Fort 9 has a video with his opinions.
https://youtu.be/Qm6fTWaj3QE
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Beowulf
Re: plugging a tire
« Reply #2 on: June 19, 2022, 01:59:24 AM »
Just had to plug my tire on the rear. I used a traditional one as compared to what you mentioned. Holding pressure well. I’m going to use slime in addition as added insurance. I think that plug will work fine but I’ve been wrong before.
So maybe slime in addition to your plan and carry on?
Offline cookiemech
Re: plugging a tire
« Reply #3 on: June 19, 2022, 04:39:00 AM »
I carry the Dynaplugs since those are easy to use on the road (also carry a compressor). If you watch the video linked above, you'll see that Ryan likes the regular "rope" type plugs commonly used on cars. Currently I have a rope plug in the rear tire of my Road King, which of course picked up a screw or nail (don't remember which) shortly after I mounted it. Tire is about worn out and no issues with the rope plug.
Re: plugging a tire
« Reply #4 on: June 19, 2022, 04:51:00 AM »
You asked.  Remove it and plug from the inside.  Good as new.
Re: plugging a tire
« Reply #5 on: June 19, 2022, 05:20:09 AM »
Sticky string is good enough for me, I even plugged a hole that had a huge staple in it, belonged to an almost new Harley, he did get a patch on it through some sort of service arrangement but it never actually leaked.
Offline Mike Tashjian
Re: plugging a tire
« Reply #6 on: June 19, 2022, 06:56:32 AM »
I have used the dyna plugs a couple of times now.  I made up a rasp to help clean and rough up the hole. I also apply glue to the rasp and the dyna plug.  They are just porous enough to leak a few pounds a week.  So I would say good for a on the road repair, but failing for the permanent repair.  I found some nice rope style I use on the cars but smaller for bicycle tires. That will be the stuff I try on my next nail puncture.
Re: plugging a tire
« Reply #7 on: June 19, 2022, 07:42:53 AM »
There should be an insertion tool with the brass pointed plug.
imghost
Online slowmover
Re: plugging a tire
« Reply #8 on: June 19, 2022, 08:01:22 AM »
I used a traditional one on a rear tire and rode it for 4500 miles until I replaced it.
Re: plugging a tire
« Reply #9 on: June 19, 2022, 08:41:38 AM »
I have used the 'gooey worms' in a lot of motorcycle tires with no problems.
I usually lube them with tire cement if I can.
Online jrt
Re: plugging a tire
« Reply #10 on: June 19, 2022, 09:23:25 AM »
Thank you all for the information!
JRT
L-720
1973 Eldorado
2020 R1250RS
Re: plugging a tire
« Reply #11 on: June 20, 2022, 06:26:36 PM »
Have a generous supply of rubber cement or contact cement.
Re: plugging a tire
« Reply #12 on: June 20, 2022, 09:23:57 PM »
I have Stop and Go plug kit.  It's done me good.  It has an installation tool that's twisted by an allen wrench.
I also carry a Slime compressor with the clamp-on chuck.  It's the only way I can get through the spokes onto the valve stem on my EV which is important since the front rim leaks pretty badly.
I have no advice to the original post.
Online jrt
Re: plugging a tire
« Reply #13 on: June 20, 2022, 09:45:46 PM »
Well, I appreciate all the information and suggestions.
I plugged it with a 'gooey worm' (nice description, Wayne).  The hardest part was reaming out the hole.  After that, it was pretty standard- coat with contact cement, insert, pull out quickly (and hope for the best).  After one day, it still seems to be holding air just fine.  No change on the gauge after 24 or so hours.
I think a Dynaplug would have worked also- the tire was pierced by- of all things- a square nail.  I have no clue how that happened!  My house was built in the early '70s.
L-720
1973 Eldorado
2020 R1250RS
Offline Kildareman
Re: plugging a tire
« Reply #14 on: June 21, 2022, 02:57:26 AM »
Never had any luck with the Mushroom type when I tried them. Sticky string works for me. Even worked on a fence post U nail - 2 punctures for the price of 1.
V85 Strada
Re: plugging a tire
« Reply #15 on: June 21, 2022, 08:13:19 AM »
Doesn't Slime have a disclaimer about max speed with it in the tire?
Re: plugging a tire
« Reply #16 on: June 21, 2022, 08:30:22 AM »
For a "slime rope" kit Neeley can't be bested.
Offline bad Chad
Re: plugging a tire
« Reply #17 on: June 23, 2022, 09:13:17 AM »
I used two dyna plugs on a puncture on our car.  First one didn’t quite seal completely so stuck in a second and it worked great.  Lasted about a year, then started two slowly leak.
1988 YX600 Radian
Offline mmcwhitehead
Re: plugging a tire
« Reply #18 on: June 23, 2022, 09:27:56 AM »
I swear by the Neeley kit!
The ropes are slimmer than most other rope kits, so they can be inserted without reaming. My understanding is that you should NEVER ream a nail or screw whole in a tire that has no steel belts... the reamer will cut the the cords adjacent to the hole in the casing and weaken the tire.
Also, if you follow the Neeley kit instructions, you'll have a knot of rope on the inside surface of the tire. This should prevent the rope from working its way out of the tire. Seems like a good idea.
2014 California Touring
1973 Eldorado w/ Velorex Sidecar
Offline Beowulf
Re: plugging a tire
« Reply #19 on: June 24, 2022, 09:17:31 PM »
. That’s a handy piece of info and of course that’s exactly what I did with mine recently. Reamed the sucker good thinking I was doing the right thing. 400 miles and holding good ( knock on wood).
