4ls Brake Cable
Topic: 4ls Brake Cable (Read 1436 times)
czakky82
4ls Brake Cable
February 12, 2023, 02:03:34 PM »
Has anybody had success soldering/clamping a ferrule nipple onto a clutch/brake cable? Where did you source the parts?
All I see are big kits for around $200 and I don’t need all that.
Not interested in the screw together type.
My relatively new-ish brake cable on the right is a solid 1/2” too long. I could shorten it closer to an inch and it would be fine.
Thanks for any help
guzzisteve
"Just Ride It"
Re: 4ls Brake Cable
Reply #1 on:
February 12, 2023, 03:12:27 PM »
Here's 1 place
https://www.dimecitycycles.com/cables/cable-parts.html
Chuck in Indiana
Re: 4ls Brake Cable
Reply #2 on:
February 12, 2023, 03:14:05 PM »
I've used a 44 (I think) cartridge case as a solder pot. Cable through the nipple, fray the ends out. Heat the solder pot with a torch, acid flux on the nipple assembly, dip it into the pot. Let it cool, and Bob's you mother's brother.
czakky82
Re: 4ls Brake Cable
Reply #3 on:
February 12, 2023, 04:19:23 PM »
@Steve, I did see those. I was worried about the brass nipple on the steel ferrule….? Maybe a rule I invented in my head.
@ Chuck, I’ve drilled holes in wood similarly to your casing cauldron. I, uh was not successful. Maybe I’ll try again. Trying not to cobble this old girl too much… plus brakes I use a bit.
guzzisteve
"Just Ride It"
Re: 4ls Brake Cable
Reply #4 on:
February 12, 2023, 06:14:32 PM »
Try Flanders too. I got ends from them or another place in CA like it.
Kiwi_Roy
Re: 4ls Brake Cable
Reply #5 on:
February 12, 2023, 07:39:12 PM »
0u should have no trouble soldering any of the brass nipples from Dimecity cycles
tin the cable with a little acid core solder, then you can switch to rosin core
I have been using the screw type nipples with good results, I doubt you even need to sweat these cable, I don't believe they are the sweat type.
Antietam Classic Cycle
Happily stuck in the past.
Re: 4ls Brake Cable
Reply #6 on:
February 12, 2023, 07:43:44 PM »
I have a small assortment of fittings and may have what you need. PM me if you'd like.
czakky82
Re: 4ls Brake Cable
Reply #7 on:
February 13, 2023, 05:00:25 AM »
@ Roy, I have rosin core around here. Acid core not so much. I’ll have to do some research.
@ Antietam, I’ll send a PM.
You guys are awesome
Chuck in Indiana
Re: 4ls Brake Cable
Reply #8 on:
February 13, 2023, 10:49:15 AM »
Hmmmmm. When I opened youtube, this video came up.
The bots must be trolling WG..
Crude, but effective.
https://youtu.be/Ysd8JkWclmc
bigbikerrick
73 Eldo, 98 V 11 ,12 Ural Gear Up, 76 Convert,
Location: Southeastern corner of Arizona, right next to "Old Mexico, and New Mexico"
Re: 4ls Brake Cable
Reply #9 on:
February 14, 2023, 12:02:20 PM »
Like Steve said, Flanders is a good source for all kinds of cable making parts.
Rick
http://www.flanderscables.com/index.html
czakky82
Re: 4ls Brake Cable
Reply #10 on:
February 14, 2023, 06:19:24 PM »
I was nervous about buying from a bicycle supplier, but good to know.
Antietam reached out and we may have the correct parts heading this way.
Thanks all!
czakky82
Re: 4ls Brake Cable
Reply #11 on:
February 20, 2023, 05:11:29 PM »
Antietam to the rescue! He sent me some fittings and i soldered them on and my brakes appear to be timed a heck of a lot better!
Gave it a very hard squeeze and it seems to be plenty sturdy
4ls Brake Cable
