Author Topic: Traveling Tools  (Read 4557 times)
Offline SmithSwede
  • I don't want a pickle
Traveling Tools
« on: July 12, 2022, 10:02:38 PM »
I’m sure this topic has been discussed before, but kindly give me your current wisdom my friends. What tools and spare parts do you think are near required to take on long, cross state trips?
Looking back on my records, the things that have stopped me were tire problems and bad spark plugs or spark caps and wires (on the Guzzi V-7).  Some stuff was just annoying and easily fixed with a screwdriver or pliers (loose parts, clutch lock nut out of adjustment, etc.). Nevertheless, I routinely packed about 15 pounds of assorted tools and spare parts for years, spark plugs, caps, feeler gauges, WD-40, screws, tubing, 3/8” socket and a bunch of sockets, etc.
Now I’m on a modern Kawasaki 900 I-4.  I’m thinking I’m ok just taking an air pump, tubeless tire repair kit, a spare master link for the drive chain, some spare fuses, some jumper wire, pliers, some baling wire and duct tape.
What’s in your tool kit?  And why?
Is this too light?  Am I tempting fate?  Or is this really all you need in a practical sense (along with a healthy credit card).
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline pehayes
Re: Traveling Tools
« Reply #1 on: July 12, 2022, 10:28:52 PM »
I wish I had all of the fuel that I wasted carting around a big bag of tools for the last 50 years.  :-(
Offline fubar guzzi
Re: Traveling Tools
« Reply #2 on: July 12, 2022, 10:48:53 PM »
     :popcorn:   Hello Swede,I too took along a full bag of tools----seems what I needed I didn't have anyway but sure as hell the Guzzi would fail anyway     :boozing:    now I ride a Jap bike + it's amazing it doesn't need anything----just put 1200 mi.on+ not so much as a burp +45 mpg,just saying !!!!    :thumb:
Online chuck peterson
Re: Traveling Tools
« Reply #3 on: July 13, 2022, 05:08:14 AM »
Spark plug caps…
For when your foot slips and the bike decides to take a nap on the pavement, snapping a cap 1500 miles from home…
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline kballowe
  • - Kevin the Great -
Re: Traveling Tools
« Reply #4 on: July 13, 2022, 07:08:39 AM »
Duct tape, tiny can of WD-40, wrench and socket set, pliers (make sure to have needle nose also) a couple of screwdrivers, spare fuses, tire plugs and compressor.  LOL - fence wire.  Chain lube for that Kawasaki.
Mastercard.
Online Ncdan
Re: Traveling Tools
« Reply #5 on: July 13, 2022, 07:52:23 AM »
Needle nose vice grips, medium size adjustable wrench, tire plug kit, jump start pack, wire, electrical tape, rubber gloves and most importantly, my leatherman tool in pocket and AAA card in wallet.
« Last Edit: July 13, 2022, 07:53:16 AM by Ncdan »
Online PJPR01
Re: Traveling Tools
« Reply #6 on: July 13, 2022, 08:31:17 AM »
A few sockets - the most common ones including the one for the rear wheel
A few metric wrenches - the most commonly used
Philips/flat head screwdriver
Adjustable wrench
Allen wrench set
Roll of electrical tape
Tire patch kit with plugs/grease
Air compressor
Pair of spark plugs and valve cover gaskets
Other than the gaskets, all fits into a nice small bag, tucked into the panniers.   If something happens beyond that, buy it on the road.
« Last Edit: July 13, 2022, 02:53:21 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline Gliderjohn
Re: Traveling Tools
« Reply #7 on: July 13, 2022, 09:37:26 AM »
Over the years I have gone from enough crap along to overhaul the motor to currently a multitool, a few critical hex wrenches, tire kit and pump, air pressure gauge and windshield cleaner.
Back in central KS
Re: Traveling Tools
« Reply #8 on: July 13, 2022, 10:08:10 AM »
Hope you keep a couple of spare relays in your tankbag.
Offline pressureangle
Re: Traveling Tools
« Reply #9 on: July 13, 2022, 10:11:14 AM »
I carry only a small set of allens, for seat removal and valve adjustment. 11mm short wrench for same. My front axle takes a spanner, so a peg socket appropriately sized in 3/8" drive. 10mm allen for rear axle. Spare plug caps (from hard experience) Spare relays, spare fuses. Pocket size screwdriver.
Anything else I may need, I'll buy at a pawn shop or Harbor Freight. If it's more serious than that out on the road, it's a proper shop or a trip home by truck.
Online AJ Huff
Re: Traveling Tools
« Reply #10 on: July 13, 2022, 10:49:48 AM »
Credit card and smart phone.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline jcctx
Re: Traveling Tools
« Reply #11 on: July 13, 2022, 01:07:40 PM »
-AJ
What he said!!
Re: Traveling Tools
« Reply #12 on: July 13, 2022, 01:18:56 PM »
Doubt the master link is needed.
On my Kawasakis all I have needed was chain lube, and tools to adjust the chain if the trip was several thousand miles.  Most of my Kawasaki touring bike were shaft or belt drive, then all I ever needed was a fuse and electric tape for a chafed wire running in the tank tunnel.  The bikes ranged from 30,000 to 60,000 miles when we parted ways so can't say what you might need beyond that.
Of course proper pre-trip maintenance was performed.
Offline Vagrant
Re: Traveling Tools
« Reply #13 on: July 13, 2022, 02:41:38 PM »
good quality 6" crescent wrench for when you knock the mirrors loose, air pump and plug kit with good needle nose, credit card. phone and the ramps in the back of the pickup truck in case the wife needs to retrieve me. But your Kawi does need the chain lube.
Offline Motormike
Re: Traveling Tools
« Reply #14 on: July 13, 2022, 02:51:35 PM »
It really depends on how far from home you ride the bike. The odds of a modern Japanese motorcycle failing to the point of stranding you on the road is infinitesimally small.  I wouldn't carry any "real" tools beyond a tire repair kit. However, if you're touring on a chain-drive motorcycle, tools to adjust the chain might be a good idea.   You are far more likely to need to repair a broken turn signal or some such plastic part after a careless drop in a parking lot rather than suffer a mechanical breakdown.  So a small role of duct tape and a few zip ties under the seat won't hurt.
Re: Traveling Tools
« Reply #15 on: July 13, 2022, 05:47:07 PM »
     :popcorn:   Hello Swede,I too took along a full bag of tools----seems what I needed I didn't have anyway but sure as hell the Guzzi would fail anyway     :boozing:    now I ride a Japanese bike + it's amazing it doesn't need anything----just put 1200 mi.on+ not so much as a burp +45 mpg,just saying !!!!    :thumb:
Fixed it for you.
Offline Scout63
Re: Traveling Tools
« Reply #16 on: July 13, 2022, 09:29:15 PM »
Around town I carry an old BMW roll up tool kit and add cotter pins, master links, a few fuses and plenty of zip ties.  On the /5 I carry a spare clutch cable zipped in place next to the original. If I were traveling longer distances I would add a good test light, spare levers, a tire plug kit and a few hundred dollars stuffed in there
Ben Zehnder - Orleans, MA USA
Offline Moparnut72
Re: Traveling Tools
« Reply #17 on: July 13, 2022, 10:00:45 PM »
The /5 tool kit was amazing. I kept it after I sold the bike. My used /6 that  replaced the /5 didn't have one.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline guzziart
Re: Traveling Tools
« Reply #18 on: July 14, 2022, 09:35:01 AM »
Nothing much in the way of tools compared to what I had to tote around when I was riding HD's.
Mostly: WW tire plug kit, pressure gauge & tiny 1st aid kit
Eldo: Plugs, caps, multi tool, elect tape, mech. wire & a thing or two of other items.
I carry roadside assist through AMA & my vehicle insurance so between that and my credit card I should be OK.  I aint changing tires or installing tubes by the roadside or major repairs out there, been there, done that and won't do it ever again.  Roadside assist will bring gas, air and tow if needed, I'm good with that.
« Last Edit: July 16, 2022, 08:15:02 AM by guzziart »
Re: Traveling Tools
« Reply #19 on: July 14, 2022, 09:50:56 AM »
This is what I carry...obvious from the photo...and why?  Because I ride a 24-year old Moto Guzzi!! :wink: :thumb:   Just also add mobile phone / credit cards and you are good to GO! :thumb: :cool:
Offline yackee
Re: Traveling Tools
« Reply #20 on: July 14, 2022, 09:54:23 AM »
Electrical tape, a few spare electrical connectors, multi-tool, Allen wrenches suitable for the valve covers, some zip ties, small spark plug wrench; points and associated bits in case the Dyna III dies, some random short bits of electrical wire. I'm not a weapons/self-defense guy, but I also started carrying a Gerber knife, just in case I break down in a bad neck of the woods. My wife makes fun of me for that.
I put in a tiny lithium starter battery that leaves plenty of room under the seat for the tools, which I keep in a small waterproof bag.
Of all the above, I can't imagine not traveling with a good multi-tool.
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Traveling Tools
« Reply #21 on: July 14, 2022, 09:54:52 AM »
Curious, JJ--why take up real estate with hose clamps if you have plastic cable ties? Can even purchase the metal ties if you're concerned with heat or need more strength.
Re: Traveling Tools
« Reply #22 on: July 14, 2022, 02:55:17 PM »
Don't confuse him.  He has his plan.   :evil:
Offline Scout63
Re: Traveling Tools
« Reply #23 on: July 14, 2022, 08:30:19 PM »
Cmon - JJ was the only one who actually unloaded and photographed his tool kit. Mine was just theoretical.
Re: Traveling Tools
« Reply #24 on: July 14, 2022, 09:21:22 PM »
The hose clamps are just probably a carry over from my years of riding "vibrating" Big Twin Harley's! :laugh: :grin: :wink: :rolleyes: :shocked: :huh:
Re: Traveling Tools
« Reply #25 on: July 14, 2022, 09:24:21 PM »
Yes...Think of McGyver.... :laugh: :grin: :wink:  You never know what you need when someone is broken down on the side of the road....
I once repaired a pair of prescription sunglasses, (so he could continue riding), for a fellow biker with "MINI-DUCT-TAPE" on a Road Trip to San Diego!!!  He would have been stranded otherwise.... :thumb: :bow:
Offline kballowe
Re: Traveling Tools
« Reply #26 on: July 15, 2022, 05:23:01 AM »
I attach the trailer to the truck, and put some $$$ in the center console for fuel, snacks, etc.
Then I hide the key somewhere and take a picture of the hiding place.
In case of a breakdown, I call around to see which one of my best friends wants to get the truck and come get me.
 :boozing: :boozing: :boozing:
Re: Traveling Tools
« Reply #27 on: July 15, 2022, 07:50:16 AM »
Yes...I have two local motorcycle friends that both have trailers...and they have been exercised on occasion over the last few years! :thumb: :bow: :cool: :boozing: :wink:
Re: Traveling Tools
« Reply #28 on: July 15, 2022, 03:00:54 PM »
You might consider replacing the front wheel fastener with a hex nut.  It's a pretty common change and requiring no special tool thereafter.
Re: Traveling Tools
« Reply #29 on: July 20, 2022, 11:36:23 AM »
Yeah that's on the long list, but who remembers when the nut is in your hand? Maybe I'll take a moment to check the size today.
