Author Topic: Does a 2007 California Vintage 1100 Use Tubed Tires?  (Read 1446 times)
Offline Castorp
« on: July 19, 2022, 07:30:50 PM »
Hi all,
Haven't been here in a while. Does anyone out there know if the 2007 California 1100 "Vintage" needs tubes in the tires? Or does this model/year have those spoked wheels that will work without tubes?
Thanks!
Bill
Offline mtwillyman
Re: Does a 2007 California Vintage 1100 Use Tubed Tires?
« Reply #1 on: July 19, 2022, 07:32:39 PM »
Tubes
Port Ludlow,WA
2003 Stone
Online Ncdan
« Reply #2 on: July 19, 2022, 07:33:48 PM »
Yes has tubes unless changed by PO.
Offline aklawok
« Reply #3 on: July 19, 2022, 11:37:01 PM »
 The CalVin all came originally as tube type, but it is common of some owners to do a tubeless conversion. look @valve stem carefully and you should be able to tell which.
2007 california vintage
Offline Castorp
« Reply #4 on: July 20, 2022, 06:50:06 AM »
Thanks so much. I am curious about how dependable the tubeless conversions are. I will research.
« Reply #5 on: July 20, 2022, 08:27:33 AM »
I used the Outex kit. Engineered by Japanese road racing dudes. However I didn't "grind my nipples" as recommended. It's worked well.     https://www.youtube.com/watch?v=ikKeVNBAmQQ
Offline s1120
« Reply #6 on: July 20, 2022, 09:56:09 AM »
Tons of posts on here about it that give a ton of background, products, tips, and tricks. I did it a few years ago on my 02 cali stone, and have been vary happy.
Paul B
Offline Castorp
« Reply #7 on: July 20, 2022, 01:10:53 PM »
Thank you for the link--and I will do further research.  I have to ask: I guess it's not easy, finding a tubeless wheel to replace the stock wheel on the Vintage? I think I read somewhere that an EV wheel wouldn't fit the vintage.
Offline John Croucher
« Reply #8 on: July 20, 2022, 02:01:25 PM »
Very satisfied with my tubeless conversion.  It take several steps and days to allow each application to cure.
Also I found that you clean up the seating surface of the tire bead of mold flash you will reduce slow leaks between rim and tire.
in two years I have not added air.
