Author Topic: 08 Norge Brake Master Cylinder Rebuild Kit Number Needed  (Read 1780 times)
Offline cappisj1
« on: February 06, 2023, 07:31:36 PM »
There is no listed part number for a rebuild/plunger kit for the Norge. My clutch master cylinder gave up last fall. Found a kit from Europe and that is fine. So yesterday the brake master cylinder started leaking. MG cycle said to ask around to see is someone knows. Even is someone knows the plunger size I could find the right kit. Or even tell what to measure to know the size. The clutch is 11.9mm.
Thanks.
« Last Edit: February 06, 2023, 10:10:22 PM by cappisj1 »
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Paul_Tim
Re: 08 Norge Brake Master Cylinder Rebuild Kit Number Needed
« Reply #1 on: February 07, 2023, 03:59:02 AM »
« Reply #2 on: February 07, 2023, 09:49:38 AM »
Front brake master should have the part # for Brembo on it, use this # to get parts. There is a US distributor, others to sell parts.
Here is another I have got from
https://www.bellissimoto.com/
If you have to buy a new master upgrade to a radial, they have a bleeder on the master usually.
Found this, you have to measure which one was used,
https://www.wemoto.com/parts/picture/is-brembo11-9
I've also read it's not rebuildable, I haven't done one.
https://addictionmotorsport.co.uk/brembo-replacement-parts/brembo-13mm-master-cylinder-repair-kit-ducati-aprilia-ktm-110436250
« Last Edit: February 07, 2023, 10:23:44 AM by guzzisteve »
Offline cappisj1
« Reply #3 on: February 07, 2023, 10:56:43 AM »
The wemoto part Brake and Clutch Master Cylinder Repair Kit Front - Brembo 11.9mm [AA0557] is what I used for the clutch side. The brake is a larger unit on the outside at least.
I can’t believe the master cylinder was only built and used on the Norge. There has to be a kit for it.
I will email these links and see if they know what will cross reference over.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
