Author Topic: 2013 Norge Headlight Issues  (Read 1071 times)
Offline Redracechris36
« on: December 18, 2022, 01:45:54 PM »
I had a running light and low beam light out on my 2013 Norge. I replaced the H3 bulbs in both low beams, and now none of the lights work, except for 1 of the 2 running lights.
Thoughts?
Online Bulldog9
Re: 2013 Norge Headlight Issues
« Reply #1 on: December 18, 2022, 03:04:42 PM »
Thoughts?
Do the High Beams work?  It's been a while, but I think the High Beam is an H1 and Low Beam H3.
Did you reconnect everything? If so, start with the Grounds, then fuses, then relay. They should come on when you start the bike.
MGNOC#23231
« Reply #2 on: December 19, 2022, 07:42:44 AM »
I messed up the ground when I changed my Norge lights without knowing it.
Took a while to figure it out.  Hamlin added assistance.
