Author Topic: Changing to Neutral at a Stop Light?  (Read 9194 times)
Offline Kaladin
« on: September 26, 2022, 11:18:47 AM »
The manual for my 2007 Norge says that I shouldn't sit at the stoplight in gear with the clutch pulled in.  As usual for user's manuals, it doesn't say why.
In the old days of clutch cables it was extra safe to put it in neutral in case the cable snapped, but I don't think that is the reasoning with thy hydraulic clutch.
Any ideas?
-k
updated subject line - R59
« Last Edit: May 29, 2024, 08:36:49 AM by rocker59 »
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be.  And when you find it you discover "that's where it should have been."
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Re: Waiting for the light to change in neutral
« Reply #1 on: September 26, 2022, 11:29:03 AM »
Norge? LOL so you dont have to hear the clutch plates chattering! (In the words of my dad- "If my motorcycle made that noise, I believe I'd take it to a mechanic!")
Honestly I have no idea. I always shift down to first and hold the clutch in unless I am at a 'known' extra-long light.  Maybe the italian manual writers dont know about crazy US drivers and road rage. I prefer to be in gear and ready to move if someone comes screaming up behind me or other such instances
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: September 26, 2022, 11:30:23 AM »
I think it’s a general rule for dry clutches.
Offline Ryan
« Reply #3 on: September 26, 2022, 12:19:08 PM »
Early in my riding, I was taught to keep it in gear and the clutch in, pointed in a safe direction and watching my mirrors so I could quickly escape someone who was about to rear-end me. I still do it, but only until there is a car stopped behind me.
Offline berniebee
« Reply #4 on: September 26, 2022, 12:47:39 PM »
Dirk is right , this is good advice for any dry clutch. Don't keep your clutch lever pulled for extended periods. Why? Dry clutches have a clutch bearing.
The bearing only spins when you pull in the clutch lever. These bearing will wear out prematurely if you keep the clutch lever in at every stop light.
« Last Edit: September 26, 2022, 12:51:41 PM by berniebee »
« Reply #5 on: September 26, 2022, 03:41:04 PM »
C'mon folks. There are splines in the clutch and intermediate plates that are free to rattle back and forth when the lever is pulled in. It's because of the 270 degree firing order. They will eat up the transmission input gear and flywheel. Simple. Once you are no shit sure there's nobody about to hit you from behind at a light, bump it into neutral and release the lever. All those parts will thank you.
Albert Einstein
« Reply #6 on: September 26, 2022, 04:29:14 PM »
My Convert says: "Pffft", I don't need no stinkin' neutral."  :grin:
Offline Kaladin
« Reply #7 on: September 26, 2022, 04:30:43 PM »
Thanks, I was hoping to be enlightened, and I was.
So even in Neutral with the clutch pulled in is wearing the mechanism.
k
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Offline Kaladin
« Reply #8 on: September 26, 2022, 04:51:36 PM »
The Convert user's manual recommends not looking too smug when stopped at a stoplight.
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Offline Markcarovilli
« Reply #9 on: September 27, 2022, 08:09:12 AM »
in addition to waving with your left hand whenever you want to....
Mark
Online chuck peterson
« Reply #10 on: September 27, 2022, 08:23:08 AM »
 :popcorn:
Regarding the Vert departure…
I’ve advocated stomping on the foot brake…
“Open throttle fully…” per owner’s manual !!!
“Release brake..” again per owner’s manual !!!
Just to check full acceleration  :cool:
Oh and then the queen’s wave with the left hand…I definitely left hordes of bikers scratching their heads at Marcus Dairy
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline MMRanch
  • MMRanch
« Reply #11 on: September 27, 2022, 08:44:27 AM »
For me its a carry over from driving strait shift cars :
     Go from high gear to neutral without using the clutch as you stop.
     Don't use the "throw-out-bearing/clutch"  no more than necessary.
     When the light is changing , then and only then press the clutch and put it in gear.
To change the "Throw-out-bearing" means to separate the transmission and clutch housing.   Who wants to do all that ?
What worse than having to work on your vehicle ?
Paying somebody to work on your vehicle !    :laugh:
« Last Edit: September 27, 2022, 09:01:46 AM by MMRanch »
2016 V7-II Stone
Online Wayne Orwig
« Reply #12 on: September 27, 2022, 11:49:21 AM »
On a Norge?
« Reply #13 on: September 27, 2022, 11:55:50 AM »
And I watch for the cross traffic light to turn yellow and then put in first so I am ready to go, unless I am further back from the light, in which case I have time to put into gear before the cars in front of me are moving.
Offline TOMB
« Reply #14 on: September 27, 2022, 12:26:42 PM »
Wait! What?
My Convert doesn't have a Neutral?
My Eldo certainly had more than one neutral!
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline Scott of the Sahara
« Reply #15 on: September 27, 2022, 01:32:19 PM »
I like to keep the bike in neutral then put it in gear just before the light changes.
Reasons: I do not want to keep the clutch pulled in for long periods, my hand can cramp up.
Also when I put it in first I know what gear I am in. It is not happy to try to start in 2nd.
I also think the clutch internal parts have less wear when in neutral, especially the throw out bering.
Another reason is I like the happy little green light on the dash shining up at me.
Offline Frenchfrog
« Reply #16 on: September 27, 2022, 04:15:41 PM »
Keeping the clutch pulled in at the lights is simply not good mechanical practice...I'm astounded that people seem to frequently do this in the US.In Europe you would never pass a license test if you did it and as others have pointed out it's a sure way to wear out the clutch release bearings and more.
« Reply #17 on: September 27, 2022, 06:12:15 PM »
Frenchfrog,
IIRR, being in gear at a stop light is the riders safety course way of doing it. It appears that Europe disagrees.
But then... A question that used to be and maybe still is for the written motorcycle drivers test in California was that if your throttle got stuck (don't think it said WO or not) would you... and a multiple choice. One was to shut the bike off. BEEPP wrong answer. Pull in the clutch is the correct answer. Nothing in the answer said pull in clutch and shut bike off, just pull in clutch. So, remember, if you throttle ever sticks according to Ca. DMV, pull clutch and blow your engine!
FWIW, If at a short time light (like you just saw your direction left turn light go and you just pulled up to the traffic), in gear. If at a light that I know takes some time, neutral.
JMHO,
Offline AJ Huff
« Reply #18 on: September 27, 2022, 06:31:17 PM »
My MSF course taught us to stay in gear and pull the clutch in at lights. I've been doing it that way ever since.
I think by the time I I found neutral after shifting back and forth from 1st to 2nd the light would have changed anyway and I could be on my merry way. LOL.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline pehayes
« Reply #19 on: September 27, 2022, 06:34:33 PM »
Not on a Guzzi.  LoopFrame or Tonti  you just pull the swingarm and the clutch bearing is staring you in the face.
On my vintage Guzzi singles, the clutch bearing comes off without any tools in about five seconds.  Oh,  you need a rag to clean your greasy fingers.
Offline MMRanch
  • MMRanch
« Reply #20 on: September 27, 2022, 08:50:02 PM »
I sure hope that is true of the V7II   "if" I ever have to replace the clutch bearing on mine .    :smiley:
2016 V7-II Stone
Offline Frenchfrog
« Reply #21 on: September 28, 2022, 02:58:41 AM »
Well if you are taught to pull in the clutch instead of snitching into neutral then I understand that most riders would do that ...but it still makes little sense from a mechanical point of view.I guess that the USA Clutch Manufacturer's Association must have had someone good doing their lobbying  :grin:
Offline Speciality
« Reply #22 on: September 28, 2022, 07:19:28 AM »
I was taught to put the gearbox in neutral too (UK). Same with cars too. As for being rear-ended the advice is to show the stoplight until another vehicle pulls up behind. I tend to put in neutral as I come to a stop. As ever though the “it depends” qualification comes into play. Often one can assess how long it will be before the lights change, in which case I’ll hold it in first for a brief period.
Online kballowe
  • - Kevin the Great -
« Reply #23 on: September 28, 2022, 07:35:34 AM »
I'm always in gear at a stoplight.
Offline Anomaly
  • Location: Southern Tuscany (mostly), Rhode Island (sometimes)
« Reply #24 on: September 28, 2022, 07:48:09 AM »
You all seem to be talking about bikes with  a neutral indicator that indicates neutral and a gearbox that predictably renders up neutral on the first try. I thought this was a Guzzi forum....  :grin:
Offline Frenchfrog
« Reply #25 on: September 28, 2022, 08:22:10 AM »
What's a neutral indicator ?! :grin:
Offline Anomaly
« Reply #26 on: September 28, 2022, 08:42:19 AM »
It's a little green lamp in the middle of the gauge cluster "full of sound and fury, signifying nothing"
Offline brider
« Reply #27 on: September 28, 2022, 08:47:15 AM »
This topic is just too tempting to NOT weigh in on.
I am in the "put it in neutral" camp.
Like many oldsters here, I was taught to put it in neutral based on the theory of not wearing out the throwout bearing on a car/truck. Same logic applies with a motorcycle, which DOES have a throwout bearing of sorts.
But imagine yourself sitting at the head of the line with cross-traffic in front of you, on a dynamic system with 60+ HP of latent energy being held back by your squeezed hand, and the clutch cable/hyd line:
A. Frays and snaps that last wire that kept it operational
B. Looses the crimped ball-end because it was defective from the manufacturer
C. Hyd clutch line fails under pressure at a weak point that has been weakening for a long time with no symptoms
D. You have a sudden muscle spasm, stroke, or any other malady that causes you to release the clutch lever
As we say in the aircraft biz: Bad things happen fast.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Online Bulldog9
« Reply #28 on: September 28, 2022, 08:53:24 AM »
I stay in gear at lights until the cars behind me are fully stopped. Not harmful for a minute or two, but holding the clutch in on any vehicle will create wear to the throwout bearing and mechanism. Catastrophic? Nah, but wear all the same. Always better to sit and idle in neutral.
I love the chinkalingaring sounds my Griso and 1200 Sport make when the clutch lever is pulled. Still remember Dave Richardsons face when the first time I pulled the clutch and immediately released in surprise. "That's normal, only be worried if it doesn't make that noise... It's a dual plate dry clutch..."
MGNOC#23231
Online Moparnut72
« Reply #29 on: September 28, 2022, 09:43:27 AM »
I am in the put it in neutral when the coast is clear. I had a very early R75/5 that broke clutch cables quite often. That is a wake up call at a light for sure. There was a sharp bend in the cable at the lever that would fray the cable. I modified it but it didn't help much. I tried to keep an eye on it but would get complacent and it would always break at a light.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
