Author Topic: Stripped threads in plastic  (Read 1548 times)
Offline larrys
« on: July 11, 2022, 01:38:02 PM »
I found that the threaded holes in my right side handlebar switch are stripped. I think that the PO was a gorilla, as everything that he had touched was waaay overtightened and/or stripped.
Since the plastic is ABS, I thought that I might renew the threads by adding material to the threaded holes. ABS pipe glue is basically ABS plastic dissolved in a solvent. So I used the end of a toothpick to drool in a bunch of glue into the threaded holes, but not filling them completely. I placed the switch piece with the threaded holes down, so excess glue could run out. After letting it set for a few hours, I ran in a 2.5MM tap to chase the threads. Put the switch back on the handlebar and much to my surprise it worked! YMMV.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Stripped threads in plastic
« Reply #1 on: July 11, 2022, 01:43:15 PM »
Very nice. I'll have to keep that product in mind.
Curious--instead of setting,then re-tapping, couldn't one just squirt/smear the glue into the hole, stick the screw in, and when the glue dries, the threads are made via mold casting?
Offline berniebee
« Reply #2 on: July 11, 2022, 03:54:02 PM »
Great idea Larry!
Online ridingron
« Reply #3 on: July 11, 2022, 07:18:50 PM »
Better put some kind of grease on the threads.
Offline Don G
« Reply #4 on: July 11, 2022, 07:52:10 PM »
You could also use Helicoils.  DonG
Offline normzone
« Reply #5 on: July 11, 2022, 11:16:16 PM »
You could, but Murphy's Law indicates that you'd never get the screw out. Perhaps by using mold release, but you'd be gambling. Also the threads would be the inverse of the male screw used, when actually you'd want the female (slightly larger) thread in there.
But you knew all this already, and were just looking for someone to talk to. Me also ...
 :popcorn:
Offline lucky phil
« Reply #6 on: July 12, 2022, 12:53:48 AM »
Or in the best traditions of the backyard hacker stick a self tapper/PK/sheet metal screw in her, Heerk, poot, ding.
Phil
