Author Topic: V7 Sport cam gear removal  (Read 1644 times)
Offline Scout63
« on: March 05, 2023, 10:14:02 PM »
Is there a trick to keeping the cam gear from spinning while removing the 26mm nut?  Assuming I've already removed the crank nut and rods so can’t lock the rods.  Do I jam the gear?  As always, thanks to the forum gurus. Ben
Ben Zehnder - Orleans, MA USA
Offline moto-uno
Re: V7 Sport cam gear removal
« Reply #1 on: March 06, 2023, 01:52:43 AM »
 Do you have access to an air impact wrench and a block of wood to jam into the gear and the case to prevent it from spinning ?  Peter
Offline huub
« Reply #2 on: March 06, 2023, 02:32:39 AM »
make a tool to fit in the holes,
dont be tempted to block the gear on the teeth with something solid.
i've seen two gears that cracked, causing the gear to break, making a mess of the engine
Happened twice to the same guy, ( friend on mine)
he used to torque the gear down by fitting a piece of metal between the teeth of the cam gear and the crankshaft gear.
i use one of these.
https://www.bol.com/nl/nl/p/universele-poelie-vliegwiel-blokkeersleutel/9200000121684927/
« Last Edit: March 06, 2023, 02:38:20 AM by huub »
« Reply #3 on: March 06, 2023, 03:02:47 AM »
i use one of these.
Just a simple tool with two pegs to fit as mentioned above.
guido guzzi
Offline Scout63
« Reply #5 on: March 06, 2023, 06:49:35 AM »
This is in stock...
https://www.mgcycle.com/index.php?main_page=product_info&cPath=80&products_id=2628
I have that tool in my tool box.  I must have bought it from MG Cycle years ago and forgot about it. Duh!  Love you guys.
Offline Moparnut72
« Reply #6 on: March 06, 2023, 10:13:07 AM »
"don't be tempted to block the gear on the teeth with something solid.
he used to torque the gear down by fitting a piece of metal between the teeth of the cam gear and the crankshaft gear."
This was SOP in the aircraft shop where I worked. We used a piece of aluminum. No impacts in the shop just armstrong power. Never damaged a gear. I still have my piece of aluminum, it has a lot of teeth marks in it.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #7 on: March 06, 2023, 11:27:26 AM »
I see you have the proper tool. But in a pinch...
Not sure if your bike has the timing hole on the bell housing. If it does, you can also use a large screwdriver to jam the ring gear teeth. Helps to have someone hold the screwdriver, but can be done by yourself.
Offline Scout63
« Reply #8 on: March 06, 2023, 08:56:13 PM »
Thanks Tom. Ring gear, flywheel, crank gear and rods are already out.  The tool worked like a charm.
« Reply #9 on: March 06, 2023, 10:27:03 PM »
Always best to have the right tool for the job! :thumb:
