Author Topic: Gas Tank removal Tool help  (Read 2034 times)
Offline SemperVee
  • USMC Retired
« on: November 06, 2022, 01:06:56 PM »
 After dealing with my first Norge gas tank removal,  a search brought up this tool for separating gas tank fuel connection.  Any one have one of these than can comment on it's use?   $10.00
Disconnect Tong Removal Tool used for Demount Brass Push Fit Connect Fitting
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Re: Gas Tank removal Tool help
« Reply #1 on: November 06, 2022, 01:28:49 PM »
I don’t have one, but there is a gadget you can get and I’ve seen one in use.
It is like an oversized set of pliers that have a kind of fork on one jaw and a cup on the other. You open it up and place it over the “quick detach”  :rolleyes: fitting, and as you close the jaws, it squeezes the grey plastic ring against the collar, then the whole lot just slides off.
I’ll phone Paul Harris in London, he’s the guy who had it as I recall.
This is vaguely reminiscent of the thing.
« Last Edit: November 06, 2022, 01:32:50 PM by Huzo »
Offline SemperVee
  • USMC Retired
« Reply #2 on: November 06, 2022, 02:14:45 PM »
  Thanks HUZO.   I know there has to be a "user" friendly way that would be a help to anyone who struggles with this kind of fitting as often as we have to do it and avoiding having to chase down parts for breaking it.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
« Reply #3 on: November 06, 2022, 07:33:48 PM »
It can sometimes be hard to pinch the coupling to release the clips V7 and CARC bikes.
Disconnect the wires to the fuel pump first then try to start the bike, it will typically start and run for a couple of seconds, this uses up the fuel under pressure which takes the pressure off the clips to make it easier to squeeze the fitting and release the clips.
Offline Scout63
« Reply #4 on: November 06, 2022, 09:16:35 PM »
Ben Zehnder - Orleans, MA USA
Offline tris
« Reply #5 on: November 07, 2022, 12:19:18 AM »
That's the set I have but you only need the green ones
Not the best quality in the world,  but unless you're earning your living using them they'll do the job
Plus they're as cheap as chips on ebay ... which is nice  :thumb:
« Last Edit: November 07, 2022, 12:20:39 AM by tris »
1993 TW125 "POS" - Resting
Offline flower_king001
« Reply #6 on: November 07, 2022, 04:09:01 AM »
I replaced mine with metal quick disconnects:
https://www.beemerboneyard.com/fuliqudise.html
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline SemperVee
  • USMC Retired
« Reply #7 on: November 07, 2022, 10:06:30 AM »
I use these. One of those tools that really works well.
https://www.denniskirk.com/bikeservice/vacuum-and-fuel-hose-removal-pliers-bs2110.p285064.prd/285064.sku
Thanks for the web jump scout.  Good to know it works.   Between the push this and pull back that at the same time can be hard while trying to be careful is a challenge.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Offline SemperVee
  • USMC Retired
« Reply #8 on: November 07, 2022, 10:10:03 AM »
That is great and looks to be easier...    Thanks!
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
« Reply #9 on: November 07, 2022, 01:19:18 PM »
I have always taken this route and never have a problem.
