Author Topic: crossover pipes  (Read 2300 times)
Offline ital4me
crossover pipes
« on: December 06, 2022, 10:28:27 AM »
Greetings, Anyone know if there is an issue with running two exhaust crossover pipes? I have a pair of racing megaphone mufflers with crossover under the trannie and another right below the alternator. If if I remember correctly I had some header pipes without the front crossover that I believe came with the mufflers. I was told at the time that it that the mufflers and straight header pipes were a factory racing item but I have no idea if that is true. They are nicely done. I had cut the reverse cone off the muffles and installed some Vance and Hines baffles, then welded the cones back on. They sound awesome.That was a long time ago and I cannot find the straight pipes, damn. Now I have two crossovers.
« Last Edit: December 06, 2022, 10:31:56 AM by ital4me »
Offline moto-uno
Re: crossover pipes
« Reply #1 on: December 06, 2022, 10:57:48 AM »
  I don't think the double xover pipes were a negative . Mine ran fine with them and the usual LaFranconis for mufflers .
  You can simply remove the one under the trans and simply install a straight or slightly angled pipe from an auto supplier.
  Peter
Offline Frenchfrog
Re: crossover pipes
« Reply #2 on: December 06, 2022, 03:53:55 PM »
I've ran both with no noticeable seat of the pants difference...that was with small internal dia downpipes though.
Offline Moparnut72
Re: crossover pipes
« Reply #3 on: December 07, 2022, 08:14:49 AM »
I bought a R75/5 in 1970, a very early one. It had a cross over in front just below the timing cover if I remember correctly. Anyway it was up front. A few years later the Airheads had a second added below the transmission. I was told at the time why it was added but I don't remember why.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online Groover
    • Scooteropolis
Re: crossover pipes
« Reply #4 on: December 07, 2022, 01:21:55 PM »
Turbo  :wink:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
