Author Topic: Do you use 10W-60 oil ?  (Read 26443 times)
Offline kballowe
  • - Kevin the Great -
Re: Do you use 10W-60 oil ?
« Reply #60 on: March 18, 2023, 08:47:33 AM »
OK, so - serious question here.....
How many of you have owner's manuals that specify Castrol products, and actually use Castrol products ?
Offline vibr8r
« Reply #61 on: March 18, 2023, 08:53:54 AM »
I bought my 2004 EVT from the original owner in Atlanta, GA.  He gave me a few receipts from the dealer which indicated that they were using 10w/60, yet the manual calls for 5w/40.  If all of the lubricated parts (except lifters) are the same in the parts manual, then why would it be taboo to run 5w/40 with conventional lifters?
Offline Moparnut72
« Reply #62 on: March 18, 2023, 09:59:10 AM »
Pretty much every "oil failure" I have ever heard is due to human error.
That's what my Honda/BMW dealership owner said when a few guys in the service area said when the merits of Castrol vs Valvoline oils were being discussed. "I've seen more engines damaged by lack of rather than the brand used." That ended the discussion.
I have been wondering if 10-60 is so good maybe I should use it in my water cooled Bonneville also. I ride in some warm temperatures, over 100*, the Triumph doesn't have the largest radiator. Probably should just stick with the recommended 10-40.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline brother dave
« Reply #63 on: March 18, 2023, 10:08:44 AM »
not I
2007 California Vintage (left the nest)
2018 V7 III Special
2021 V85 Centenario
2022 KLX300
Offline Vagrant
« Reply #64 on: March 18, 2023, 10:09:56 AM »
T6 is 5/40.
Offline NWrider
« Reply #65 on: March 18, 2023, 10:16:15 AM »
Mostly use Castrol 10w50wt.
Offline reidy
« Reply #66 on: March 18, 2023, 06:26:55 PM »
I have not seen the manual. I have no skin in this game. I can't blame winter but it is 38C here again today and even hotter in the shed so I have retreated inside.
What surprises me about the oil recommendation is every other vehicle I have owned has a chart with expected temperatures and has an oil weight recommended for that range. There is often a lot of overlap on the temperatures. This has always lead me to believe that there was no ideal oil weight for an engine, therefore the operator should use the one that is most appropriate for their conditions and use. The manuals often have two oil change intervals, one for regular use and one for severe use with some guidelines like stop start runs and such. Again it was up to the operator to choose the appropriate interval. In that way I have always followed the manufactures guidance.
« Reply #67 on: March 18, 2023, 06:42:59 PM »
Those range charts have all but disappeared in the auto world and are becoming less and less common in powersports.
I suspect the reason is two fold. Water cooled motors generally won't need as much if a range with changing conditions and maybe most importantly modern synthetic oils are much better suited to a wider range of ambient conditions.
Offline kballowe
« Reply #68 on: March 18, 2023, 09:04:18 PM »
Owners manuals from the past told us how to adjust the valves.
Now they tell us not to drink the contents of the battery.
80% of the newer manuals are warnings.
« Reply #69 on: March 19, 2023, 02:47:31 AM »
Penrite 10W60. Full synthetic. Full zinc loading. Heron head smallblocks run hot. <shrug>
Offline Old Jock
« Reply #70 on: March 19, 2023, 05:04:17 AM »
Probably won't satisfy Kev and only what I've found
I've got pressure gauges on my 3 Guzzis for various reasons and "joke" sump dipstick thermometers, so have some idea of oil pressure and temp
I've found the 2 v/v bikes are prefectly happy with 15/50, good start up pressure and stable running pressure and temps.
The HiCam Daytona RS engine has "mad" cams installed, that the US and Centauros didn't get.
The engine runs hot, 105C in clear air and rapidly overheats in traffic.
I run it on 10/60 which has improved the pressure, no difference in temp.
I ran Penrite for the last few years and still do on the 2v/v bikes and I'm about to try a Royal Purple 10/60 which is very pricey here.
Originally used Motul but the zinc content in RP and Penrite is higher, all oils are full synth .
« Last Edit: March 19, 2023, 06:56:59 AM by Old Jock »
Offline Stretch
« Reply #71 on: March 19, 2023, 07:51:31 AM »
Sad but true.........  :angry:
                               -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline gsf12man
« Reply #72 on: March 19, 2023, 08:46:20 AM »
When I had my Breva V1100, 10W60 Red Line. It gave me peace of mind when I rode in the Phoenix, AZ summer.
Tom K.
Suzuki V-Strom DL650A
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #73 on: March 19, 2023, 06:10:23 PM »
I had the same bike back in the day and the service manual does specify 5W-40 for the hydraulic bikes. I do recall a discussion that there was an update to require 10w-60 in hotter climates but being in NJ and not doing many long rides  I did run the 5W40 without issue.
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Offline kballowe
« Reply #74 on: March 20, 2023, 08:21:46 AM »
A good friend of mine was a barge Captain for Mobil and drove those huge barges up the Mississippi river from the Gulf refineries.  They'd dock in St. Louis and offload oil base stock.    I got to see the operation and spend time with the blenders and testers.   LOL - they bottled just about everything there.   One week it was brand x and the next week it was brand y.  There were no signs - just a large building and a lot of those huge storage tanks - and warehouse area.
Offline Clifton
« Reply #75 on: March 20, 2023, 08:40:10 AM »
Of course.... can anyone give me a good reason NOT to use what was spec'd by the OEM?!?
ANYONE?
Just one GOOD reason?
The owners manual for my 2019 Toyota Corolla 2.0 motor (and the oil fill cap on the motor) specify to "only use 0W-16 oil". I imagine it is spec'd by Toyota for slightly better MPG through our EPA test because the same engine in some other countries suggest other weights. I use 5W-30.
25 R1300GS
21 V85TT
20 XT250
14 CB1100
08 1200R Sportster
93 R100R
« Reply #76 on: March 20, 2023, 09:00:20 AM »
That is a good point and I don't disagree. I think making CAFE standards has unintended consequences. And since the OEM recommends something different in areas with different regulations I think that IS A GOOD argument to potentially follow THOSE recommendations instead.
Offline Zenermaniac
« Reply #77 on: March 20, 2023, 09:06:51 AM »
Hmm……so THATS why I’m always adding water to my mower battery. I need to keep a better eye on things around here.
Offline kballowe
« Reply #78 on: March 20, 2023, 09:15:50 AM »
Offline Clifton
« Reply #79 on: March 20, 2023, 09:40:20 AM »
Another area I often deviate from what the OEM specs is tire pressure, especially since most now seem to give one pressure for all scenarios. I generally only using what they spec when I'm fully loaded and or 2-up.
25 R1300GS
21 V85TT
20 XT250
14 CB1100
08 1200R Sportster
93 R100R
« Reply #80 on: March 20, 2023, 09:45:36 AM »
That's a spec that can be more directly tested by observing pressure changes at temp.
Offline theoneandonly
  • being honest doesn't pay...you just sleep better !
    • baldricks workshop
« Reply #81 on: March 20, 2023, 12:28:08 PM »
10/60 in the MGX ( synth )
20/60 in the 1200 Sport and Cali Metal ( TRM synth but behaves like a mineral oil )
15/50 in the Breva 750 semi synth ( Guardian )
all Rock Oil.
all get changed every 5k miles , cos it's easier to remember than every 6k miles.
Huzo if you read this , throw that god awful jacket in the bin .  :evil:
« Reply #82 on: March 20, 2023, 03:13:05 PM »
Your 2004 California has hydraulic lifters which require lighter oil for the lifters to function correctly.  That is on all 2003-2004 California models.
All other Guzzis have solid lifters and require heavier oils.  The CARC and V7 Classics have required 10w60 since 2006 and 2009 respectively.
On 2002 and previous solid lifter engines the choice should be 15W50 or 20w50.
On the solid lifter engines the added viscosity and an oil with a higher ZDDP number will keep the cam alive longer.
« Last Edit: March 20, 2023, 03:13:42 PM by rocker59 »
« Reply #83 on: March 20, 2023, 05:28:10 PM »
Offline kballowe
« Reply #84 on: March 20, 2023, 06:13:22 PM »
I never could find that Rotra MP gear oil, but after a bit of research, I discovered that Mobil 1 Delvac gear oil is a virtual match.  Of course, nobody sells that, either.  At least not in the retail stores or the auto parts stores.  I ordered a gallon from Summit Racing.
Offline bad Chad
« Reply #85 on: March 20, 2023, 06:21:11 PM »
How do we really know that's not a deep fake you made up, while siting on your bed in your mom's basement?
« Reply #86 on: March 21, 2023, 09:26:41 AM »
Well, gentlemen, there you have it.  What more could possibly be said?
Offline kballowe
« Reply #87 on: March 21, 2023, 09:32:59 AM »
hahahahahahaaaaa... ..
The AF-1 Racing website has these 10W-60 Castrol oil change kits.  One for the V7 III and another for the Moto Guzzi 1400.  And there are more, of course.  It appears that they're in the spirit of the lubes as specified in the owner's manual.
« Last Edit: March 21, 2023, 09:33:50 AM by kballowe »
« Reply #88 on: March 21, 2023, 03:53:37 PM »
No, he's right.  I cobbled it together, pasted it on one of Hamlin's shop tool boxes, and then sat on the pic for a dozen years just waiting for this thread so I could wreck havac on everyone's motor from afar.  Man, I thought I was way more cleaver than THAT............... ..........dang.
Offline bad Chad
« Reply #89 on: March 21, 2023, 04:57:49 PM »
I new it!!   Maybe now you can admit that the world isn't round too, you ratbas@rd!   :wink: :wink:
« Last Edit: March 23, 2023, 02:35:11 PM by Ncdan »
