V11 instrument schematic
Topic: V11 instrument schematic (Read 1220 times)
LaGrasta
January 16, 2023, 11:50:34 AM »
2003 V11 Sport
I'm replacing my panel lights with LEDs, the OEM sockets were touch and go. The schematic colors are a bit difficult to read, appreciate someone to help clarify.
As for dash light wiring, this is now
confirmed
to be correct:
Instrument bulb harness color key
HIGH BEAM: brown +, black -
OIL: red black +, blue black -
NEUTRAL: white +, violet -
FUEL: red black +, yellow white -
BATTERY: red black +, light blue -
TURN: green black +, pink –
I removed each light socket, marked each before doing so. Then afterward realized the pen I used wiped off the masking tape while working with the harness. I then proceeded to remove the now unless tape and inadvertently also slid off the tiny zip ties that contained two wires, per socket. I now have all of these wires, unclear what one is positive, what one is negative, and what two belong together. The above is what I have concluded thus far. I'll figure it out, then post to the thread if no one else has ever recorded these facts.
Last Edit: January 17, 2023, 10:12:15 AM by LaGrasta
john fish
Re: V11 instrument schematic
Reply #1 on:
January 16, 2023, 02:49:54 PM »
You may want to check:
https://www.thisoldtractor.com/moto_guzzi_misc_wiring_diagrams.html
He lost the run of himself.
LaGrasta
Reply #2 on:
January 16, 2023, 02:54:37 PM »
thanks @john fish. I actually downloaded those with high hopes, ThisOldTractor maintains such a helpful site! However the English Schematics, are still in Italian. Even so I can figure them out, but the wire colors are so unclear, i can't be sure. Tonight I hope to sit down next to the bike, and probe around, taking notes to later share.
RinkRat II
Lake Powell AZ
Reply #3 on:
January 16, 2023, 03:19:05 PM »
Try Carl Allison's. May be a little clearer.
https://www.thisoldtractor.com/guzzi007/sportissimo.html
Paul B
LaGrasta
Reply #4 on:
January 16, 2023, 03:36:50 PM »
Thank you @RinkRat. I have his version as well, it's so nice as it's built
digitally
, I can really zoom in.
it's the same problem, it so very difficult to indentify the correct wires for each light, then positive and negative. I posted my best guess and will confirm or update once I probe each.
I complicated things a bit more for myself by using LED, unlike regular bulbs, these are directional so I must identify the positive feed for each.
RinkRat II
Lake Powell AZ
Reply #5 on:
January 16, 2023, 04:18:16 PM »
After looking at the diagram in my owner's manual it appears your initial assumptions are correct. A good double check wouldn't hurt.
Paul B
LaGrasta
Reply #6 on:
January 16, 2023, 04:21:03 PM »
thank you Paul, appreciate your taking time to help me confirm!
LaGrasta
Reply #7 on:
January 17, 2023, 10:10:53 AM »
this is accurate for my
2003 V11 Sport
with a single turn signal light
. Thank you @docc
https://static.imgzeit.com/reduced/e099c9e8cdfd4a07/A3EAE9D4-EB83-47A6-B945-24AC9B39CD3B.png
confirmed
to be correct:
john fish
Reply #8 on:
January 17, 2023, 04:33:21 PM »
That's awesome. Thank you for posting that.
The V11 Sport is a great motorcycle. Selling mine in the swap meet here. I love it, but the old body just won't tolerate the riding position anymore.
