Author Topic: Hidden Bling  (Read 977 times)
Offline Scout63
Hidden Bling
« on: February 16, 2023, 09:31:45 PM »
I finally took the gearbox off in my v7 Sport build and found this lightened flywheel and ring gear.  Also a drilled oil pump gear.  Fancy.  What I don’t understand is why someone tacked the clutch pushrod end cap to the pressure plate.
a
Ben Zehnder - Orleans, MA USA
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Hidden Bling
« Reply #1 on: February 16, 2023, 09:37:43 PM »
Track bike in its previous life?
Re: Hidden Bling
« Reply #2 on: February 17, 2023, 02:09:07 AM »
Why would you drill holes in the gear ?
Offline Scout63
Re: Hidden Bling
« Reply #3 on: February 17, 2023, 06:54:37 AM »
My question also Huzo. Maybe a PO bought and installed it when doing the flywheel.
Offline cliffrod
Re: Hidden Bling
« Reply #4 on: February 17, 2023, 06:59:29 AM »
Can do vs should do stuff.  Drilling everything to excess like that isn’t uncommon in older race/performance builds. When it was all analog seat of the pants dyno, perceived benefits couldn’t always be separated from reality.
The difference between flywheel effect on my stock flywheel V7 Sport and this CX100 with seriously lightened flywheel is really noticeable- feels more like I’m riding/downshifting a Ducati when I’m on the CX100.  It’s not how I’m used to a Guzzi feeling.
The welded-in pushrod cap is possibly a remedy to hasty transmission r&r activity like you may do when racing. If you don’t seat it properly during assembly and it then seats itself while you’re riding, you get so much free play that you suddenly have no clutch.   This scenario can also happen at home when you were usually drunk & working on your bike in a hurry….
« Last Edit: February 17, 2023, 07:06:09 AM by cliffrod »
Carolina Sculpture Studio YouTube Channel-
Online bmc5733946
Re: Hidden Bling
« Reply #5 on: February 17, 2023, 10:42:07 AM »
I would bet that the few holes in the ring gear are final rotating balance requirements. I would make certain they returned to the same spot on the assembly. I have seen this before, but the memories are distant. Make your own insurance of balance or trust what others have done?
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Scout63
Re: Hidden Bling
« Reply #6 on: February 17, 2023, 07:27:41 PM »
Like an idiot, I didn’t mark the flywheel and ring gear before removing.  I’ve looked for match marks but can’t find any.  I’ll set up the flywheel with a degree wheel and try to get the ring gear right.  Thanks for the feedback everyone.
