Author Topic: 300mm Front Disks Kit - LM1000  (Read 2841 times)
Offline Groover
    • Scooteropolis
« on: November 30, 2022, 02:20:25 PM »
Is there a good conversion kit ready made out there for 300mm front brake conversion for the Le Mans 1000?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Turin
Re: 300mm Front Disks Kit - LM1000
« Reply #1 on: November 30, 2022, 08:27:18 PM »
Not anymore. There used to be a kit composed of Brembo 300 mm rotor, Menani caliper adapters, and gold brembo calipers.
https://dropbears.com/s/sda/p62.htm
I bought these discs from a board member. I had caliper adapters made and used harrison calipers cuz I had them sitting around. on a 16" wheel.
love poems by famous poets
1985 Sidlow Guzzi
Offline Turin
« Reply #2 on: November 30, 2022, 08:33:26 PM »
your best bet for brake discs is ISR. Acke made a custom set for my project and they weren't much more expensive than Brembo or EBC and they look wicked!
1985 Sidlow Guzzi
guido guzzi
« Reply #3 on: December 01, 2022, 09:49:34 AM »
 :drool:
Offline Groover
    • Scooteropolis
« Reply #4 on: December 01, 2022, 03:58:14 PM »
Thank you Turin, both those options look great! Thanks again for the alternate suggestion. The kit sounds(sounded) perfect of course..   :azn:
1980 Vespa SI Moped
Online cliffrod
« Reply #5 on: December 01, 2022, 04:54:06 PM »
Yup.  I understand Menani is no longer in business.  eBay seller valtermotousa sold me a pair of NOS Menani clip-ons for my Corsa Record project last fall.  He said Menani was permanently closed, that they had purchased all remaining Menani inventory and were selling it.   There would be no more.
There may be a chance that valtermotousa (via their website or eBay)  have the adapters mentioned by Turin, but ?  Good luck.
Offline Groover
    • Scooteropolis
« Reply #6 on: December 02, 2022, 10:54:14 AM »
Ok, thank you Clifford. I reached out to that seller. I've actually purchased some stuff from them in the past - fingers crossed.
« Last Edit: December 02, 2022, 02:05:21 PM by Groover »
1980 Vespa SI Moped
Offline Groover
    • Scooteropolis
« Reply #7 on: December 02, 2022, 02:04:14 PM »
No Dice. They responded. Just wanted to provide an update.
« Last Edit: December 02, 2022, 02:05:05 PM by Groover »
1980 Vespa SI Moped
Offline Turin
« Reply #8 on: December 03, 2022, 02:17:58 AM »
you'll have to have some caliper adapters made up. Ed Milich makes adapters that are undrilled, but I'm not sure if those would work either.
I have this file. Might work?
1985 Sidlow Guzzi
Offline Groover
    • Scooteropolis
« Reply #9 on: December 04, 2022, 10:43:06 AM »
Thanks Turin. Saved the file, I'll revisit this update later on, I'll keep an eye out in the meantime. Just day-dreaming upgrade options at the moment. Thanks again.
1980 Vespa SI Moped
Offline Turin
« Reply #10 on: December 04, 2022, 11:41:21 AM »
That file is a bit off, but it's a place to start. Researching this stuff can be tedious, so I'm happy to share.
1985 Sidlow Guzzi
