Author Topic: Need help wiring distributor BB  (Read 2195 times)
Offline NCAmother
« on: July 29, 2022, 08:56:36 PM »
I’m moving  from my dyna III ignition back to a points ignition.   My distributor is currently just a housing for the dyna sensor plate (original points plate removed).  I’ll need to buy another distributor or rebuild the one I have. Can anyone advise me how to wire the points  distributor to the coils? I’m running two dyna 5 ohm coils.  Thanks in advance.
« Last Edit: July 29, 2022, 09:07:41 PM by NCAmother »
Howdy
Re: Need help wiring distributor BB
« Reply #1 on: July 29, 2022, 09:09:36 PM »
Red wire to right cylinder coil, green to left. Wires from "distributor" connect to the - (negative) side of the coil.
Online n3303j
  • Ron Cichowski
« Reply #2 on: July 29, 2022, 09:24:54 PM »
Any info as to who has the best points for the T3. Found a lot that were badly aligned and flimsy. Found others that the rubbing blocks wore excessively in 400 miles. I have an original Magneti Marelli set but at 80K miles they are getting a bit thin.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline centauro
« Reply #3 on: July 30, 2022, 05:58:01 AM »
If your main harness under the tank has not been messed with, you'll probably find a red and a green wire with terminals still attached that are connected to the points/condensers wires, as Charlie says above.
Val Barone
1984 1000 SP/NT (sold)
1985 Vespa PX150E
1973 Honda CB 350 Four
czakky82
« Reply #4 on: July 30, 2022, 06:46:06 AM »
The pricier ones from MGcycle held up real well for me. I find it not uncommon for new points to bed in, in the first few hundred miles. After that pretty reliable.
« Reply #5 on: July 30, 2022, 08:15:06 AM »
Plus it helps to use a dedicated point grease to lube the cam. I have a 30+ year old tube of Bosch Distributor Grease and it should last me the rest of my days. "A little dab will do ya". Since the Bosch stuff seems to be NLA, Super Lube 2 would be my second choice.
https://www.euromotoelectrics.com/product-p/cs-lubetube.htm
czakky82
« Reply #6 on: July 30, 2022, 09:12:04 AM »
Embarrassingly I’ve only ever used whatever thick grease I have around… :embarrassed:
Offline NCAmother
« Reply #8 on: July 31, 2022, 10:36:49 PM »
Thanks.  Do I use a blue/black jumper wire between coils?
Howdy
Offline moto-uno
« Reply #9 on: August 01, 2022, 12:21:32 AM »
  If you have a separate power (+) to each coil , then there's no need for a jumper . Peter
  (pm me if you want a brief explanation of ign. basics)
« Reply #10 on: August 01, 2022, 08:35:02 AM »
Yes, between the + terminals of the coils.
