Author Topic: engine out of convert or not  (Read 1734 times)
Offline ray bear
« on: January 24, 2023, 12:06:05 AM »
Can I remove just the transmission of my Convert by removing swing arm and raising the rear of frame to allow trans to come back and leave motor insitu or do I have to do the Tonti thing and lift the complete frame from engine gear box assembly . When I rebuilt my V7 sport I removed the complete frame from the the lump but this time I just want to get the trans assembly out of the Convert and hoping there is a short cut . Ray.
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline chuck peterson
Re: engine out of convert or not
« Reply #1 on: January 24, 2023, 01:14:11 AM »
Yes you can pull it off by crabbing the frame. I used a good sized wooden box taller than the centerstand underneath the motor and removed the front wheel to leave room for the front forks to move towards the floor as you lift the back
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #2 on: January 24, 2023, 07:46:45 AM »
Not a convert but this is how I do it.
Offline TOMB
« Reply #3 on: January 24, 2023, 09:35:17 AM »
Be sure to have a drain pan under the transmission--you will drain about 1/2 of the fluid in the torque converter.
I did when I did mine.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
