Author Topic: another oil thread - failures!!!  (Read 3914 times)
Online SIR REAL ED
  • uh.... it's personal....
« on: October 27, 2022, 02:55:44 PM »
With so many opinions & debates on what is the best brand, weight, price, etc of oil.....
It would be very interesting and informative to know if anyone ever experienced an oil failure that was not directly traceable to their own lack of maintenance and diligence?  ie: letting the oil level get toooooo low or using the wrong oil for the application.
Personally, I don't know of anyone who can honestly claim "I know the oil failed cause I did everything right!"
Looking forward to the stories MGers have to relate.
Unfortunately, I have none to tell.......   :sad:
2002 MZ Skorpion
1994 DR Skorpion
Offline Markcarovilli
Re: another oil thread - failures!!!
« Reply #1 on: October 27, 2022, 03:55:26 PM »
every oil I try have had the same results and I'm getting tired of it...
I make a bloody mess every single time no matter how careful or the amount of rags I use and never the same accident or problem repeats itself.  Failures for sure!
Mark
Offline Fontain25
« Reply #2 on: October 27, 2022, 04:25:09 PM »
I've never heard of another Guzzi that broke a connecting rod. My V700 did back in the 80s. Rod broke off one inch below wrist-pin and just flailed everything - engine cases , cylinder sleaves , even got a big dent on camshaft. Not from lack of lubrication as far as I could determine - at the time I chocked it up to a defective rod. Was running Castrol 20w50.
Online SIR REAL ED
« Reply #3 on: October 27, 2022, 04:50:23 PM »
Mark
Sounds like a demand for a motorcycle oil diaper is out there waiting to be invented.
2002 MZ Skorpion
1994 DR Skorpion
Online SIR REAL ED
« Reply #4 on: October 27, 2022, 04:55:05 PM »
Very interesting.
That sounds like a manufacturing flaw, like a crack or surface defect that propagated, in the connecting rod to me.  I suspect an oil failure would have occurred in a bearing.
How many miles were on the bike?
2002 MZ Skorpion
1994 DR Skorpion
Offline slopokes
« Reply #5 on: October 27, 2022, 05:04:12 PM »
Years ago they had a oil box—- bag with sawdust inside— if I can remember rite they were fifty cents….
« Reply #6 on: October 27, 2022, 05:46:41 PM »
^^^^The old "Tips" books by Frank Wedge had many bodges, including several with Kotex. They'll soak up oil real good. That's all I'll say about that..
kballowe
« Reply #7 on: October 27, 2022, 05:58:54 PM »
One of the guys in our riding group has a GL1800 Gold Wing and #3 cylinder is down to 85 psi and it's using half a quart of oil every 1,000 miles now.  He uses the WalMart house brand Super Tech oil and filters and 8,000-ish mile oil change intervals.  He claims that his use of "el cheapo" oil and filters is the cause.  Not the 500,000+ miles showing on the odometer.
True story.
Online SIR REAL ED
« Reply #8 on: October 27, 2022, 06:43:59 PM »
True story.
Did he ever tell you what the compression readings are on the other 5 cylinders?
I know a guy who bought the GL1800 and liked to brag about the low end torque.
Him:  "have you ever ridden route 43 from Buchanan up to the Parkway?"
Me:  "Sure.  Lots of times."
Him:  "I can ride those 15 mph switchbacks in fifth gear no problem."
2002 MZ Skorpion
1994 DR Skorpion
Online Beowulf
« Reply #9 on: October 27, 2022, 08:17:43 PM »
I have experienced what I’d call an oil failure. But I chock it up to my younger stupidity of running to thin an oil for air cooled Vw motor based off a recommendation that I shouldn’t have listened to. Chevron oil.
I bought a truck with a regular maintenance log and it had a massive timing chain failure due to buildup from conventional oil. Engine was suppose to be synthetic motor oil. Motor craft oil in this case was what was used.
Both things I attribute to oil but can’t fault it for misapplications of use.
I have my favorite brands of course now and I really love frequent oil changes. I think it’s hard to go wrong and think similar weights of oil have similar failure rates when tested. I do notice depending on intervals and brand some do seem to run cleaner when I’m replacing parts. Love oil threads. I find them entertaining.
« Reply #10 on: October 28, 2022, 12:44:25 AM »
Riding my 72 Eldorado one day all of a sudden started to make a clatter like big End and the oil pressure dropped from ~ 40 to 5 PSI I thought I was looking at an expensive overhaul.
When I finally got around to stripping it down I took the RH tappet cover off and the rocker shaft for exhaust valve fell out on the ground.
It turned out the 6mm bolt that holds the shaft in place had worked its way out thus bleeding off all the pressure and let the shaft drop down to rattle on the inside of the rocker cover.
Happily with a replacement bolt the pressure is back up to 60 PSI when cold idling and the motor is very quiet.
« Last Edit: October 28, 2022, 01:10:17 AM by Kiwi_Roy »
Offline s1120
« Reply #11 on: October 28, 2022, 06:11:29 AM »
Most of what I have seen is automotive from working for 25 years at a VW/Mazda dealer. VW was REAL picky about what oil they wanted you to use in their cars. We did see some oil related failures, but frankly all that I saw could be traced back to oil change intervals. Pushing out cheap oils to too many miles, or even good oils to the long extended drain times that they spec some times. Sludge, crud, and blocked passages caused failures. As far as the oil itself causing issues, the only thing I have really seen is flat tappet cam failures in old auto engines from the lack of zink in the new oils.
Paul B
Online Moparnut72
« Reply #12 on: October 28, 2022, 08:21:04 AM »
One day back in the late '60s I was hanging out at the local BMW - Honda dealership in the service area. There was a discussion going about how Castrol oil was so much better than anything else. Of course there were the deniers. The owner was nearby working on a bike. He piped up with "the only damage I have seen was from lack of". End of discussion.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline moto-uno
« Reply #13 on: October 28, 2022, 10:50:25 PM »
  I gotta say any body mentioning Castrol oil as a good product in the 80's was simply wrong .
I worked at one of Canada's largest Yamaha dealerships then and would frequently use Castrol 20W50 .
It was supplied in 200 gallon drums to the dealership , so I could buy it cheaply. Every single time I did this ,
my oil pressure gauge read 10 psi lower at idle within 10 kms of the oil change . When I got paid , I used
Kendall 20W50 and the pressure in my Le Mans 2 gained 10psi . This must have happened at least 10 different
times while working there . Remember all oil viscosities must meet a minimum flow rate , not always the highest.
I haven't used ( and will never use a Castrol oil ) product again . A pressure gauge is kinda cheap . And even
if YMMV , use this product with some caution if you tend to ride hard !  Peter
And, Yes I did use the Castrol 20W50 .
kballowe
« Reply #14 on: October 29, 2022, 08:12:22 AM »
Many moons ago, when I was a young man - and dinosaurs roamed the earth..... I used to do a lot of work on automobile engines.
The era of legendary extreme engine sludge.  We'd roll those engines out back and blast 'em with the steam cleaner BEFORE disassembly.
Phillips 66 "Trop-Artic" oil was popular at the time.  Those engines were relatively clean on tear-down.  Pennzoil had a bad reputation in those days.
Offline pressureangle
« Reply #15 on: October 29, 2022, 08:27:05 AM »
Ah yes, the 'Pennzoil Penance'. Motor oil with Paraffin base was death in the rust belt winters. Fords were particularly bad, often having a half inch of candle wax built up inside the valve covers. Seasonal maintenance was adding a half quart of diesel to the engine oil and idling 15 minutes hot before draining.
The only oil related failures I ever had in anything was on 883 Sportsters when racing very long tracks- the thick liners built up too much heat for weak oils and would scuff pistons. Castrol was an absolute no-no to everyone.
Online SIR REAL ED
« Reply #16 on: October 29, 2022, 08:58:46 AM »
Obviously, someone fudged their viscosity numbers.
It would be interesting to perform a test with different viscosity oils from the same manufacturer and monitor oil pressure both hot and cold.
2002 MZ Skorpion
1994 DR Skorpion
Online SIR REAL ED
« Reply #17 on: October 29, 2022, 09:04:26 AM »
growing up outside of Rochester, NY, adding diesel fuel to the engine prior to changing oil was a regular routine.
to this day, I still think the engine Flush liquids they sell in quart can are just kerosine due to the smell.  you pay extra for the red dye?
one of my buddies had a Ford pickup with the 240 straight six in college.  high mileage.  it kept progressly burning more oil and losing power.  coming home for Christmas, he said it didn't have the power to go faster than 30 mph and burned 10 quarts of oil in 300 miles!  We replaced the engine with a 300 straight six over Christmas vacation and had to swap oil pans.  the oil looked fine, but there was enough oil control ring pieces in the oil pan that I suspect at least 3 pistons had no oil control rings on them at all.
ah, the adventures of being young and poor......
don't we all miss those days?
« Last Edit: October 29, 2022, 09:08:46 AM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
kballowe
« Reply #18 on: October 29, 2022, 09:28:09 AM »
Thankfully, Shell bought the Pennzoil/Quaker State brands in 2002 and changed the formulations.
There are some of us that still refuse to buy yellow bottle Pennzoil.    :boozing:
« Last Edit: October 29, 2022, 09:29:49 AM by kballowe »
Online Moparnut72
« Reply #19 on: October 29, 2022, 12:38:22 PM »
Because of this problem my dad's first and last Ford was the reason my mom couldn't have the Mustang she wanted. It is my understanding the oil drain back holes were too high and not all of the oil would drain out of the valve covers and would then cook and sludge up. The the valve springs wouldn't get fresh oil, overheat and break. '58 Ranch Wagon with a 352 V8, very troublesome car.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline s1120
« Reply #20 on: October 30, 2022, 05:03:07 AM »
I think a lot of of us might be old enough to remember the year back in the late 70's when Penzsoil had messed something up BIG time and was blowing up engines left and right. Dont remember the exact year, I was a few years too young, but the auto shop lost a lot if engines, as did most all  repair shops that used it. Maybe it was a local thing, but you couldn't give Pennsoil away in the late 70's, early 80's around here.
Paul B
Offline bad Chad
« Reply #21 on: October 30, 2022, 06:31:10 AM »
Ahh, the fog of time at work.
1988 YX600 Radian
Online Moparnut72
« Reply #22 on: October 30, 2022, 10:49:21 AM »
Pennzoil and Quaker State had a bad rap back East back in the day. Until recently I raced two stroke outboards so I did extensive research into two stroke oils. Surprisingly enough Pennzoil came out as one of the best. It was the absolute best as to amount of ash produced.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
