Author Topic: Stelvio 1200 - broken gearbox output shaft  (Read 8402 times)
Offline guzzdi
« on: September 22, 2022, 04:33:55 PM »
When I was riding steep uphill on forest road, my bike suddenly lost traction. The engine worked fine, but no power goes to rear wheel on any of gears. Clearly major failure in a middle of nowhere :)
I called friends with off road trailer and we succeed to evacuate the bike.
At home we started to diagnose and first thought about failed clutch or final drive. We took out final drive (just as it’s easier) and realized that cardan shaft is not spinning (with engine running in a gear). We took out cardan and to the biggest surprise found the problem - the very end of gearbox output shaft broke from the gear shaft. Like somebody cut it wit a laser!!
I never experienced or saw something like that on any motorcycle in my life (I owned 6-7 during many years).
Did anybody hear or read about such failures and any reason (besides manufacturing defect) it may happen?
I’m thinking that replacing whole gearbox (but used on eBay?) is the best possible option. The alternative is to search for output shaft only and take apart gear box which sounds scary to the degree and probably not much cheaper at the end.
Any collective thoughts?
And the question - are gearboxes all same/identical for different years Stelvio 1200 4V? What about identicality between 4V 8V NTX etc? Just want to be sure which one to look on eBay.
Thx
Attached pictures of the broken part
« Last Edit: September 22, 2022, 04:42:51 PM by guzzdi »
Offline lucian
Re: Stelvio 1200 - broken gearbox output shaft
« Reply #1 on: September 22, 2022, 05:16:22 PM »
Damn . I would say Moto Guzzi owes you a new shaft. I would contact them . It must be a manufacturing defect.
« Reply #2 on: September 22, 2022, 06:19:56 PM »
See p.m.
Offline guzzdi
« Reply #3 on: September 23, 2022, 01:33:39 AM »
Offline guzzdi
« Reply #4 on: September 23, 2022, 02:01:29 AM »
The bike is Stelvio 1200 4V 2008.
I really doubt they will treat as "manufacturing defect" (though it really is)
Unless there is a good contact somewhere in corporate who can provide an exception authorization for parts and work to the local dealer/service center to fix it :)
Offline tris
« Reply #5 on: September 23, 2022, 01:31:21 PM »
I'd  love to put that in the hands of one of our metallurgists and see if they could identify the failure mode.
If a lab inspection is a possibility, don't  touch the fracture surface and don't put it back on the remains of the shaft. They can tell loads by just looking under a microscope
It could be a manufacturing defect,  but might be something else entirely.
1993 TW125 "POS" - Resting
Offline guzzdi
« Reply #6 on: September 23, 2022, 03:46:29 PM »
Tris,
I don’t have here in Seattle access to such level metallurgists :)
Besides that, I cannot even imagine what are possible any other reasons except manufacturing defect? I was single on a bike, going uphill gravel road, no luggage, on a second gear about 20 km/h.
Uphill steep, but I wouldn’t think of it as something extraordinary from a bike load perspective.
And what is a point to “prove” manufacturing defect? The bike is out of warranty anyhow…
Cheers
Offline tris
« Reply #7 on: September 23, 2022, 03:59:11 PM »
Just idle curiosity,  as its an unexpected failure, and  us Mech Es are curious about such things
But, I agree, wouldn't change anything.
Offline guzzdi
« Reply #8 on: February 02, 2023, 09:32:52 PM »
Hello,
Just wanted to provide an update.
With the help of Muzz and his friend, I was able to handle it in a proper way - replacing the gearbox with a broken output shaft with the used gearbox.
Not an easy, but very challenging and interesting task.
First, had to remove the engine with gearbox from a bike, or more accurately would probably say "remove the bike from and engine" :)
Some pictures:
Now ready to remove the engine:
2018 brz 0 60
And separate gearbox from the engine:
and put the "new" (used) gearbox back on the engine - I put a small broken part of output shaft next to the "new" output shaft of gearbox for comparison and show where it belonged:
And put everything back on the bike:
Out of curiosity, I disassembled old gearbox completely, so wanted to show all components of this piece of enegineering:
And here is the failed part to blame fro all this work - output shaft with a broken piece. If somebody wanted to examine it metallurgically to find "why it broke" - just pay shipment and and I can ship  :grin:
geojson spec
To summarize - challenging, but doable task of replacing a gearbox. The hardest part of the job is to remove engine from the bike - I put a bike jack with large flat surface on top under the engine and pulled the bike slowly up maneuvering through the frame structure.
Using the opportunity, I also checked all swingarm, wishbone, etc bearings. Thankfully they were not "deserted" like in some pictures I saw on this forum, so I just cleaned, re-greased and put it all back.
The bike is running great!
Thanks all who helped with advises.
Safe rides!
« Reply #9 on: February 03, 2023, 08:40:50 PM »
How was that breather plate on front cover left side? Hang you up? PIA every time I do one. Book pays around 10hrs.
Offline guzzdi
« Reply #10 on: February 03, 2023, 09:39:26 PM »
This one #2
Or which plate do you mean?
Offline tris
« Reply #11 on: February 04, 2023, 03:40:19 AM »
 :shocked:
Quote from: guzzdi
geojson spec
If you can get a couple of good pictures of both the fracture surfaces I can show them to one of our metallurgists
Can't do the lab work, but obvious stuff they'll spot and interpret from the pictures
« Reply #12 on: February 04, 2023, 08:04:06 AM »
This one #2
No, the cover plate over square hole on LH side of front timing chest. Behind the LH upper frame mount.
2V models have a breather hose going there.
« Last Edit: February 04, 2023, 08:54:41 AM by guzzisteve »
« Reply #13 on: February 05, 2023, 03:16:28 PM »
Good to see you got it all sussed Guzzdi. :thumb:
Friend's blood is worth bottling! :grin:
Offline Huzo
« Reply #14 on: February 05, 2023, 03:24:44 PM »
Is it just me, or do Stelvios have a face like a slapped arse…
« Last Edit: February 05, 2023, 03:34:59 PM by Huzo »
Offline dguzzi
« Reply #15 on: February 05, 2023, 03:55:38 PM »
Agree!
  Also looks like you should not do burnouts or wheelies!!
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline guzzdi
« Reply #16 on: February 05, 2023, 04:23:14 PM »
Hmm, I don't understand which plate at that location you mean (or my bike 4V doest have it?). I have there this hose you mentioned, if I understood the location you meant.
Offline guzzdi
« Reply #17 on: February 05, 2023, 04:29:49 PM »
Thanks, Muzz! And yes, I'm very grateful to the friend (and to you connecting me to :grin:)!
« Reply #18 on: February 05, 2023, 04:56:31 PM »
Yes, 8V has a plate to take off to get motor out, behind 10mm allen goes into motor in front of cyl.
Paul_Tim
« Reply #19 on: February 06, 2023, 04:30:35 AM »
Early models have a deep plate held by two bolts , one of which is impossible to access with the motor in the frame and which makes motor removal/installation a pita. I believe later models have either a much thinner plate or it's blanked off thus making motor movement a lot easier.
Offline GMies
« Reply #20 on: February 06, 2023, 05:08:15 AM »
Tris,
Cheers
“Besides that, I cannot even imagine what are possible any other reasons except manufacturing defect?”
You are driving at too low an engine speed?
MG Breva 750 2004
Aprilia Atlantic 500 2003
Offline guzzdi
« Reply #21 on: February 06, 2023, 03:19:39 PM »
:shocked:
Tris,
Not at home now.  I'll try to take the better quality close-up picture(s) of both parts (the shaft itself and small broken piece) sides in couple of days, when I'm back.
Meantime, attaching a couple I have on my phone now from small piece:
1) with a focus on a center of the broken small part
2) with a focus on an edge of the broken small part
Offline guzzdi
« Reply #22 on: February 06, 2023, 03:32:46 PM »
I don't consider 20 mph on a second gear uphill as "too low an engine speed".. Especially on a bike like that, which was "derived' from Griso/Breva as an "adventure tourer and reportedly has been optimized for an improved torque curve.
And in any case, whatever engine speed and/or gear was (even if a hypothetical rider didn't choose correctly), the shaft not supposed to break like that...
Offline Alfetta
« Reply #23 on: February 06, 2023, 04:24:17 PM »
The use of splines for an off-road machines is a bit troubling in my mind.
If the splines are not "pressed" together then there is an amount of clearance that will allow torque reversals to occur when the tire suddenly gains or looses traction.  Over time the impacts imparted by the torque reversal will fatigue the metal, especially if the is any small imperfection present. (machining or base material)
I did see a small dark spot on the broken shaft end,  but I cant see I this is an inclusion of a spot of debris.
I could also see metal migration on the sides of several splines, and that would indicate to me that the clearances are even larger than the original slip fit values.
Offline tris
« Reply #24 on: February 07, 2023, 12:24:31 AM »
From these shots it looks like the surfaces have spun on each other  - which is not a huge surprise I guess
Problem with that is that all the stuff that gets the metal men excited is  lost.
Still let's see what we can see once GD gets some nice photos square on
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #25 on: February 07, 2023, 03:45:56 PM »
I had the same a few years ago with a 2008 stelvio, could be my pictures. Mine broke when I was using no power, rolling down a trafic light. Bought a new shaft and build it in, did change the clutch to a new one to have a light clutch
Paul
Daytona 1225, Stelvio 1151
Offline guzzdi
« Reply #26 on: February 08, 2023, 06:24:59 PM »
At least now I know I'm not that special  :grin:
Since September when it happened, I posted here and couple of other places and everybody everywhere told that they not only never seen, but never heard of something like that.
To be fair, I also didn't see and didn't hear of similar, not only on Guzzi, but on any bike  :grin:
I also wanted to replace the shaft itself, but ordering a new one from europe was a wait of 2-3 months, as estimated by a couple of dealers I UK and Italy I requested a quote.
Also realized from the quotes that new shaft cost + shipping is the same (actually even little higher) than buying used gearbox I found.
Thanks for sharing your case.
« Reply #27 on: February 08, 2023, 07:21:13 PM »
On the plus side , if you’re not breaking parts, you’re not putting out enough power…. :rolleyes:
« Reply #28 on: February 12, 2023, 09:01:29 AM »
My 2009 had that goofy breather plate. No way you could simply drop the motor from the frame. And no way to unscrew the plate with the frame in the way.
It took a lot of wiggling and cursing.
