I am familiar with this project with my CX, when I first purchased mine almost 20 years ago it was in sad shape. For the longest time I kept it as original but eventually it went in a different direction. When the original dash was changed, I went with the clock holder from a 1000S but it never looked right and the LM fairing didn't sit quite right under the screen.Eventually I went with an earlier clock holder and it works much better and now it has 36mm carbs, a hotter cam and a lightened flywheel and it has similar performance to my 76 Lemans. And I installed the stock wiring harness from a LM I as I was glad to be rid of the miles or wiring from the original bike. Good luck with your project.
Finally got the fairing done on my "Almost LeMans I"Will change tires and get it inspected as soon as it gets a little warmer. Hopefully there will be some fair days in March, definitely April.The plan was that the ConverT would be my daily ride but that bike just turned out a little bit to nice. It doesn't feel good parking it on the street and running in the rain as a daily driver. I don't think I will have that problem wit the Almost LeMans. Time will tell.
Yours is not an “almost Le Mans 1..” The 1’s are ” almost Le Mans 2’s..”Truth be told, yours is probably a better bike. The only time you’ll find out otherwise is if you sell it to try and pay the utilities…Until you’re chasing $$$’s, you’re better off with the 2.
The LMII looks great Klinkhammer. That and the Convert make choosing which to ride pretty difficult.
please explain .... I´m keen to learn about it.
