Author Topic: Edit: Norge have immobilizer? Won’t start  (Read 75372 times)
« on: February 09, 2023, 06:13:15 PM »
If so and if the immobilizer has lost memory can you recover the connection? It doesn’t look like the key has a battery in it.
« Last Edit: February 09, 2023, 08:32:59 PM by fotoguzzi »
Online Bulldog9
Re: Does Norge have immobilizer?
« Reply #1 on: February 09, 2023, 06:42:10 PM »
No battery in the key, but there is a transponder chip in the key that communicates with the ECU through an 'antenna' that surrounds the key slot.  The key is not programmed, it is the ECU that 'learns' to communicate with key and register it to the ECU so the bike will run. Otherwise the ECU will 'immobilize' the bike.
You need the user code to program the dash to register keys.
MGNOC#23231
« Reply #2 on: February 09, 2023, 08:23:07 PM »
Hm,  I don’t suppose that’s the same as the service code, is it?
« Reply #3 on: February 09, 2023, 08:28:20 PM »
I think my key is fine but Here’s why I ask.
My Norge (2007) and my buddies 2008 have the same no start problem. Actually it will start by jumping the relay but the start button doesn’t work.
I’ve read everything i can find but still don’t have the answer. First the startus-interuptus fix has been done. Norge 1200.
turn key on, dash sweeps as normal and hear all the regular noises purge pump etc. push start button hear a thunk (from the starter solenoid?) and then nothing. It’s like everything good right up till the point where the starter should spin. Like I said the fix of a battery fused wire to the yellow wire at the start solenoid has been done.
if I jump the yellow to orange wires at the start solenoid the starter spins and bike starts. So the basic thing is the start button does not get the starter spinning. Checked the clutch switch, SS switch, neutral light works, new battery that checks out. I had a suggestion to clean the ground on back of starter but since it starts by jumping the solenoid I don’t think that could be it? The button wiring goes thru the clutch switch and the bank angle sensor (I tested and it works) could that be where the problem is? But why on both bikes would that fail?
what am I missing, it sounds like I’m having a brain fog or something but I read the start procedure in manual and follow exactly.
it’s pretty weird that two bikes in one garage have this same problem but I find nothing on line with this exact situation.
Tried 3 batteries one is brand new.
« Last Edit: February 09, 2023, 08:31:54 PM by fotoguzzi »
« Reply #4 on: February 09, 2023, 08:29:20 PM »
I have ordered all new relays and should have them tomorrow.
Offline cappisj1
Re: Edit: Norge have immobilizer? Won’t start
« Reply #5 on: February 09, 2023, 09:45:08 PM »
Make sure the battery is good. I bought a new interstate battery and got the no start click but a jump would fire it right up. I took the bike to them so they could test the battery. It checked ok but they gave me another one. Have been using that other one for 4 years no issues.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
« Reply #6 on: February 10, 2023, 06:12:51 AM »
Well, Brad.. it's *not* the immobilizer. Cleaning up the  ground is a good idea..
Offline Scott of the Sahara
« Reply #7 on: February 10, 2023, 09:51:09 AM »
just because the battery shows 12 or 13 volts does not mean it has cranking amps
Offline MattP
« Reply #8 on: February 10, 2023, 10:50:24 AM »
read your own post brad the starter works there for the bat works your not getting enough amps to the solanoid .
« Reply #9 on: February 10, 2023, 11:20:31 AM »
I think a search for "Startus Interuptus" may be in order.
« Reply #10 on: February 10, 2023, 12:18:39 PM »
Thatwas the very first thing we did.
« Reply #11 on: February 10, 2023, 01:16:23 PM »
When you hit the starter button, have you "confirmed" that the noise your hearing is the starter solenoid?
You said that you could jump 2 wires and the bike will crank and start. To be sure I understand. If you took a jumper wire from battery positive and touch it to the starter solenoid small spade connector the bike will crank and start?
If it will start with the jumper wire, the starter and battery positive and ground seem to be working.
I would make sure your starting relays are all getting power in and out as they should and confirm how may volts your getting to the spade on the solenoid.
If all check out. It "MAY" be a bad ECU. PLEASE correct me if I'm wrong, but I think the ECU has final say as to if the bike will crank? I DO remember a post a few months ago with a bike that had starting issues. I can't remember the details, but I think he ended up swapped the ECU with a Ducatti one and problem of starting solved. I think he then tried a friends Guzzi ECU and again solved IIRR. Might be worth searching for the thread. The guy was in the UK I think.
Good luck,
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #12 on: February 10, 2023, 02:42:05 PM »
Guzzidiag at hand?, it will show if bike is ready to crank.
Paul
Daytona 1225, Stelvio 1151
« Reply #13 on: February 10, 2023, 03:50:27 PM »
it shows discrepancies, saying start possible and start switch electrical errors.
Why would the GD show a different voltage that reading right off the battery. I see now why it won’t crank with not enough voltage but I used a new battery showing 12.8 before key on. Then tried another battery with a jumper hooked to a second battery but still got the low voltage signal.
Am I the new “Mr Nevada”?
« Reply #14 on: February 10, 2023, 03:58:57 PM »
There's your load test!
« Reply #15 on: February 10, 2023, 04:01:18 PM »
“Am I the new “Mr Nevada”?“
Not even close may he rest in peace.
« Reply #16 on: February 10, 2023, 04:43:35 PM »
if true why does it fire right off when jumping the starter relay?
GuzziOrDeath
« Reply #17 on: February 10, 2023, 05:07:21 PM »
The ECU requires a good ground and connection to measure the battery volts. If your multimeter reads, say 12.8V, but GuzziDiag shows 11.4, then either you have a bad connection or ground (most likely), or the ADC (analog to digital converter) in the ECU isn't working properly (least likely).
Startus Interruptus is probable. Check the ground on the ECU is clean and tight before going there, however. I've seen bad kill and start switches cause issues, too.
FYI, the immobiliser is controlled by the dash, not the ECU. Since you're getting the 'Start Possible' message in GuzziDiag, it's not the immobiliser. Even with worst case scenario, if the dash is sending the ECU the "don't start" message, just disconnect the dash to confirm. The engine will start without the dash connected.
« Reply #18 on: February 10, 2023, 05:52:48 PM »
if you connect the yellow wire to the Orange /green on at the starter relay it cranks, right? You can do that by removing the Start relay and jumping between the two contact terminals of the socket
« Reply #19 on: February 10, 2023, 06:38:52 PM »
There are several wires that have to be in great shape to fix Startus interrupts, the solenoid coil draws 50-60 Amps until the gear is pulled into mesh
The yellow at the start relay should be a 16 gauge direct from the battery via a dedicated fuse,
the wire from start relay to the solenoid should also be larger e.g. 18 gauge minimum.
The bank angle sensor needs to be closed, it can open if the bike is dropped, it's interlocked with the start relay coil, I have found that jumping the battery to the solenoid spade seems to close it,
causing the starter to wind over can shake it closed.
« Last Edit: August 22, 2024, 06:14:37 PM by Kiwi_Roy »
Online Bulldog9
« Reply #20 on: February 10, 2023, 06:57:05 PM »
If this is the case, is clearly not a key-immobilizer issue, likely 'starter interuptus' Lots of thread on that.
BLUF: Stock wiring doesn't deliver enough current to starter to engage and turn the engine over.
MGNOC#23231
« Reply #21 on: February 10, 2023, 07:13:41 PM »
The yellow at the start relay should be a 16 gauge direct from the battery via a dictated fuse,
the wire from start relay to the solenoid should also be a #16
s interlocked with thee start relay coilI have found that jumping the battery to the solenoid spade seems to close it, it can open if the bike is dropped
yes, if jumping the orange and yellow at the starter relay it will start. That wire from battery is 16g with a fuse. I have not done anything with the wire from relay to solenoid, I’ll look into that. Maybe that’s where I’m losing the amps to the starter?
I took the bank angle sensor out and tested it with an ohm meter, seemed to work, lost continuity when I tipped it 90* sideways. The starter solenoid pin is not very accessible on a Norge.
As a little more of a challenge some of the wire colors do not match the schematic I have, most do.. and 4 of the relay are identical but the 5th relay is bigger and has a different orientation of the pins, that’s the one that colors don’t match up , pretty sure that 5th relay is different on my buddies bike too, it’s either a headlight relay or one of the injector relays, I haven’t figured that out yet but should be able to by unplugging and see if the low or high beam are working I guess.
I have replaced all the relays but nothing changed.
We have thought about just putting in a new start button where we jump the start relay but both of us would rather find out why it does not start with the button on handlebar.
Getting to the ECU to check or add a ground is a pain. It’s buried under the tank and frame tubes up near the steering head but we might have to go there too. I guess that should be done nextNeither of the bikes have lived outside or been in the kind of situation that would cause corrosion but I guess any bad contact could be happening. Mine does have 94k, Bone’s only 13k and really clean.having two bikes with the same odd problem is a real stumper.
« Last Edit: February 10, 2023, 07:32:45 PM by fotoguzzi »
« Reply #22 on: February 10, 2023, 07:17:17 PM »
the first part of interuptus was the first thing we did. The fused wire from battery to yellow at the starter relay was done. We have not done a 16g wire from relay to solenoid, I have not seen that part of the fix before.
Also, the bike starts if jumped around the relay and uses the existing wire from relay to solenoid so why would the gauge of wire matter if it works fine when jumping the relay?
« Last Edit: February 10, 2023, 07:30:21 PM by fotoguzzi »
Offline drdwb
    • backfeelsgreat.com
« Reply #23 on: February 10, 2023, 09:16:26 PM »
My 07 Norge had a similar problem, intermittently though, that’s when I discovered it had already had most of the status interruptis fix done. Mine still doesn’t have the 16 ga going from start relay to solenoid, I will do that in a few weeks. My problem was in the kill switch connections.
Offline pauldaytona
« Reply #24 on: February 11, 2023, 05:47:01 AM »
Clear the errors, to show what is now on error. When it's empty, try to start and read afterwards to see if you got new errors.
Voltage shown in the dash ist always lower than measured on the battery direct.
« Last Edit: February 11, 2023, 06:56:45 AM by pauldaytona »
Paul
« Reply #25 on: February 11, 2023, 05:48:48 AM »
I have seen a corroded connector at the solenoid cause what you are talking about. Put a 16 gauge wire on there, and a new connector.
Offline bratman2
« Reply #26 on: February 11, 2023, 09:53:13 AM »
Had a pretty good run of not wanting to start with my 09 Norge.  Starter interuptus had been done years ago. Grounds cleaned and rebolted down. Nearly new Ballistic battery one size above what was called for. Finally pulled my starter and found that the grease had gotten kind of thick and sticky in the starter. Cleaned, lubed and reassembled and has been working fine since. May not be your problem being you can jump it out. Was my problem.
Glenn Taylor
09 Norge with Staintune and Rexxer reflash
87 Subaru Brat (owned since 97)
Offline Juan1
« Reply #27 on: February 11, 2023, 04:34:39 PM »
I'm eager to see how this is resolved.  I had a '07 Norge with this issue. Also did the Startus Interruptus, cleaned the ground point, cleaned the starter, and dropped in a fresh battery.  The issue was gone for a bit, but eventually came back...as I was selling the bike!
BTW, I consider the Norge to be a near perfect bike unless lane splitting is involved.
« Last Edit: February 11, 2023, 04:44:12 PM by Juan1 »
Offline pehayes
« Reply #28 on: February 11, 2023, 04:36:10 PM »
Bump.
Has this problem been solved on the 'fotoguzzi' bike?
Add another one to the list.
I'm trying to sell a 2006 Breva 11 cheap.  See the Swap Meet.  So, of course, now the bike won't start and I can't demo or show it.
Yes, a home grown Startus Interruptus was done years ago.
Yes, brand new MotoBatt AGM in October.  Normally sits on a solar maintainer.
I get just a loud CLUNK, heard and felt at the starter itself.  I started attacking connections everywhere.  I found two crimp spades that just freely pulled off their wires.  Aha, must be it!  No such luck.  Rechecked every spade, every crimp, every added wire.  Changed to a new automotive cube relay.  The starter button system doesn't do anything except power the little electromagnetic coil within the relay.  Pretty insignificant load.  I even opened the older relay and burnished the contact surfaces.  DeOxit sprayed everywhere.  I have 12" of 12ga going direct from the battery post to the relay.  I have another 12" of 12ga going from the relay to the starter spade.  All crimps were re-crimped at the wires.  All used spades were pinched down for better contact.
Clunk!  Clunk!
Now, I also have 24" of simple 18ga wire with alligators at each end.  Clamp one end at the battery post.  Poke the other end directly onto the starter spade.
Crank and zoom EVERY time.  Never a hesitation.
I'm stumped.  The only difference between my 24" of smaller wire and my larger wires on the relay is the number of spade connectors involved and the relay internal contacts.
But I cleaned and burnished the contacts.
But I changed to another brand new relay.
But I re-crimped every wire.
Can't be the starter or solenoid or it wouldn't work reliably with my alligator jump wire.
I've manipulated every possible connection.
Any ideas?
« Reply #29 on: February 11, 2023, 04:41:49 PM »
I posted earlier that I think the ECU may control the starter. Can anyone confirm this. Again, there was a post I think about a Norge that the ECU starter circuits had gone bad. I can't find that post.
I do hope I'm wrong and it's something simple.
« Last Edit: February 11, 2023, 04:42:36 PM by Tom H »
