Author Topic: Hey, Charlie..  (Read 3672 times)
Hey, Charlie..
« on: June 23, 2022, 07:31:54 AM »
Austin called me this morning, and is headed to the Virginia rally. He has what sound to me to be regulator issues on his G5, and I told him I *assumed* you would go there. If you do, could you take a regulator? He said he had called Jim Hamlin, and he doesn't think he has one.
TIA
Re: Hey, Charlie..
« Reply #1 on: June 23, 2022, 08:43:08 AM »
I have a few good used ones. He's Messaged me via Facebook, I'll get in touch with him.
Re: Hey, Charlie..
« Reply #2 on: June 23, 2022, 08:44:01 AM »
Chuck,
Can you find a similar regulator at an auto parts store?  I’ve seen that done with Loopframes in need.
Cam
Re: Hey, Charlie..
« Reply #3 on: June 23, 2022, 09:16:44 AM »
Chuck,
Cam
It's a little tougher - '70s vintage Mercedes used the same one, but it's unlikely a NAPA, Autozone, etc. will stock it.
https://www.autozone.com/batteries-starting-and-charging/voltage-regulator?filterByKeyWord=voltage+regulator&fromString=search&isIgnoreVehicle=false
« Last Edit: June 23, 2022, 09:18:25 AM by Antietam Classic Cycle »
Re: Hey, Charlie..
« Reply #4 on: June 23, 2022, 09:29:13 AM »
Thanks.. :thumb: Austin asked me if a regulator could be wired in, and I told him that was out of my experience level, but I didn't think so.
Re: Hey, Charlie..
« Reply #5 on: June 23, 2022, 03:09:58 PM »
I used an Echlin from NAPA on my '70 Ambo.  Not sure on a G5 and I don't think I'd try it.
Re: Hey, Charlie..
« Reply #6 on: June 23, 2022, 03:13:23 PM »
Totally different systems - generator vs. alternator and likely Marelli vs. Bosch. Yes, for a '70 Ambo a '61 Ford Falcon regulator works.
Re: Hey, Charlie..
« Reply #7 on: June 23, 2022, 03:22:04 PM »
The voltage on Austin's bike is going bonkers - sometimes up to 16, other times down to 13. Does sound like the regulator... isn't.
Re: Hey, Charlie..
« Reply #8 on: June 23, 2022, 06:05:38 PM »
A solid state regulator??  I haven't done the homework on what would work.
Online nc43bsa
Re: Hey, Charlie..
« Reply #9 on: June 23, 2022, 06:16:13 PM »
Could be an intermittent grounding issue.
1990 MilleGT
Re: Hey, Charlie..
« Reply #10 on: June 23, 2022, 06:17:09 PM »
That's what I use. The adjustable one from MG Cycle in particular:
https://www.mgcycle.com/index.php?main_page=product_info&cPath=37_161&products_id=1110
The one I linked to above from Autozone is s.s. as well, just non-adjustable.
I pulled the known-good solid state regulator off of my V50 III and will be taking it to the rally, along with a diode board, just in case.
Re: Hey, Charlie..
« Reply #11 on: June 23, 2022, 07:32:17 PM »
You are a good guy, Charlie.. but we all know that.  :smiley:
I put the adjustable MG cycle one on the AeroLario, and it's been solid for several years, now. He said his voltmeter was going from 15.1 to 12.5. Of course, it *could* be a ground, but I've hammered looking at that stuff regularly to him.  :smiley:
Offline AZach
Re: Hey, Charlie..
« Reply #12 on: June 24, 2022, 12:06:19 PM »
Well I think I figured it out I figured out. I like all old Guzzis carry tools under the seat, of all the things the 10 mm wrench rubbed away the coating on the back of the regulator on a couple of the contacts causing it to short out which explains why it was intermittent and going from over charge to under. Moved all the tools and it was steady. It messed something up in it though. I am still thankfully charging but it won't get up to 14.2 until I hit around 5k and with my headlight (led low draw) off and just my cellphone plugged in to the charger it drops by .4-5 volts. Before it would get up to 14 by 3k ish now 42-45 where the old gal likes to set she is only at 13.5 ish with only my phone plugged in. Before it had no affect on it really.
Also somewhere in the hills of Virginia my shift lever broke off (welded once before) luckily it was still attached and it happened going through a small town two blocks from an auto garage. Called they had a small welder 10 minutes later I was rolling away with a bubble gum covered shifter but intact haha. Found a machine shop in Floyd near the campground called them up said what was going on and they said come by I think we can get ya sorted. Literally as we speak I'm Bolting the fixed shifter back on! Guy cut away the bubble gum and tiged all the way around it for me! Should be good till I get home and I can work on bracing the shifter so this doesn't ever happen again. One of those rainy day projects I had been meaning to do but never got around to. Haha. Thanks for all the help! I'll see Charlie today sometime! Get one of the new used regs thrown in the old gal and I'll get a solid state one on order now!
Austin
Indiana Rep
'81 V1000 G5
'86 LeMans IV "200k Flood bike"
'91 CalMans "big valve Cal turned Mk4
'98 EV
'03 Cal Aluminum "mostly parts bike"
'79 Yamaha XS750 Tripple
'94 KLR650 aka "KLR from Hell"
Re: Hey, Charlie..
« Reply #13 on: June 25, 2022, 07:04:34 AM »
Glad to see you are getting it sorted, Austin. All those G5 shifters will fail..even the outrageously priced new ones at harpers. What I did was make a solid stub that closely fit the interior of the old shifter. Tigged that on the shifter assembly, then slid the arm over that with and made a couple of rosette welds to the stub. That will *fix* the infamous G5 shifter issues.
Offline AZach
Re: Hey, Charlie..
« Reply #14 on: June 25, 2022, 08:22:12 AM »
Yeah I remember when you had done yours, I had planned on doing that as well and adding a gusset on the inside but just one of those projects that kept getting out off because it hasn't been an issue and since mine had been welded before I figured it would be fine till I got around to it haha. Oh well all good now!
Austin
Indiana Rep
'81 V1000 G5
'98 EV
Re: Hey, Charlie..
« Reply #15 on: June 27, 2022, 08:39:02 AM »
What AZach was calling the "regulator" was actually the diode board. Good thing I took both with me.  :grin:
Offline kidsmoke
Re: Hey, Charlie..
« Reply #16 on: June 27, 2022, 12:45:45 PM »
Thanks for that.  :thumb:
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
czakky82
Re: Hey, Charlie..
« Reply #17 on: June 27, 2022, 01:34:38 PM »
If you want to do a T3 shifter conversion I have parts for you Azach….
Offline vintagehoarder
  • Cycle Hoarders
  • Ride to Eat, Eat To Ride
    • Facebook Page
Re: Hey, Charlie..
« Reply #18 on: June 28, 2022, 07:35:46 AM »
Sounds like an adventure.
Cyclehoarders Garage
2022 Honda CT125 Trail Cub
2018 Triumph Tiger 800
2014 Moto Guzzi V7 Speical
2009 Vepsa GTS 250 ie
1977 V1000 Convert
1969 Yamaha YAS1C
2027 Vespa GTS 310 Super
LaGrange, KY
Offline AZach
Re: Hey, Charlie..
« Reply #19 on: June 28, 2022, 10:07:51 PM »
I've not had the pleasure of working on a t3 yet or really being able to dissect one, what is the difference in shifters?
Austin
Indiana Rep
'81 V1000 G5
'98 EV
Offline AZach
Re: Hey, Charlie..
« Reply #20 on: June 28, 2022, 10:09:40 PM »
Wouldn't be a Guzzi trip without some sort of failure haha especially when traveling with a group like Job, Todd and Craig haha! But alas the old gal got me home.
Austin
Indiana Rep
'81 V1000 G5
'98 EV
czakky82
Re: Hey, Charlie..
« Reply #21 on: June 29, 2022, 08:12:54 AM »
Shorter shift throw, more rearsets (mid set), different frame lowers, different footpeg brackets.
Shoot me a PM if interested.
