Author Topic: ngk plugs discontinued (updated)  (Read 5532 times)
Offline amamet
« on: August 17, 2022, 01:20:25 PM »
since the bp6es plugs are discontinued I read to just get bpr6es plugs, I was wondering if my ngk red racing caps and wires are still good to use.  I read that resistor plugs should NOT be used with resistor caps?  this is all too confusing :)
« Last Edit: August 18, 2022, 07:05:37 AM by amamet »
Online PeteS
Re: ngk plugs discontinued
« Reply #1 on: August 17, 2022, 01:41:17 PM »
What is the ignition system? You don’t need resistor anything with points. Resistor plugs were introduced to reduce RF interference. Noise on your radio. Some electronic ignitions may specify them as well.
« Last Edit: August 17, 2022, 01:41:38 PM by PeteS »
Offline BMCMOTO
Re: ngk plugs discontinued (updated)
« Reply #2 on: August 17, 2022, 01:51:37 PM »
Won't make a whit of difference. Resistor plugs and caps work just fine in combination with points or electronic ignition systems. YMMV!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Mike Tashjian
« Reply #3 on: August 17, 2022, 01:52:30 PM »
Resistor plugs should not be used with resistor caps.  Total resistance will be too high.  The right amount of resistance gives a better spark at the right time.
Offline amamet
« Reply #4 on: August 17, 2022, 01:59:39 PM »
just got off the phone with ngk tech, was told don't use restistor caps with resistor plugs, period.  he said to with to non-resistor caps or find nos plugs if I want to use ngk.  he mentioned everyone will be doing the same since non resistor plugs are "old tech"
Online TOMB
« Reply #5 on: August 17, 2022, 03:26:31 PM »
I switched over to Nippon Denso plugs because of NGK stopped making the BP6ES non resister plug.
I can say that the ND plugs offer in my case a better running bike so give then a try
NGK BP6ES equals the Nippon Denso W20EP-U Both are non-resister
side note ---I'm using the 5 ohm Bosch resister caps, no issues , if you need resister caps NGK still makes them
TOMB
« Last Edit: August 17, 2022, 03:30:37 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline moto-uno
« Reply #6 on: August 17, 2022, 04:12:58 PM »
 ^  I think you meant to say "5K ohm" .  Peter
« Reply #7 on: August 17, 2022, 04:14:28 PM »
TOMB
Same thing here. The first time I started my V50 III during it's "resurrection" it didn't go so well. It would only run on one cylinder, checked and rechecked everything. New (genuine) NGK BP7ES plugs. Tried a set of new (genuine) NGK BP6ES I had - same thing. Tried a pair of Denso W22EP-U - it started on both cylinders and ran very well. I've been using them ever since.
Offline sib
« Reply #8 on: August 17, 2022, 05:05:01 PM »
At least as far back as 2013 when I got my first V7, the specified plugs had resistors and the caps also had resistors.  If NGK thinks they shouldn't be used together, they didn't tell Moto Guzzi.  I've never had any kind of ignition problems with any of my 3 V7s, so I'm not losing any sleep over the issue.
Also, although resistors were first used to lower radio interference, I wouldn't be surprised if they also prevent interference with all the electronic devices we use these days, including computerized fuel injection systems.
« Last Edit: August 17, 2022, 05:08:55 PM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline BMCMOTO
« Reply #9 on: August 17, 2022, 05:47:08 PM »
Resistor plugs actually provide spark at greater energy because they hold off spark discharge until there is enough to overcome the resistance and to jump the plug gap. If you had a SunScope for tuning you could see it in the spark voltage on the screen, I have. Resistor plugs have been used with resistor caps and resistor wires since the 1960s, well before the advent of electronic ignition and fuel injection in automotive applications. Many Guzzi and other bikes came from the factory with resistor caps and plugs. This is really a non issue. But think what you will.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #10 on: August 17, 2022, 06:44:37 PM »
Where do you find Nippon Denso W20EP-U plugs?
« Reply #11 on: August 17, 2022, 06:47:53 PM »
I have them ordered through NAPA and other parts stores, also buy them on Amazon.
Offline Dimples
« Reply #12 on: August 17, 2022, 08:46:26 PM »
Should the Denso pre-set gap be modified?
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
« Reply #13 on: August 17, 2022, 09:08:15 PM »
Yes. On their website they specify .025" gap for the W20EP-U and the W22EP-U when used in older Guzzi applications.
« Reply #14 on: August 17, 2022, 10:10:56 PM »
2004 EVT. From factory, resistor caps and plugs.
NGK does not appear to make a 0 resistance cap in the LB-XX-YY style. Lowest is LB01EP that I can find, again, at least in that style.
Offline mtiberio
    • TiberioRacing
« Reply #15 on: August 18, 2022, 04:55:27 AM »
All I know is that Eraldo Ferracci would insist on using those OEM metal clad spark plug caps (over brownish phenolic looking innards) on the 851 Ducatis. And FWIW, Dr John once told me by running .025 or .028" gaps I was losing torque. He said use .035. YMMV...
What I'll never understand is how you can have ignition wires with a core of material that would not appear to be of a conducting material (silicon core, plastic looking shite).
« Last Edit: August 18, 2022, 04:57:10 AM by mtiberio »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Online Bulldog9
« Reply #16 on: August 18, 2022, 05:30:19 AM »
My grandfather who was a NYC cop spent the last few years working in a NYPD garage as a mechanic and supervisor rather than a desk job after getting hurt while serving as a motorcycle officer in upper Manhattan.  He was one of the lucky few to ride the old Indian police bikes in the 50's and 60's.
Anyhow, your recalling Dr. John reminded me of a trick he taught me back when I was a kid, that increasing plug gap on an air cooled engine or high powered motor would result in more power and torque, but you had to have a healthy fuel and ignition system, or you would hobble the motor. He was also a fanatic about indexing the plugs to get as ideal and equal combustion as possible. Man I miss him.
I prefer the R plugs to non R plugs with or without R caps. They result in a cleaner spark (as was stated earlier) due to the resistor.
Use what makes you most comfortable.  I've had similar performance from ND and NGK plugs, but prefer old school copper NGK's or BOSCH to just about anything.
MGNOC#23231
Offline Ncdan
« Reply #17 on: August 18, 2022, 07:33:41 AM »
Would you possibly have any pictures of your Grandfather on a police bike.
I collect old Motor Cop photos?
Sorry for the thread drift guys.
Offline amamet
« Reply #18 on: August 18, 2022, 10:45:05 AM »
I see on the Denso cross reference chart, there is a w20ep, w20ep-u and a w20ex-u for the ngk bp6es. anyone no the difference? removable terminal vs fixed?
thx
allen
« Reply #19 on: August 18, 2022, 11:14:53 AM »
I just purchased a pair a few months ago.
replacement for BP6ES
NGK 7131 BPR6ES Nickel Spark Plug
SKU #BPR6ES
ITEM #NGK7131
Offline kidsmoke
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline amamet
« Reply #21 on: August 18, 2022, 02:51:21 PM »
Yah saw that but balked at $10 a p;lug
« Reply #22 on: August 18, 2022, 03:27:27 PM »
Shop around a bit:
https://www.napaonline.com/en/p/NGK4007
Note that on the 4007, the terminal on top is non-removable.
Offline izzuG
« Reply #23 on: August 18, 2022, 03:48:26 PM »
My local parts store still has the NGK 4007 in stock, perhaps I should be buying up what he has before they are gone?
« Reply #24 on: August 18, 2022, 03:52:46 PM »
Thanks I will check with NAPA
Offline kidsmoke
« Reply #25 on: August 18, 2022, 03:54:36 PM »
Heard that! and of course shortly after ordering I read this.... (93 and up Digiplex entry) Guzziology
Supported by others comments here.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #26 on: August 18, 2022, 04:26:00 PM »
^^^^Kip.. as my favorite philosopher Babe the Pig says.. "Because that is the way life is."  :smiley:
« Reply #27 on: August 18, 2022, 04:28:12 PM »
$10 for $ 2 plug?  I'm going to get some emery cloth a pocket knife.
« Reply #28 on: August 18, 2022, 04:33:24 PM »
I have an aircraft spark plug cleaner/tester that I've made an insert to test 14mm plugs. Other than finding an occasional bad plug out of the box (Champion mower plugs) it's kind of useless on a $2 plug. It's kind of handy on a $50 aircraft plug, though.  :smiley:
Online PeteS
« Reply #29 on: August 18, 2022, 05:19:56 PM »
The conductor is carbon. So you have 5k ohm plug caps, 5k plugs and many K (????) ohm wire.
Its gotta work, right.
