Author Topic: 1984 V65C Oil Filter  (Read 1541 times)
Offline Guzikid
« on: August 07, 2022, 04:08:16 PM »
  You do-it-yourselfers.......I'm changing oil/filter on a 1984 V65C without a manual.  It looks like I will have to drop the sump pan to replace the oil filter-correct ?  Anything else I need to know ?  The Kid
Re: 1984 V65C Oil Filter
« Reply #1 on: August 07, 2022, 04:10:26 PM »
No, there's a bolt with 13 mm hex head that's removed, then the filter cover comes off.
Manual: https://www.thisoldtractor.com/mg_manuals/workshop_manual_v35-ii_v50-iii_v35-imola_v50-monza_v35c_v50c_v65_v65sp_en.pdf
« Last Edit: August 07, 2022, 04:14:20 PM by Antietam Classic Cycle »
Offline pehayes
« Reply #2 on: August 07, 2022, 04:14:51 PM »
One bolt.  Cover plate drops off the bottom and the filter comes out with it.  Careful with the perimeter o-ring in the cover plate.  Careful with the vertical orientation of the filter and its attached spring.  IIRC, the sump has TWO drain plugs; one forward, one aft.  Remove both for a complete drain.  Be VERY careful reinstalling the drain plugs. Quite easy to strip out those aluminum threads.  Doesn't take much torque.
Offline huub
« Reply #3 on: August 08, 2022, 01:45:55 AM »
compare the old and new filters , they exist in different length for different models.
if you fit the wrong one , it wont filter.
Offline Guzikid
« Reply #4 on: August 11, 2022, 10:09:13 PM »
  Thanks to you all for the replies. You're the greatest when a guy needs help !!!  The Kid   :thumb:
