Author Topic: Dyna Mini Coil wiring.  (Read 1011 times)
Offline Scout63
« on: September 06, 2022, 12:23:24 PM »
I ordered a Sachse ignition system and a dual output Dyna mini coil.  I’m replacing the stock system on my 1978 Ducati bevel engine which doesn’t use coils.  Here is the coil I bought from Sachse in Germany, so I assume it is right:
 https://www.dynaonline.com/dyna-igntion-coil-mini-series-dual-output-3ohm-dual-plug-single-fire-dc1-3/
The coil only has one positive and one negative terminal.  Since the ignition system is wasted spark, I assume that I can wire 12v to the + terminal and both trigger wires to the negative terminal.  Am I off base here?  Thanks, Ben
Ben Zehnder - Orleans, MA USA
