Author Topic: ? Silicone "Coating" in valve covers  (Read 2942 times)
Offline Fontain25
« on: July 02, 2022, 09:06:18 AM »
        Has anyone else seen a thick coating of what appears to be silicone or something similar ? What do you think it's for? My guess would be noise reduction or stopleak. Also, what is the rivet for in the middle of the valve cover? Thank you for any input.
Re: ? Silicone "Coating" in valve covers
« Reply #1 on: July 02, 2022, 09:14:40 AM »
Definitely a lame attempt to silence the tappets.
That IS the Guzzi music!
« Reply #2 on: July 02, 2022, 10:18:10 AM »
What Cam wrote. I'd remove it as soon as possible. No idea what the rivet was all about.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #3 on: July 02, 2022, 10:33:39 AM »
…or perhaps to hide/cover up a crack?
Offline chuck peterson
« Reply #4 on: July 04, 2022, 04:33:57 AM »
On a tangent to this…
Tomb is always quite proud of a set of valve covers from a company called Blake, if I recall..
A bit taller with additional finning, the inside was indeed layered with some heat/oil resistant thick coating (rubbery)  to reduce the tappet noise..
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #5 on: July 04, 2022, 06:45:35 AM »
Yeah, those are pretty rare these days.
« Reply #6 on: July 04, 2022, 11:03:12 AM »
One issue with the Guzzi is that the valve covers stuck out there in the cold air get a lot of condensation in them.
Maybe it was an attempt to insulate the cover, and maybe reduce the condensation.
Interesting idea, but having the silicone disintegrate inside the motor would do more damage than the moisture.
No idea on the rivet in the cover.
Online John A
« Reply #7 on: July 04, 2022, 12:37:17 PM »
Maybe he used the rivet to plug a hole from a previous attempt at what he was trying to accomplish.
« Reply #8 on: July 04, 2022, 12:50:44 PM »
I would say that is as good a guess as any. I believe the "Tips" book said a feminine napkin would quiet them down.  :rolleyes:
Offline Fontain25
« Reply #9 on: July 05, 2022, 09:29:45 AM »
Thanks for your replies. Should add that valve covers are off of non-running parts motor that I purchased. Motor has cast-iron liners so I know that's something to work with. Will probably never use these valve covers , but if I do I will clean them up .
« Last Edit: July 05, 2022, 09:41:36 AM by Francois25 »
« Reply #10 on: July 05, 2022, 01:29:28 PM »
I was just going to ask if you were from IL. I used to see all kinds of stuff glued or what ever in the covers. Silicone and felt mostly. And the rivet, well, seen stuff like that before too. That was supposed to stop the ringing some would have or heard. Seen a half of stick of stick on wheel weights on top of the fins.
Offline Burkslaw
« Reply #11 on: July 05, 2022, 06:58:38 PM »
That is fossilized amber. Your Guzzi was built in the Pleistocene era. :cool:
Offline ccoli
  • What? Me Worry?
« Reply #12 on: July 06, 2022, 07:38:53 PM »
Heard about folks finding indoor/outdoor carpet glued inside of valve covers in order to quiet the valve noise.
That's not noise that's music!
Wisconsin MGNOC Rep
Offline lucky phil
« Reply #13 on: July 07, 2022, 03:21:54 AM »
Didn't you have a rocker cover porosity issue at one point Chuck?
Phil
« Reply #14 on: July 07, 2022, 05:33:30 PM »
And, they make fantastic hand warmers in the cold weather!
