Author Topic: Stupid or not? V85 wheels  (Read 1781 times)
Offline Phil/TX
« on: June 23, 2022, 12:46:08 PM »
Ok, just got my tubeless wheels for my v 85 in. My question…….is there a rubber ring that fits the rim like my KTM 790? Or do I just put new valve stems on and fit the tire. I would think there is no need for rubber ring around the rim as there are no spokes in the inner ring, all spokes are out side BMW style. Any one have the tubeless rims? Help an old guy out :drool: :drool:
"You will seldom regret what you have done, but you will always regret what you have not"
2024 V7 Stone Corsa (850)
2024 Triumph Speed 400
20 Guzzi V85TT Coast Guard (super chicken)
23 V100 S Mandello ( wing man)
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Stupid or not? V85 wheels
« Reply #1 on: June 23, 2022, 12:57:33 PM »
“Rubber ring” as in rim tape? Rim tape’s job is to protect tubes from spokes. There’s no tube, and the spokes are on the outside, so treat it like a regular ol’ cast wheel style rim inside.
And since I’m not experienced enough to be considered a wise sage, you can see on the V85TT parts fiche that there’s no rim tape to purchase:
https://www.af1racing.com/ProdImages/st3/GU312.pdf#page63
The older V85TT with regular spoked wheels do show rim tape being used:
https://www.af1racing.com/ProdImages/st3/GU30X.pdf#page61
« Last Edit: June 23, 2022, 12:57:59 PM by Dirk_S »
Offline Solorider73
« Reply #2 on: June 23, 2022, 08:41:54 PM »
I purchased mine from AF1.  They have the wheels and also a kit.  The kit includes the right angle valve stem and the plastic cover for the back wheel.
See here.
https://www.af1racing.com/oem-moto-guzzi-tubeless-rear-wheel-for-19-21-v85-af1-2b007319
Current Stable
2019 MG V7 lll Stone
2020 MG V85TT Adventure
2021 Royal Enfield Himalayan
Offline SSGG Geezer
« Reply #3 on: June 24, 2022, 10:54:51 AM »
If you plan on adding a TPMS valve stem cap, you need to go with metal valve stems as the rubber ones will tear due to the added weight of the cap sensor and internal battery.
Online Vagrant
« Reply #4 on: June 25, 2022, 08:14:00 AM »
I don't know where this .453 hole size came from. My V7III, V85 and 2001 EV all used this NAPA part 90-426 and it's a .327 hole.
Offline Roebling3
« Reply #5 on: June 27, 2022, 10:50:03 AM »
In my quest for reliability ('17 V7 iii racer), I swopped out the wire wheels for cast (for a serious chunk of $ to powder coat); plus NGK spark plug connectors & all metal fuel filter.
+ K-Tech fully adjustable fork. 4pot Brembo frt. caliper w/fully adjustable Brembo radial MC.
Two mistakes:
1 - Angled metal air fill valves (total trash material and machining), added by a trusted HD shop. Don't know the maker.
2 - From following the 'new' V7s' first published specs to the series 3, I decided a 2017 would be my last new bike. w/out telling me the wee bitch gained ~50#'s (scaled 475 w/tail rack and serious paint job). In the same interval I lost 50+#. "Weigh" too heavy for these old bones. R3~
 I lost near 50.
