Author Topic: Harper's Outsider on a G5  (Read 1686 times)
Offline life member
  • Been riding since 1958
« on: August 15, 2022, 11:59:34 AM »
Does Harper's Outsider increase oil capacity on a G5. The dip stick has 3 different marks. Is the standard 3 quarts sufficient?
Does a Harper's Outsider on a G5 increase oil capacity? There are three different marks on the dip sticks. Is 3 quarts of Amsoil Motorcycle oil sufficient?
Offline bigbikerrick
Re: Harper's Outsider on a G5
« Reply #1 on: August 15, 2022, 12:14:10 PM »
My 98 V 11 EV has a Harpers outsider, and I use 3 quarts of oil at oil changes.
Rick
Offline life member
« Reply #2 on: August 15, 2022, 12:41:34 PM »
Thanks for your reply.
Offline TOMB
« Reply #3 on: August 15, 2022, 09:11:51 PM »
I have an early outsider on my Convert, which means the crankcase is the same as a G5, T3, CX100 etc.
Takes the same amount of oil as stock. You are not adding a space to increase the oil capacity, you are increasing the air space above the oil to at least prevent oil churn in the crankcase. 3 quarts is the correct amount for an oil change BUT the amount is more when you change the filter and have to refill the oil passages and the filter, (maybe 3 1/4 qt +-)
As a side note, the stock dipstick will now indicate the oil is at the wrong level. Ie. the lower mark on the originals IS NOW THE NEW FULL MARK so the problem is easily solved, I purchased the dipstick for a Cali 11 as it had a Guzzi spacer from the factory and the factory also changed the dipstick to indicate the new marks
Zoom in on the pic to see my installation
TOMB
« Last Edit: August 15, 2022, 09:16:41 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
