Author Topic: 1973 V7 Sport Cylinder Relining Millennium  (Read 129578 times)
Re: 1973 V7 Sport Cylinder Relining Millennium
« Reply #180 on: September 05, 2022, 12:27:46 PM »
I don't think I see the painted marks on the cam gear. There is what looks like a painted tooth and some paint on the crank gear about where the cam gear rides. The only cam gears I have seen have 2 teeth painted.
Charlie?
Offline Richiez22908
« Reply #181 on: September 05, 2022, 12:50:35 PM »
Other than just that tiny bit in two teeth I don’t see anything significant either.
Charlie?
Online cliffrod
« Reply #182 on: September 05, 2022, 01:11:40 PM »
I appreciate your understanding. Fortunately everything on this bike has come apart cleanly... so I was probably more resistant to pushing my luck this time.
Hoping it all goes together as well!
You’re doing a great job.  Speaking from personal experience, some (many?) of us could have benefited from a more cautious approach on many such things in the past.  Live and learn..  I’m very happy & impressed to see you fixing your engine properly in the beginning.  I wish I had known that I needed to do more than just address the cylinders because I would have done it before things went seriously wrong on my bike..
As conscientious as you are, the going-back-together should be fine, too.  Slow down and ask questions here whenever needed.  I think you’ll be very happy in the end, even when the end is further away than we think it will be.
« Reply #183 on: September 05, 2022, 03:24:32 PM »
Go here and scroll down. There is a picture of the paint that would have been like my Eldo and Ambo.
https://wildguzzi.com/forum/index.php?topic=99057.0
Maybe there are different ways of marking?
Edit: Look close at "Your" cam gear. In Your first pic it looks like a touch of paint about 12:30. Almost looks like a center punch mark there as well? If you look just on the crank gear, there looks to be paint about half way down on the left of the painted tooth.
Maybe those are the marks?
« Last Edit: September 05, 2022, 03:32:27 PM by Tom H »
« Reply #184 on: September 06, 2022, 10:03:56 AM »
Ok thanks... I did see a little paint here and there so will take a closer look. I'm waiting on an electric impact wrench I ordered because I could not get that gear nut loose.
« Reply #185 on: September 12, 2022, 07:00:10 AM »
Ok got the gear nut off... so before I yank the gears... considering those marks is there anything I have to remember about where they are before I remove the gears? Or will I just be using them when I put them back in?
« Reply #186 on: September 12, 2022, 07:58:27 AM »
Sorry, I haven't read the whole thread, but before I do *anything* having to do with timing, I put the left (S) cylinder on TDC ready to fire. If you have already done that.. "nevermind.."  :smiley:
« Reply #187 on: September 12, 2022, 08:21:46 AM »
Oops... crank's off already... lol. But I guess I could pop it back in and do that.
« Last Edit: September 12, 2022, 05:42:51 PM by Richiez22908 »
Offline vintagehoarder
  • Cycle Hoarders
  • Ride to Eat, Eat To Ride
    • Facebook Page
« Reply #188 on: September 13, 2022, 02:40:28 PM »
I did on my 73 and gave me great piece of mind, especially when we found this.
Cyclehoarders Garage
2021 Honda CT125 Trail Cub
2018 Triumph Tiger 800
2014 Moto Guzzi V7 Speical
2009 Vepsa GTS 250 ie
1986 Yanaha FZX700 Fazer
1981 Honda CX500 Deluxe
1973 Moto Guzzi Eldorado 850
1969 Yamaha YAS1C
LaGrange, KY
« Reply #189 on: September 15, 2022, 07:32:42 AM »
Hey thanks... but what did you do, put the crank back on? ...and what is that?
« Reply #190 on: September 15, 2022, 08:39:17 AM »
If you don't know already you will be finding out soon.  That's one of the lifters.
« Reply #191 on: September 15, 2022, 09:49:26 AM »
Delta Camshaft in Tacoma, WA can reface the lifters for ~ $5 ea.
« Reply #192 on: September 15, 2022, 08:05:11 PM »
Yeah haven't gotten the cam out yet... but will certainly check them!
Charlie, anything I need to note about the alignment of those gears and the marks before removing them? Do I need to reattach the crank and get to TDC on one side and then make note?
Thank you all again!
« Last Edit: September 15, 2022, 08:14:38 PM by Richiez22908 »
Offline redrider90
Re: 1973 V7 Sport Cylinder Relining Millenium
« Reply #193 on: September 15, 2022, 10:36:09 PM »
No no, as Charlie said, 26mm. With that said, I use the same as my axle nut size 27mm. Seems to work perfect for both.
And congrats on the family bonding over a bike!
1-1/16" socket is 0.013" less than 27mm, so the *standard* socket provides a snug fit on the metric hex.
Red 90 Mille GT
« Reply #194 on: October 09, 2022, 12:43:28 PM »
So finally all apart. Taking the crank, cam and heads to a machine shop tomorrow to get them checked, repaired as needed. None look very bad... oil pump(unless I'm missing something) looks pristine.Lifters do not... assuming these have to be replaced.
« Last Edit: October 09, 2022, 05:06:19 PM by Richiez22908 »
Offline Frenchfrog
« Reply #195 on: October 09, 2022, 03:33:05 PM »
New lifters(or resurfaced) for sure.The rest needs measuring.
« Reply #196 on: October 09, 2022, 03:35:27 PM »
Cam followers can be surface ground, crank can be miced and if need be reground, oil pump shafts and casting bores can be miced for clearance spec and you could get the cam reground to a performance spec if you choose.
« Last Edit: October 10, 2022, 04:11:04 PM by Canuck750 »
« Reply #197 on: October 09, 2022, 05:07:32 PM »
Cam followers can be surface ground, crank can be mixed and if need be reground, oil pump shafts and casting bores can be mixed for clearance spec and you could get the cam reground to a performance spec if you choose.
So take that pump apart and measure the shafts and the bores for the shafts?
Offline Frenchfrog
« Reply #198 on: October 10, 2022, 03:43:14 AM »
Yup. Measurements and method in the Guzzi workshop manual.At least they are in the 850 T 3 edition.
« Reply #199 on: October 10, 2022, 04:14:47 PM »
Yes, the shop manual for the V7 Sport lists the shaft and bore measurements / tolerances. A worn out pump, low oil pressure, will negate all the investment you have put into the bike. Most of the non filter Guzzi engines I have rebuilt had worn out oil pumps, V7 Sport, 750S, a couple Ambassadors, Eldorado, all had sloppy shafts to pump body.
« Reply #200 on: October 17, 2022, 08:01:27 AM »
Whats the best tool to measure a bore that small? Will a digital caliper fit in there?
« Last Edit: October 17, 2022, 08:22:35 AM by Richiez22908 »
Offline Frenchfrog
« Reply #201 on: October 17, 2022, 02:55:21 PM »
The manual suggests using feeler gauges if my memory is right.The impeller obviously has to be in place.
« Reply #202 on: October 18, 2022, 11:43:27 AM »
As French says; feeler gauges, I would take the oil pump to the shop that is measuring your other components, if the main and shell bearings show deposits of chrome or scoring from chrome it's likely the pump has suffered wear as well. Pumps are not cheap but neither is the effect of poor oil pressure.
One other thing to look at is the oil pressure blow off valve, probably fine but check it anyways.
I fitted a cheap oil pressure gauge to my Eldorado in place of the idiot light sensor and its kind of reassuring to see the healthy pressure the engine maintains, as low as 30 at idle then as high as 60 under load. I got another gauge that I have used for testing with a short piece of hose I have spun on other Guzzi big twins to read the oil pressure before and after rebuilds. I went to Summit racing to get the fittings for metric into the block and the adapter fitting and hose for the gauge.  It only take a couple minutes to remove the oil pressure sensor and for the gauge.
« Reply #203 on: October 18, 2022, 10:01:19 PM »
The holes the gear shafts run in can be measured with a telescopic gauge such as these:
https://www.zoro.com/mitutoyo-telescope-gage-127-19mm-155-128/i/G0970938/
and a micrometer.
The shafts and gears are measured with a micrometer also. The depth of the pump body is measured with a depth gauge.
« Reply #204 on: October 19, 2022, 08:34:12 AM »
and a micrometer.
A guy once asked me what a micrometer was and did he need one. I told him if he didn't know what it was, he definitely didn't need one.  :smiley: Harsh, but true. Take that stuff to the machine shop. There is skill involved in using mics and definitely depth mics.
« Reply #205 on: October 19, 2022, 12:06:06 PM »
That is damn good advice Chuck!
I thought I understood tolerances from 40 years in the architectural business and knowing how to read a vernier gauge from drafting by hand with a drafting machine, but getting into mechanical precision is a whole other universe and I know my capabilities to accurately read a micrometer, especialy a fine inside gauge are limited at best.
In my world the tolerances I was used to were huge in comparison, an example; a concrete floor slab will typically be specified with a flat tolerance of 1/8" in 10 feet. A vertical tolerance of a cast in place or steel structure can sound enormous,  a 15 storey apartment building I worked on was drifting 3"+ over the 15 storeys top to ground and that was well within tolerance.
« Reply #206 on: October 19, 2022, 07:06:51 PM »
Yeah I know what one is but still gonna run it down to the machine shop. Bringing them new valves and guides and clips anyway.
Thanks for the advice!
« Reply #207 on: October 20, 2022, 08:22:19 AM »
I didn't mean to say you didn't.. but.. there is a learned "feel" in precision measuring. It is *easy* to be off by a half thousandth.. or more.. without considerable practice.
« Reply #208 on: October 22, 2022, 12:29:47 PM »
Bought new valves, guides, clips and running them down to the shop for install in the heads. Apparently old weren't too bad just recommended to replace due to corrosion from sitting so may years. Gonna ru. the oil pump down as well.
My daughter and I removed all remnants of the old gaskets on everything and cleaned up all the surfaces.
I'm afraid to ask but, while waiting on the crank, heads, cam at the shop... should I open the transmission up and take a look? If so... what am I looking for? It seemed to function well.
Also... it still had a leak that appeared to come from the rear main seal, but it had been replaced and looks good(Gonna replace the bearing and have new seal so doesnt matter). But someone mentioned other things to look at inside the bell housing that could be the source of the leak instead... breaker tube? Anything else in there I should check or reseal?
Thank you all again so much! I'm in South Florida and the weather is just turning great for riding... so its time too get this thing back together!! So you'll see alot more action not his thread now till its done.
Online smdl
« Reply #209 on: October 22, 2022, 01:31:07 PM »
https://www.thisoldtractor.com/moto_guzzi_loopframe_engine_out__check_these_things.html
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
