Author Topic: Griso 1100 Piston Rings  (Read 1724 times)
Offline meccanicab
« on: February 09, 2023, 05:43:56 PM »
Hi guys, I've managed to break the oil ring whilst 're assembling the engine after a light make over.
The rings are no longer available to order from the factory, except as a complete piston/ring assembly, which is very costly.
Would any of you guys know which ring manufacturer makes the rings, plus where to purchase?
Thanks in advance.
Offline MattP
Re: Griso 1100 Piston Rings
« Reply #1 on: February 09, 2023, 07:33:56 PM »
Total seal call them talk to tec you want a molly or cast not crome 3 pice dia and thickness is what willbe asked.
Offline Don G
« Reply #2 on: February 10, 2023, 06:40:39 AM »
Any ring manufacturer will need to know cylinder diameter, ring width and depth, as mentioned above in a non-chrome material due to the cylinder surface material, chrome on chrome action is not cool. DonG
Offline MattP
« Reply #3 on: February 10, 2023, 08:06:56 AM »
Corect
« Reply #4 on: February 10, 2023, 08:11:47 AM »
The part number of the oil ring is 05061030/GU05061030. Doing a Google search of that number brings up a few possibilities.
https://www.google.com/search?client=firefox-b-1-d&q=GU05061030
Whether it's in stock at any of those listed is another thing.
Offline pressureangle
« Reply #5 on: February 10, 2023, 08:14:49 AM »
I had Total Seal make a set for my '85 LeMans. Very easy to work with and not expensive.
Offline Don G
« Reply #6 on: February 10, 2023, 05:06:36 PM »
I have used Chrysler 2.5L rings in 88mm cast bores, if I remember offhand they were + .5mm overbore, buy a set in chrome,moly or cast and you can service 2 engines fairly economically. DonG
« Last Edit: February 10, 2023, 05:10:07 PM by Don G »
« Reply #7 on: February 10, 2023, 05:50:04 PM »
Sent you a PM, my friend has 2 sets for stock G pistons, we are in USA not England. I would check there 1st.
Offline meccanicab
« Reply #8 on: February 11, 2023, 12:07:53 AM »
I've already exhausted all the suppliers in Europe who specialize in Guzzi parts. No old stock floating around. Not available from the factory.
I'm approaching various ring suppliers in the UK, but most don't deal with Italian. Japanese/ British yes.
Offline meccanicab
« Reply #9 on: February 11, 2023, 12:08:59 AM »
Thanks for the pm.
