Why are you bothering with the rotor ? 99 times out of 80 it's the stator and that is easy peasey , no special tools ! Unless summer lasts forever where you're at !
The "whole job" is correcting the problem no ? Spend your time riding it and change the rotor (if you must) ,when it's snowing out . Peter
Hey Dirk there is also an ebay seller who makes them... I dont have a link or any further info, but you can prob find it... thats where I got a puller for my v-65.
Look for posts by Kiwi Roy or me from a couple of years back.Just the POS stator fails. As you will see by the 4 foot of lead on it I think it came off a scooter straight from China. FYI , as I recall Guzzi wanted $600 for the package with the rotor and it was the only way they sold it. Pricks wouldn't warantee mine as the far from perfect PADS said it was good. There is a screw up on the top of the frame that is only accesable by a ball allen wrench. Just open it up with a drill. The screws that hold the stator in are locktited. Heat them and remove them one at a time. The stator comes off easily. Kiwi and I didn't touch the rotor but it looked tappered to me. Make sure you have a new gasket and hot oil pruff silicone for the hole the cord passes through. Oh, and aa lot of beer.
Oh, and a lot of beer.
Just to be clear. No one replaces the rotor. Unless physically damaged they RARAELY go bad.** That is all **
‘People don’t normally do it’ — I get that, and I got it before I made the post. But nobody’s told me why I shouldn’t do it. Is it easy to cause damage to the shaft, even if I use the correct tool? Can I easily damage something else? From what I’ve read and seen on other web pages outside of WG, stators often come without the rotor. Since I will have a brand new rotor, why not?
But WHY DO IT if it's not necessary?So yeah, that's the why. Then there's the fact that you need to buy more tools to do it, why spend that money if you don't have to?
Time, space, and knowledge are big resource factors as to why.I don’t know what all can go wrong with rotors. I’ve read that the internal magnets can sometimes be an issue. A good follow-up question is—How do I know if a rotor is damaged? Can the magnets become an issue within the rotor and I might not see it, or is a damaged rotor always something that will reveal itself?The new rotor’s there, and I live in a small apartment. I can only keep so much. I just decided to keep my extra cylinder heads, but I can’t make that same decision with everything, so I’d rather throw on the new rotor now than consider tossing it.Not having the garage means I have to be selective and efficient with my work time. Sure, I can cut the work down by not doing it, but if I have a chance to learn AND have a new part on, then I see it as a win. True, the extra cost is there in the tools, around $40…but maybe I can also rent. Maybe.Anyway, the new stator and rotor just arrived. As Vagrant showed in his experience, there’s a minor amount of wear, possibly from how the unit comes shipped. Pics attached:
