Author Topic: Quick clutch spring question loop frame  (Read 2866 times)
Offline 2slow
« on: February 03, 2023, 12:09:34 AM »
This might be a dumb question but on a 72 Ambassador with the motor in the frame how do you keep the clutch springs in place while your putting the pressure plate on any tips would be appreciated thanks
Offline ray bear
Re: Quick clutch spring question loop frame
« Reply #1 on: February 03, 2023, 12:33:13 AM »
Dont the springs  press on to a raised section in the bottom of the spring recess  in the flywheel, you may have to rotate the spring till it catches ,  maybe a dab of silicone on the end of the spring and hold it in place till cures. most important that they line up and locate correctly at the other end
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline normzone
« Reply #2 on: February 03, 2023, 12:33:19 AM »
Hi [2Slow], and welcome.
An expert will be along momentarily to give you the correct answer, but if it was forty years ago I would have thought:
A dab of grease? Grease and clutch plates generally bad combination, but if you used the bare minimum ...
A bit of newspaper? It's going to get broken down for sure.
Edit: I like dab of silicone ...
« Last Edit: February 03, 2023, 12:34:07 AM by normzone »
Offline Rolf Halvorsen
« Reply #3 on: February 03, 2023, 02:48:04 AM »
A drop of super glue on the end of the springs will hold them in the straight position. Rolf
Offline TOMB
« Reply #4 on: February 03, 2023, 06:34:03 AM »
Silicon them to the pressure plate while laying flat let the assembly cure over night then reassemble.
The springs will stay straight  .
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Online jhem68
« Reply #5 on: February 03, 2023, 09:51:22 AM »
 I have used a waterpump pliers (Channellock's) to ever so slightly "crimp" one end of the springs so that they  will sit snug on the nub in the flywheel nubs while assemblying the plates. Doesn't take much force to make them snug up, so easy does it!
« Reply #6 on: February 03, 2023, 09:54:34 AM »
Permatex #2. Just a dab on the end, once dried for about 10 minutes it holds it in.
« Reply #7 on: February 03, 2023, 09:55:42 AM »
I have used a waterpump pliers (Channellock's) to ever so slightly "crimp" one end of the springs so that they  will sit snug on the nub in the flywheel nubs while assembling the plates. Doesn't take much force to make them snug up, so easy does it!
This ^^^.
Offline 2slow
« Reply #8 on: February 03, 2023, 07:10:34 PM »
Thanks guys for the suggestions gonna put the clutch in this weekend I’m sure I’ll have more questions in the future this is my first Guzzi mostly have airheads thanks again
« Reply #9 on: February 03, 2023, 07:12:35 PM »
Don’t bend the floater!
Offline moto-uno
« Reply #10 on: February 03, 2023, 10:41:31 PM »
  ^ What ?  Peter
« Reply #11 on: February 04, 2023, 08:27:59 AM »
  ^ What ?  Peter
I think he meant "don't bend the intermediate plate".
« Reply #12 on: February 04, 2023, 07:06:23 PM »
On a funny car they used a mult disc clutch and the plates that were loose when they were unclamped ,we called them floaters. We had a grinding machine that we would re surface the faces with. We did that after every run. It was a modified Cat D something caterpillar clutch. So I call the intermediate plate a floater for when it’s unclamped it’s loose. Sorry for the confusion . I bent my first one last century   :embarrassed:
71 Ambassador, my first Guzzi. I bought it used and put lots of miles on it. I didn’t want 2Slow to do the same with his intermediate plate. They were thirty bones back then.
« Last Edit: February 04, 2023, 08:24:04 PM by John A »
