Author Topic: Changing to Neutral at a Stop Light?  (Read 9923 times)
Re: Changing to Neutral at a Stop Light?
« Reply #60 on: May 29, 2024, 07:40:45 PM »
You are applying the pressure to compress the springs against the pockets in the flywheel. Flywheel presses on the crankshaft. Crankshaft absorbs the thrust.
Ahh yes.
By disengaging, you are (correctly) saying that the lever is in…
Thanks.
Offline Dr. Enzo Toma
« Reply #61 on: May 29, 2024, 07:42:56 PM »
I had the clutch cable snap while waiting at a red light on my Cagiva Tamanaco. I nearly dropped the bike from the shock of it, but the bike just stalled and I pushed it through the intersection and off to the side once the light changed.
My experience riding with Italians is that they don't stop and wait at stop lights anyway. They stop, look both ways, and continue through lol
I keep any bike, even dry clutch Ducatis, in gear at a light unless I expect it to be a long stop (construction, train) or once I see the vehicle behind me has stopped and provided some assurance I won't be run over from behind.
Offline Air-Cooled
« Reply #62 on: May 29, 2024, 08:16:45 PM »
As one person already pointed out, it can sometimes be challenging to find neutral when the engine is running (on my 2016 V7 II it is).  Engine off no problem. Do I want to fiddle around endlessly at a stop light looking for neutral? No. Do I want to shut the bike off at a stop light? No. So if it doesn't flip into neutral after one or two tries, I just leave the clutch pulled in. Not a problem.
1973 Moto Guzzi V7 Sport, 2016 Moto Guzzi Stornello, 2023 Vespa Primavera
« Reply #63 on: May 29, 2024, 08:43:02 PM »
Why not grab neutral while still in motion ? (5 mph or so…)
I used to do that with my Darmah.
« Reply #64 on: May 29, 2024, 08:47:51 PM »
really?
neutral saves the clutch,  being in gear gives a quick out in case there's someone running over you.
Perhaps neutral and your eyes in the mirrors and a lane to proceed?
 :huh:
Offline n3303j
  • Ron Cichowski
« Reply #65 on: May 29, 2024, 10:33:03 PM »
Neutral doesn't save the clutch,  just the throw out bearings (and a bit of your wrist).
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline mondtster
« Reply #66 on: May 29, 2024, 11:19:59 PM »
No one has mentioned that disengaging the clutch places the thrust bearing at the front of the crankshaft under load. Wonder how long that bearing lasts?
Having owned several vehicles with engines that have had weak thrust bearings, this is the #1 reason why I always put my manual transmission cars and motorcycles in neutral while waiting at a stop light.
« Reply #67 on: May 30, 2024, 06:47:41 AM »
Why not fix the actual problem - i.e. adjust the clutch so you can find Neutral.
I mean that's been my solution on plenty of smallblocks I've ridden, even demo bikes from two different dealers.
The factory spec is just a little too loose and if there's any sign of it not quite fully releasing when the lever hits the grip it can be, as you say, challenging (mostly when hot, but if really out cold too).
Offline Bulldog9
« Reply #68 on: May 30, 2024, 08:08:28 AM »
Enter the Hendon Shuffle
Hendon is where the police motorcyclists are trained in the UK and I believe that this is still current
Essentially when stopped you have the bike out of gear and held stationary with the foot brake and left foot on the ground
To pull away you hold the bike with the hard brake, switch feet (hence the shuffle) to engage the gear and pull away
https://longrider.co.uk/blog/2012/08/25/starting-stopping-and-thoughts-on-the-hendon-shuffle/
That's what I do, didn't know it had a 'name'
MGNOC#23231
Online Moparnut72
« Reply #69 on: May 30, 2024, 09:34:41 AM »
I didn't know there was a name for what I do most of the time. If I am only going to be at the light for a few seconds I leave it in gear. All depends on what is or is not behind me.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline Frenchfrog
« Reply #70 on: May 30, 2024, 12:41:08 PM »
No, that's not entirely correct.
The plates themselves might not get any extra wear but the splines in the flywheel and clutch hub will be getting banged around far more than if in neutral.Given the pita to change these parts and the expense....
Offline n3303j
  • Ron Cichowski
« Reply #71 on: May 30, 2024, 05:33:59 PM »
Neutral (with clutch released) saves the splines in the flywheel. I still hear the transmission input splines and the gears in the box racking back and forth against the power pulses.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #72 on: May 30, 2024, 05:38:24 PM »
If I ever have to put a clutch in my Norge, I’ll give it a new shaft as well.
« Reply #73 on: May 31, 2024, 10:55:18 AM »
On a small block I go to neutral because the crankshaft thrust bearing on the rear of the crankshaft is feeble. On a big block it is not a problem. The throw out bearings on the rear of the transmission have been trouble free in my experience.
Offline Griso8V
« Reply #74 on: May 31, 2024, 04:44:20 PM »
I put it in neutral at a light when everyone is stopped behind me.  I never had an issue putting in gear on any of my bikes even getting caught in neutral even when I get caught when the light changes.  All my bikes (V50, V11, Griso8v & V7 850) went into neutral no problem.  I only put it in neutral when there is no threat and if i have any fear that I may need to blast off out of the way then I leave it in gear...Or if I am on a hill like in San Francisco then 1st gear it is...
Tony C
Offline wirespokes
« Reply #75 on: May 31, 2024, 07:47:52 PM »
That might be the problem, though in my case it's a high idle, that won't come down any lower. When the engine is cold, it idles slower and getting into neutral isn't a problem.
Also, I've never had a problem getting into first from neutral. A fast get-away? No problem. Clutch in, snick into first, blip throttle, GO!
Since I wrote this posting, I rode the bike again today and realized the difficulty shifting into neutral from first or second has nothing to do with the idle or the clutch. With engine off it's still difficult finding neutral.
« Last Edit: June 02, 2024, 09:16:14 PM by wirespokes »
