Author Topic: 6/32 Gear Ratio Final Drive  (Read 1319 times)
Offline Groover
    • Scooteropolis
« on: July 07, 2022, 01:19:17 PM »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: 6/32 Gear Ratio Final Drive
« Reply #1 on: July 07, 2022, 02:07:52 PM »
That was used in 89-90 or thereabouts on Cali's w/full fairing and some w/big valve models. It needs a coupler that is splined like a Vert on one side & normal splines on the other end.
A friend had one on his SP sidecar rig. Rpm was up there at speed. Would be good for the drag strip.
« Reply #2 on: July 07, 2022, 02:16:43 PM »
8/33 is 4.13:1 ratio.
7/33 is 4.71:1 ratio.
6/32 is 5.33:1 ratio.
Yep, it would be good for a Quota or some of the Calis with tall transmission gearing.
« Reply #3 on: July 07, 2022, 03:53:16 PM »
I always though it was a standard 20 spline coupler, but a driveshaft with 20 on one end and 10 on the other.
Medium:
Long:
« Reply #4 on: July 08, 2022, 09:15:20 AM »
Those shafts did not exist in the 90's.
Offline pressureangle
« Reply #5 on: July 08, 2022, 10:04:17 AM »
Shame it's not 10 spline, I'd put it on my 'Sport for those sub-90mph twisties.
Offline guzzista
« Reply #6 on: July 08, 2022, 12:16:33 PM »
I found one of those adapter sleeves with a LM project I worked on. Unfortunately the 6/32 drive was gone so I was never able to sample the difference between the 7/33 and the lower gearing in real time
Offline Groover
    • Scooteropolis
« Reply #7 on: July 08, 2022, 01:52:48 PM »
The housing part number is a little different than the older Tonti boxes, would this fit say a G5 or SP? (I'm not going for it, just curious)
The G5 housing part number is 17350305 this one is 37350305
1980 Vespa SI Moped
Offline guzzista
« Reply #8 on: July 08, 2022, 05:42:04 PM »
Don't  most 1975-2001 rear ends from T3 on  interchange if the spacer inside the drive is the correct one for  the wheel. you are using ?
